December 16, 2014, 08:22 |
Probe function file
António Pires
Rep Power: 11 |
Hello everyone,
I used the probe function to calculate the velocity vector in about 30 different points in a wave flume. After the run i got the file with the velocity vectors for each point and each time step. So now i have a massive file with a lot of information and i want to do a time average for every measurement points but it's a lot of information and doing this manually would take a long long time. I was wondering if there is a way to export this file to an excel sheet or something similar so the data treatment would be much faster. Thank you! António |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
