LES: dynSmagorinsky does not match analytical y+/u+ profile
Old   September 30, 2014, 11:46
Default LES: dynSmagorinsky does not match analytical y+/u+ profile
aylalisa is on a distinguished road
Dear Foamers,
I've simulated an LES canal flow and used dynamicSmagorinsky (by Alberto Pasquale) with vanDriest damping function.
The dimensionless profiles y+/u+ don't match the analytical log-law. How can I improve these results?
The finer mesh gives a worse result. Why?
Mesh resolution:
Case510: \Deltax+ ~ 18, \Deltay+ ~ 1,6 - 18, \Deltaz+ ~ 10
Case511: \Deltax+ ~ 13, \Deltay+ ~ 1,4 - 15, \Deltaz+ ~ 7
I expected this resolution to be o.k. for LES.
Does dynamicSmagorinsky underestimate \tau_{wall}?
Is it correct to use vanDriest damping in combination with a dynamic SGS model?
Best regards,
Aylalisa
aylalisa is offline   Reply With Quote
Old   October 1, 2014, 08:24
Florian Ries
itchy is on a distinguished road
first:
In dynamic Smagorinsky you use Germano procedure to estimate the Smagorinsky constant. With this you get the y³-law of the wall for nuSgs (that is what you want). If you use van Driest with dynamic procedure you get unphyisical behaviour for nuSgs at the wall. So do never use van Driest with dynSmagorinsky
second:
post your case, then we can help you. Without your case file it is nearly impossible to find the error.
kind regards
Florian
itchy is offline   Reply With Quote
Old   October 1, 2014, 09:31
Florian Ries
Hi again,
how do you calculate tau_w???
Do not calculate tau_w with the velocity gradient near the wall, because you use a inner
variable that depends on your variable! If you do this, then OF (and any other solver) will underpredict tau_w.
A better way is calculating tau_w or u_tau using the pressure gradient (fvOptions).
What kind of LES do you solve??? Near wall resolution LES (NWR) or near wall modelling LES (NWM). If you do NWR, then your y+ is to high.
kind regards
Florian
Old   October 7, 2014, 11:02
Hi Florian,
thanks for your answer, sorry for late reply!
uTau:
uTau.boundaryField()[patchi] =
sqrt
nuEff.boundaryField()[patchi]
*mag(U.boundaryField()[patchi].snGrad())
Is the inner variable "nuEff"?
The other way I'm aware of is to compute tau_w with the Stress Tensor Beff:
tau_w = unit_vector & Beff
I've expected that both methods should give the same result.
How can I use fvOptions file for computation of tau_w? I've assumed that this file allows the definition of source terms (if necessary), to avoid additional coding.
I've only added a momentumSource of type pressureGradientExplicitSource in fvOptions to keep up the flow.
LES with NWR. \Deltay+ ~ 1,5 at the wall and y+_{average}=0,4, y+_{max}=0,6, y+_{min}=0,2 at wall 'bottom'. How small does y+ have to be for a LES with NWR on a single structured grid? y+ < 1 not small enough? My goal was to locate the first cell center in the inner layer of the boundary layer.
Additionally I've chosen nutUSpaldingWallFunction as wall function. For NWR it should not be necessary but could it cause a problem?
first:
o.k.!
second:
all files?
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    //default         steadyState;
    //default         Euler;
  default    backward;
d2dt2Schemes
gradSchemes
    default         Gauss linear;
    //neu:
    grad(nuTilda)   cellLimited Gauss linear 1;
    grad(U)           cellLimited Gauss linear 1;
divSchemes
    default                    none;
    //div(phi,U)               bounded Gauss upwind;
    div(phi,U)                 Gauss LUST unlimitedGrad(U);
    //div(phi,k)                bounded Gauss upwind;
    div(phi,k)                  Gauss limitedLinear 1;
    div(phi,epsilon)          bounded Gauss upwind;
    div(phi,R)                  bounded Gauss upwind;
    div(R)                       Gauss linear;
    div((nuEff*dev(T(grad(U)))))     Gauss linear;
    //neu
    div(phi,nuTilda)             Gauss limitedLinear 1;
laplacianSchemes
    default         Gauss linear limited corrected 0.33;
    //laplacian(nuEff,U) Gauss linear corrected;
    //laplacian((1|A(U)),p) Gauss linear corrected;
    //laplacian(DkEff,k) Gauss linear corrected;
    //laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    //laplacian(DREff,R) Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    //default         corrected;
    default         limited corrected 0.33;
fluxRequired
    default         no;
    p              ;
I've set upwind schemes as discretization schemes for:
Could that cause additional numerical dissipation in my simulation?
