Heat transfer coefficient/heat flux BC
Old   June 5, 2015, 07:48
Default Heat transfer coefficient/heat flux BC
buffi is on a distinguished road
Hi all,
I have a 2D (x,y) flow with heat transferred into that flow through the walls with normal z, so it's basically a flat heated channel:
"htc" is a field with the local heat transfer coefficient coefficients and I'd now like to solve the temperature field. As a first step, a constant heat flux is sufficient and the wall temperature should be adjusted to allow for the desired heat flux.
How can I impose such a boundary condition? I thought about adapting the fixedGradient BC, but I'm not sure how that would work in my case. Are there other BCs that could work?
Regards
Christoph
buffi is offline   Reply With Quote
Old   December 4, 2019, 08:05
rohan majalekar
rohan1495 is on a distinguished road
hi
You mentioned htc- local heat transfer coefficient. My query is about post processing of heat transfer coefficient. The utility wallHeatTransferCoeff is giving error, I have gone through all related threads but still I am figuring it out so any hints for htc calculation or post processing would be appreciated.
Thank you
rohan1495 is offline   Reply With Quote
chtMultiRegionFoam heat flux sailor79 OpenFOAM Running, Solving & CFD 0 September 27, 2013 08:08
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 04:07
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 02:18
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
heat transfer flux Mark FLUENT 4 August 13, 2003 01:49
