does anyone know what does flowType do?
Old   April 1, 2013, 15:55
Default does anyone know what does flowType do?
immortality's Avatar
Ehsan
immortality is on a distinguished road
i used flowType command.how can find type of flow(shear flow,with or without circulation or fully turbulent mentioned somewhere i saw) from the numbers like:
0.07651246272745461
0.009874601375924783
0.4152505236808813
0.9556226864937011
0.9416049188595975
0.5856388528734834
0.2512780734589708
0.2002043050379488
0.2956873682252182
0.344476903828302
0.392744880848549
0.4422645731141795
0.5060221916933719
0.603670873234636
0.791199009088522
0.728309604866278
0.3407973861953704
0.9500353914061376
0.3114390527424502
0.1782654103206394
0.1555218835283287
0.162709215687532
it has resulted.
immortality is offline   Reply With Quote
Old   April 6, 2013, 18:15
Ehsan
nobody knows?
Old   April 7, 2013, 09:07
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Immortality,
In the Doxygen C++ documentation you will find the following explanation for flowType:
Description
Calculates and writes the flowType of velocity field U.
The flow type parameter is obtained according to the following equation:
lambda = (|D| - |Omega|)/(|D| + |Omega|)
-1 = rotational flow
0 = simple shear flow
1 = planar extensional flow
I don't know the exact meaning of D and Omega, but it seems that D is a measure of the angular deformation of the fluid particle and Omega is a measure of it's rotation.
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   April 7, 2013, 13:26
Ehsan
thanks.I has saw that.but what does .37 mean it not exactly 0,-1,1 ?
is this somewhat like 0 and somewhat like 1 propounded numbers?
Old   April 8, 2013, 05:30
Ehsan
what's the usage of it?does it have an equivalent parameter in CFD?has anyone encountered it in CFD texts anywhere?
Old   November 12, 2014, 14:31
Mehid
Metti is on a distinguished road
Hi Ehsan,
have you ever found out about what would be the usage of "flowType"?
I mean what's the benefit of this command?
Best,
Mehdi.
Metti is offline   Reply With Quote
flowType sersunzo OpenFOAM Running, Solving & CFD 3 April 1, 2013 16:11
