changing viscosity in main solver
Old   March 27, 2015, 08:21
Default changing viscosity in main solver
Luuk Buijs
lcbuijs is on a distinguished road
Dear Foamers,
I would like to edit buoyantBoussinesqPimpleFoam to implement temperature-dependent viscosity. I've started to work on createFields.H, by trying to output the viscosity. So far I've added:
    volScalarField nu
        IOobject
            "nu",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        <function goes here>
However, this works only for any random name other than "nu". Can anyone point me in the right direction or tell me what steps I should take to change the viscosity?
Many thanks!
Luuk
lcbuijs is offline   Reply With Quote
Old   March 28, 2015, 14:56
Agustín Villa
agustinvo is on a distinguished road
I think you can't do this in this way, since in this solver, nu is a transportProperties variable, and this creates a conflict between the nu the solver has and the one you define.
I propose you two thinks:
  • Modify the solver and include your nuModified instead of nu
  • I think there are different options to express nu as a function inside the transportProperties file... take a look to this thread
agustinvo is offline   Reply With Quote
Old   March 30, 2015, 04:29
Luuk Buijs
Heres my problem: buoyantPimpleFoam is the go-to solver for this kind of implementation. I can't get that solver to work for my geometry however, and am therefore stuck with buoyantBoussinesqPimpleFoam, which works fine so far. I haven't been able to find anything on how to modify viscosity in the main buoyantBoussinesqPimpleFoam solver.
Can anyone here show me an example on how this or something comparable is done?
Many thanks again!
Luuk
Old   March 30, 2015, 05:08
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
In general it is done through implementation of new viscosity model. You can find existing models in $FOAM_SRC/transportModels/incompressible/viscosityModels. So you take, for example, powerLaw model; copy it into myCoolNewViscosityModelWithTemperature; rename source files, correct Make/files and Make/options; add const volScalarField& T_ as a property of new class; use U.mesh().lookupObject("T") to initialize T_; and finally in calcNu method you utilize T_ to calculate new value of viscosity.
alexeym is offline   Reply With Quote
Old   March 30, 2015, 07:04
Luuk Buijs
Originally Posted by alexeym View Post
Dear Alexey,
Thank you very much for your reply. I'll look into this!
Old   March 30, 2015, 07:52
Alexey Matveichev
It turns out there is an example of implementation - http://www.tfd.chalmers.se/~hani/kur...nFoam%20v2.pdf [1]
There author decided to lookup temperature field each time calcNu is called instead of looking the field in constructor.
[1] - http://www.cfd-online.com/Forums/ope...tml#post538956
Old   March 24, 2019, 10:13
ALOK KUMAR
alok1463 is on a distinguished road
Hi All,
I am simulating slurry flow. I am facing following problem during implementation of different functions of viscosity in different regions based on alpha. Expressions for the viscosity are given below.
volScalarField mueff
IOobject
"mueff",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh,
dimensionedScalar("mueff", dimViscosity, 0.0)
Definition of viscosity:
forAll(mesh.cells(), i)
mueff[i]= mu2.value()*(1.0 + 2.5*alpha1[i] + 10.05*Foam::sqr(alpha1[i]) + 0.00273*Foam::exp(16.6*alpha1[i]));
if ((alpha1[i] > 0.305))
mueff[i]=mu2.value();
Momentum equation:
fvVectorMatrix UEqn
fvm::ddt(rho, U) + fvm::div(phi, U)
+ MRF.DDt(rho, U)
- fvm::laplacian(rho*mu2/rho2, U)
- fvc::laplacian(rho*mueff*alpha1/rho2, US)
- fvc::laplacian(mu2*gs, US)
fvOptions(rho, U)
- gs*(rhos-rho2)*g
- fvm::Sp(Kdf, U)
UEqn.relax();
fvOptions.constrain(UEqn);
Solver is compiled successfully but it gives following error during running of test case:
DILUPBiCGStab: Solving for T, Initial residual = 1, Final residual = 7.09367e-09, No Iterations 5
DILUPBiCGStab: Solving for C, Initial residual = 0.000216836, Final residual = 6.22504e-13, No Iterations 1
THERMO: iteration 1 residual: 0
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 ? at ??:?
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? at ??:?
Floating point exception (core dumped)
Please provide me the suggestions to rectify the errors.
Thank you.
alok1463 is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
Changing viscosity in interFoam ThomasV OpenFOAM Running, Solving & CFD 5 March 12, 2015 06:43
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 11:00
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
