buoyant pimple foam
Old   May 11, 2014, 01:11
Default buoyant pimple foam
ali
alzgh is on a distinguished road
hi
i want to anderstand in which problems buoyant pimple foam uses?
and in "hot room" problem we dont have any inlet flow or outlet flow how flow creation in this problem?
alzgh is offline   Reply With Quote
Old   December 4, 2014, 02:16
Default Which solver did you use to solve this problem?
Xia Shuning
Bulrush is on a distinguished road
since "No inlet and outlet" in your configuration, why not incompressible solver ?
Bulrush is offline   Reply With Quote
Old   December 4, 2014, 02:37
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
this is an excerpt from buoyantPimpleFoam.C
Application
    buoyantPimpleFoam
Description
    Transient solver for buoyant, turbulent flow of compressible fluids for
    ventilation and heat-transfer.
    Turbulence is modelled using a run-time selectable compressible RAS or
    LES model.
In hotRoom tutorial flow is created by buoyancy force as gas is heated from below (heat source is set by setFields).
alexeym is offline   Reply With Quote
Old   December 4, 2014, 05:36
Xia Shuning
Originally Posted by alexeym View Post
Application
    buoyantPimpleFoam
Description
    LES model.
hi, so could you tell me where I can find the governing eqs for "buoyantPimpleFoam"? 3q.
Old   December 4, 2014, 05:42
Alexey Matveichev
In
$FOAM_APP/solvers/heatTransfer/buoyantPimpleFoam/*Eqn.H
Old   December 4, 2014, 06:28
Xia Shuning
In
Thanks very much.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