|  \\    /   O peration     | Version:  2.2.2                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-6;
        relTol           0.1;
        smoother         GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 50;//10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    pFinal
        solver           GAMG;
        tolerance        1e-6;
        relTol           0;
    //smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        mergeLevels      1;
    "(U|k)"
        solver           PBiCG;
        preconditioner   DILU;
          //solver     smoothSolver;
        //smoother     symGaussSeidel;
    tolerance        1e-08;
        relTol           0;
    "(U|k)Final"
    $U;
        tolerance        1e-08;
        relTol           0;
    B
        solver           PBiCG;
        tolerance        1e-07;
        relTol           0;
    nuTilda
        solver           PBiCG;
        tolerance        1e-07;
        relTol           0;
PISO
    nCorrectors             2;
    nNonOrthogonalCorrectors     1;
PIMPLE
    //nOuterCorrectors        1;
    nCorrectors             2;
    pRefCell                0;
    pRefValue               0;
relaxationFactors
    "U.*"               1;
    "nuTilda.*"         1;
Best regards,
Lisa
Old   October 8, 2014, 03:19
Florian Ries
Hi Lisa,
uTau:
The inner variable is the velocity (mean velocity). In your first approach you use U to calculate utau. And then you use utau to scale U. With this you get uncertainties in utau. Not a good way.
Another possibility is to calculate utau with the gradientP. You can extract gradP of your logfile "pressure gradient = ..." and take the mean of it. Then for channel-flow you get:
utau = sqrt(0.5*h*gradP),
where h is the height of your channel.
Grid-resolution:
your grid should be fine enough. Sorry, I misunderstood your specifications.
fvSchemes:
I would use Gauss linear, Gauss linear corrected. But this should not change so much.
fvSolution:
Do you solve B and k???? I don't know the dynSmagorinsky-code of Alberto Pasquale.
You should insert a residual control, smth. like this:
PIMPLE
nOuterCorrectors 10;
nCorrectors 1;
nNonOrthogonalCorrectors 3;
pRefCell 1001;
pRefValue 0;
residualControl
U
relTol 0;
tolerance 1e-6;
p
relTol 0;
tolerance 1e-6;
Is your case statistical stationary when you begin your averaging??
Is your avaraging long enough??
Do you have proper reference data to check accuracy??
I have never done a LES for channel, only for pipe (but with my own dynSmagorinsky-code). If you don't get it managed with the dynSmagorinsky-code of Alberto Pasquale I can send you my code.
Best regards
Florian
Old   October 8, 2014, 07:09
Hi Florian,
uTau:
I will check and see how curves change!
Grid-resolution:
Especially the fact, that the coarser grid of both simulations gives seemingly the better result, is astonishing. Could this behaviour point to the problem?
fvSchemes/fvSolution:
I'll change and try out.
statistical stationary:
I start averaging after 150 flows through time. Averaging is done for 200 flow throughs.
Do u refer to one-point/ two-point correlations etc.?
I'll try out all these changes and start simulations again. It will take some time, but I'll post results! If it does not work it would be great if I can try your code.
Thank's!
Best regards,
Lisa
Old   October 11, 2014, 07:47
Florian Ries
Hi Lisa,
averaging time that the flow passes 200 times the domain should be enough for a stable mean value. For the variances pherhaps not.
I mean some experimental data of channelflow?? Is there some abnormal behaviour concerning log-law for channelflow as a function of Re?? In pipeflow it is.
With proper reference data I mean some experimental data of exactly your problem?? e.g experimental data of u+ vs. y+ .
Do you have some result??
kind regards
Florian
Old   October 12, 2014, 14:01
Hi Florian,
I was busy at work and completely lag my ToDo list. Tomorrow I can start simulation. It will take some time because I still work on a stand-alone work station. If u_tau is the problem I must recompute that value and correct curves!
proper reference data: I've been searching the net and found data sources
like http://torroja.dmt.upm.es/turbdata/agard/ ()and http://turbulence.ices.utexas.edu/da.../chan590/pdfs/ . I am not yet clear about how to use this data. These sources contain DNS canal data comparable to my case (Re_\tau ~ 400).
