January 26, 2015, 13:07 |
InterFoam - time step
Rep Power: 11 |
Hallo,
Can somebody help me with the following problem? I am trying to run InterFoam simulation on a general geometry (large wessel filled with water). The mesh is made of tetrahedral elements and the minimum elements size is over 20 mm. The inlet velocity is about 7m/s. If I calculate the time step for this configuration with Courrant number under 0.1 this is about 3e-4s. But if I run the simulation the solver decreases the time step under 1e-10, which is for 30s calculation impossible to calculate. Can somebody advise me what to do to keep the time step on some realistic level? Regards Atlan |
January 26, 2015, 14:10 |
Just to clarify a little bit: Co = u*dt/dx: Co = 0.1, u = 7, dx = 20e-3 -> dt ~ 3e-4. But really, show your: 1. checkMesh output 2. fvSchemes & fvSolution (maybe also controlDict to check your initial deltaT) 3. IC & BC (i.e. archive of your 0 folder), if you set initial distribution of alpha1 with setFields, post a screenshot of your initial distribution of alpha1. |
January 27, 2015, 05:24 |
Pablo Higuera
Rep Power: 19 |
Hi atlan,
from my experience is better to forget about using tetrahedral meshes with interFoam, as the spurious velocities at the interface are enormous and advection of the phases looks horrible. Try a hex-dominant mesh instead. Best, Pablo |
March 13, 2015, 16:09 |
Time step problems
Rep Power: 11 |
Dear Pablo,
you were completely right. I prepared completely hexa mesh and there is no problem with the time step anymore. Atlan |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
