twoPhaseEulerFoam execution error
Old   March 11, 2015, 09:40
Default twoPhaseEulerFoam execution error
Tomas Trewhela
Trewhela is on a distinguished road
I'm new in OpenFoam and I'm trying to model a snowdrift in a rectangular grid, with an inlet velocity from the left face and outlet at the right face of the grid. I'm getting this error and there are a few things I can't explain, such as the negative courant number and a negative volume fraction for alpha.particles.
¿Could this be a BC error?
Thanks,
| \\ / O peration | Version: 2.3.0 |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : twoPhaseEulerFoam
Date : Mar 11 2015
Time : 11:27:51
Host : "TT-est-rhma"
PID : 32230
Case : /home/tomas/OpenFOAM/tomas-2.3.0/run/snowdrift
nProcs : 1
Create time
Create mesh for time = 0
Reading g
Creating twoPhaseSystem
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleInternalEnergy;
Calculating face flux field phi.particles
Selecting diameterModel for phase particles: constant
Selecting turbulence model type RAS
Selecting RAS turbulence model kineticTheory
Selecting viscosityModel Gidaspow
Selecting conductivityModel Gidaspow
Selecting radialModel SinclairJackson
Selecting granularPressureModel Lun
Selecting frictionalStressModel JohnsonJackson
kineticTheoryCoeffs
equilibrium on;
e 0.8;
alphaMax 0.62;
alphaMinFriction 0.5;
residualAlpha 1e-06;
viscosityModel Gidaspow;
conductivityModel Gidaspow;
granularPressureModel Lun;
frictionalStressModel JohnsonJackson;
radialModel SinclairJackson;
JohnsonJacksonCoeffs
Fr 0.05;
eta 2;
p 5;
phi 28.5;
type heRhoThermo;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
Calculating face flux field phi.air
Selecting diameterModel for phase air: constant
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Selecting default blending method: none
Selecting dragModel for (particles in air): GidaspowErgunWenYu
Selecting swarmCorrection for (particles in air): none
Selecting virtualMassModel for (particles in air): constantCoefficient
Selecting heatTransferModel for (particles in air): RanzMarshall
Calculating field DDtU1 and DDtU2
Creating field dpdt
Creating field kinetic energy K
No MRF models present
Courant Number mean: -0.0797 max: -0.04
Max Ur Courant Number = -0.04
PIMPLE: Operating solver in PISO mode
Starting time loop
fieldAverage fieldAverage1:
Starting averaging at time 0
Time = 0.0002
MULES: Solving for alpha.particles
smoothSolver: Solving for alpha.particles, Initial residual = 0, Final residual = 0, No Iterations 1
alpha.particles volume fraction = -0 Min(alpha1) = 0 Max(alpha1) = 0.5
smoothSolver: Solving for e.particles, Initial residual = 1, Final residual = 1.12571e-16, No Iterations 1
smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 0.994753, No Iterations 1000
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Trewhela is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