I've read papers and literature like the work from Jochen Fröhlich who shows y+/u+ for canal flow (Re_\tau~590). Till now I did not find any hint that the analytical profile shows a different behavior in a canal flow. Though this assumption could be wrong!
To see if the simulation converges a statistical steady state I've plotted the resolved kinetic energy and the turbulent kinetic energy (case511, other is very similar --> attached pic) for start phase and averaging phase.
Additionally you see the u^+_{rms}, v^+_{rms}, w^+_{rms}.
u_{tau}:
wallShearStress.C for RANS computes wSS like
wallShearStress.boundaryField()[patchI] =
           -mesh.Sf().boundaryField()[patchI]
           /mesh.magSf().boundaryField()[patchI]
        ) & Reff.boundaryField()[patchI];
where Reff is the deviatoric part of shear stress tensor resulting from chosen RAS model. In the forum it was discussed that Reff could be replaced by Beff and then this code should compute the wSS for an LES case (and finally u_{tau}). This seems to be a further method to compute u_tau.
Does B contain the sgs stresses computed by the chosen LES model? Where is the difference between tensor fields B and UPrime2Mean?
answer to last question: B -> unresolved stresses (sgs model), UPrime2Mean (var(U)) -> resolved normal stresses ???
Best regards,
Lisa
File Type: png run3_one-point_correlations_half_canal_height_yPlus.png (39.9 KB, 66 views)
Old   October 19, 2014, 08:29
Huang Xianbei
huangxianbei is on a distinguished road
Hi, if a turbulence model is used, the profile may goes upon the analytical profile. I did a similar case with LES before and got similar results as yours. If no turbulence model is used ,then they are commute.
I have a question about the way to calculate the wallShearStress
tau_wall=rho*nu*gradU;
while in the wallShearStressLES, it's calculated as unit_wallnormal &Beff
In my case of a 90 bend duct, the two results deviates about 30-100 times, what's your opinion about that?
huangxianbei is offline   Reply With Quote
Old   October 21, 2014, 12:21
Dear huangxianbei,
thank's for your hint according to the turbulence model!
My function for computing u_\tau, using \tau_{wall} according to unit_wallnormal &Beff ,does not work either.
Problems:
1) how to compute \tau_{wall} ?
\tau_{wall} = (mag((-Sfp/magSfp) & Beffp)*magSfp)
(-Sfp/magSfp) & Beffp should give an vector.
I thought, multiplied by the cell face area should give the desired shear stress ...
2) how to compute u_\tau with \tau_{wall} ?
Dividing it by \rho ?
I haven't solved it yet.
Best regards,
Aylalisa
Old   October 22, 2014, 08:32
Huang Xianbei
Originally Posted by aylalisa View Post
Dear huangxianbei,
Problems:
Best regards,
Aylalisa
Hi,Aylalisa:
If the fluid is incompressible, tau_wall should divide rho to get the right value. However, in my case, I compared the results with experiment's, the way that tau_wall=rho*nu*gradU is in the same order as the experiment's, while the wallShearStress didn't. I don't know why So I'd prefer the way I metioned here.
Xianbei
Old   October 24, 2014, 04:56
Hi Xianbei,
sorry that I ask again but I'd like to be sure to understand you correctly.
You compute \tau_{wall} = \rho * \nu * gradU and this result matches the experimentally received \tau_{wall}.
u_{\tau computed} is equal to u_{\tau measured}.
The problem is that \tau_{wall} = unit_wallnormal &Beff is not equal to \tau_{wall} = \rho * \nu * gradU (and experimental result)?
How do you compute \tau_{wall} = unit_wallnormal &Beff exactly?
Aylalisa
Old   October 24, 2014, 05:22
Huang Xianbei
Hi Xianbei,
Aylalisa
I use the wallShearStressLES http://www.cfd-online.com/Forums/ope...ulation-2.html
You can see from the code that it's computed using unit_wallnormal &Beff similar to the case in RANS with wallShearStress utility
Xianbei
Old   October 24, 2014, 07:44
I started from this thread too but I am still looking for the reason why the result does not agree with \tau = \rho * \nu * gradU :-(
Old   October 27, 2014, 13:55
Hi huangxianbei,
I've computed \tau_{wall} and u_\tau by the different ways.
u_\tau= sqrt(\nu_{eff} * snGrad(U))
u_\tau = sqrt(mag((-Sfp/magSfp) & B_{eff}))
\rho is not needed.
