December 9, 2014, 05:32 |
chtMultiRegionSimpleFoam 3D
Rep Power: 11 |
Good Morning!
I have a simple question (at least I guess) that I'm sure you can solve. I'm using the chtMultiRegionSimpleFoam in order to create a model which consists in a little cube which has heat transfer which my fluid (everything inside a pipe of 5x2x2). I took planeWall2D as a model, and I achieved to draw it in 2D, but not in 3D model. The problem is that I don't get a cube of 0.4L, I get a prism of 0.4x0.4x2 (so OpenFoam doesn't take care about Z dimensions). This is my topoSetDict file: PHP Code:
PHP Code:
I attach my complete case folder, maybe the failure is there. Thank you in advance! |
December 11, 2014, 03:17 |
Rep Power: 11 |
I solved it!
It was enough to add the front and back face as "symmetry plane", and for having 3D mesh, change z component in the hexaedron in blockMesh (if it is input a "1" error are produced in front and back faces) I hope it can help somebody! |
December 27, 2014, 10:19 |
chtMultiRegionSimpleFoam - sphere around a fluid
Rep Power: 12 |
Hi all guys,
i am trying to simulate a static sphere (hot sphere) in a fluid (cold fluid) which transfers heat by difference of temperature.I created the mesh with salome and i have two regions: fluidRegion (air) , solidRegion (sphere) My goal is to get a convergence with HeatFlux (computed by using the tool wallHeatFlux available in OF2.3.X) increasing the cells of the mesh. I started playing with planeWall2D as a model, but when i started using these kind of problems i do not get any convergence with wall flux. here i enclose the folder 0 to check BC ( i am not sure about them)! , could someone please help me with this case?? i am trying making different changes but i do not get a right heat flux between both regions, even if residuals go below than 10^-5. I ll really appreciate, thank you very much in advance!! P.S. I use OpenFoam 2.3.x and salome 6.6.0 to create meshes |
