rhoSimpleFoam div(phi,k/K) 2.1.x 2.0.x
Like Tree1Likes
  • 1 Post By maHein
Old   January 31, 2013, 09:09
Default rhoSimpleFoam div(phi,k/K) 2.1.x 2.0.x
Martin
wernsen is on a distinguished road
Dear Foamers,
I am having trouble with a rhoSimpleFoam case which is running under 2.0.x without a problem. If I try to run this case under 2.1.x I am gettin the Fatal Error:
--> FOAM FATAL IO ERROR:
keyword div(phi,K) is undefined in dictionary
What is the capital K and why do I need it since in 2.0.x it is not necessary?
thx
martin
wernsen is offline   Reply With Quote
Old   January 31, 2013, 09:24
doubtsincfd is on a distinguished road
something is missing in fvSchemes
It might also be a missing comma or a {
Try giving a default scheme for div
doubtsincfd is offline   Reply With Quote
Old   January 31, 2013, 09:42
Martin
my fvSchemes::divSchemes looks like that:
divSchemes
   default            none;
   div(phi,U)                     Gauss upwind;
   div(phi,h)                     Gauss upwind;
   div(phi,k)                     Gauss upwind;
   div(phi,epsilon)               Gauss upwind;
   div(phi,omega)                 Gauss upwind;
   div(U,p)                     Gauss linear;
   dic(phi)              Gauss linear;
   div((muEff*dev2(T(grad(U)))))  Gauss linear;
so I already have a scheme for the div(phi,k) but not for div(phi,K) which confuses me. So what is the K?
Old   January 31, 2013, 10:06
maHein is on a distinguished road
The formulation of the energy equation has changed from 2.0.x to 2.1x. In the later one, the divergence on the kinetic energy K is part of it. That's why you need div(phi,K) in your fvSchemes. See line 8 of the hEqn.H file:
- fvc::div(phi, 0.5*magSqr(U), "div(phi,K)")
By the way, I noticed considerable differences between results from both versions. I tested both for turbomachinery simulation and the 2.1.x resulted in negative isentropic efficiencies. So make sure to compare both results and see if they are reasonable.
maHein is offline   Reply With Quote
Old   February 4, 2013, 02:43
Martin
Thank You very much "maHein"!
Old   February 20, 2015, 09:12
Eugen
estang is on a distinguished road
I use Version 2.3.0 and i do not understand why the angledDuctExplicitFixedCoeff tutorial for rhoSimpleFoam runs with
div(phi,k)      bounded Gauss upwind;
and the same fvSchemes file doesn't work with my case.
I get the following errormessage:
keyword div(phi,K) is undefined in dictionary "/home/estang/OpenFOAM/estang-2.3.0/run/2_fluid_Testcase_comp_heat_transfer/system/fvSchemes.divSchemes"
file: /home/estang/OpenFOAM/estang-2.3.0/run/2_fluid_Testcase_comp_heat_transfer/system/fvSchemes.divSchemes from line 30 to line 40.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 437.
FOAM exiting
i just want to understand
estang is offline   Reply With Quote
Old   February 20, 2015, 10:01
It is a capital "k" in your warning: div(phi, K).
Old   February 23, 2015, 01:20
Eugen
That's why i'm asking here in this thread. I copied the fvSchemes without any edit from the tutorial. I can run the tutorial but when i try to run my own case with the same fvSchemes the solver complains. Shouldn't the same message appear with running the tutorial case?
Old   February 24, 2015, 03:32
You have to check whether you use sensibleEnthalpy or sensibleInternalEnergy in your thermodynamicProperties. This changes the form of the energy equation and thus introduces different terms such as div(phi,K).
m.omair likes this.
Old   February 24, 2015, 03:52
Thumbs up
Eugen
Thank you very much.
Bad that i didn't see the difference in my thermophysical Properties before.
I should have a look to the different formulations.
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Pressure instability with rhoSimpleFoam philipp. OpenFOAM 13 October 30, 2016 03:39
Installation on Ubuntu 12.04 LTS samiam1000 OpenFOAM Installation 11 May 26, 2012 05:54
Transonic rhoSimpleFoam Equations eric.m.tridas OpenFOAM 3 January 25, 2012 10:52
Problem with rhoSimpleFoam mecbe2002 OpenFOAM 3 April 11, 2010 00:54