I get different results if I compute \tau_{wall} with the different methods, the difference is not as big as in your case:
wSS_gradU.boundaryField()[patchi] =
        * mag(U.boundaryField()[patchi].snGrad());
ssp = (-Sfp/magSfp) & Reffp
I abstain from multiplication with \rho.
I don't know how the values develop but these are the values in the beginning of calculation:
wSS (snGrad()) = 0.00103336
wSS (devReff()) = 0.000889885
Though I'd like to know why there is a difference, because u_\tau results are very similar.
uTauLES uTauLES output:
    patch bottom u_tau : min = 0.0135431, max = 0.0430144, average = 0.0315161
utau_Beff_LES utau_Beff_LES output:
    patch bottom u_tau : min = 0.0135416, max = 0.0430147, average = 0.0315165
Aylalisa
Old   October 27, 2014, 20:04
Huang Xianbei
Hi huangxianbei,
\rho is not needed.
Aylalisa
Hi,Aylalisa:
Why it seems that Reff can be used to calculate the LES case? As you wrote in the thread, you use Reff. Isn't it a RANS variant instead of LES? The latter 2 results are close enough, is it the same case as the former?
Xianbei
Old   October 28, 2014, 03:17
Hi Xianbei,
to figure out R_{eff} for LES:
I've choosen one of the turbulence models, for example oneEqEddy.C.
Check the source code, line 65 --> Function call GenEddyVisc()
Then check the file GenEddyVisc.C (in my case for incompressible fluids), line 92:
return -nuEff()*dev(twoSymm(fvc::grad(U())));
This line seems to be \tau_{ij}^r = - 2 * \nu_{eff} * S_{ij}.
S_{ij} can be computed from grad(U()), it is the symmetric part of the deviatoric part of tensor grad(U()). The entity of that expression is m^2/s^2, not yet a shear stress (I think for incompressible fluids it is better to pass the multiplication with \rho). Apart from multiplication with \rho you have the stress tensor coming from the model. Have a look at LESModel.H, line 218, there you find nuEff().
Aylalisa
Old   October 28, 2014, 04:52
Huang Xianbei
Hi Xianbei,
Aylalisa
Hi,Aylalisa:
Thank you for your explaination. I'm a little confused about the Reff and Beff, is there any difference between them?
Xianbei
Old   October 28, 2014, 14:47
Hi Xianbei,
I don't understand. How can I run a LES without an LES turbulence model
I hope anybody could support us here about the reason why defReff() is used for computation of the wallShearStress!
I think:
defReff()
extracts a shear stress tensor field computed with nuEff, without the isotropic part (I think you could also call it hydrostatic part). Since we want to compute the wallShearStress we neglect the isotropic part of the tensor but need to multiply with nuEff.
B()
return ((2.0/3.0)*I)*k() - nuSgs_*twoSymm(fvc::grad(U()));
seems to be:
\tau_{ij} - \frac{\delta_{ij}}{3}\tau_{kk} = -2\nu_{T}\bar{S_{ij}}
\tau_{ij} = \frac{\delta_{ij}}{3}\tau_{kk} -2\nu_{T}\bar{S_{ij}}
The isotropic part is computed from the kinetic energy (\frac{1}{2}u^2)that comes, depending on the model, from a transport equation. The result B(), including the isotropic part, computed with \nu_T (eddy viscosity of residual motions) should be used for solving that equation.
Aylalisa
Old   October 28, 2014, 19:48
Huang Xianbei
Hi Xianbei,
Aylalisa
Hi,Aylaisa:
Sorry,that's actually not a LES case, but a case without turbulence model, say "under-resolved DNS" or something else.
According to your discription, it may be right to compute wallshearstress using B() instead of defReff. While for incompressible flow, dev_Sij=Sij as dui/dxi=0. So in that case, defReff can be used. Am I right?
Xianbei
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
LES Near-Wall Velocity Profile Alex May FLUENT 2 June 12, 2008 12:36
What's wrong with my RMS profile in LES Jiang Ning FLUENT 0 March 31, 2005 05:30
