Equations in the MRFsimpleFOAM
Old   June 5, 2008, 01:24
Default Hi in the MRFsimpleFOAM,the
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi
in the MRFsimpleFOAM,the basic equation seems in the Absolute Velocity Formulation,which have the relative velocity and abolute velocity both in the momentum eqution.that is why ?is there any
advantage in that way ?
waynezw0618 is offline   Reply With Quote
Old   June 5, 2008, 02:15
Default Yes: you do not have to do exp
Hrvoje Jasak
Yes: you do not have to do explicit coordinate transformation for the MRF interface, which makes the code MUSH simpler.
Enjoy,
Hrv
Hrvoje Jasak
Old   June 29, 2008, 03:12
Default Hi Hrv! thank you very much!b
wayne.zhang
Hi Hrv!
thank you very much!but i still cannot understand it very much for the question that,when you use absolut formulation,the "U" in the kepsilon model is relative velocity or absolute veloctiy?for example the production term in the k equation there is a Grad(U).what is this "U" is it relative velocity or abosolut velocity?
thanks
wayne
Old   June 30, 2008, 03:25
Default The "relative" or "absolute" v
Hrvoje Jasak
The "relative" or "absolute" velocity is for the moving part of the multiple reference frames - in that region you have solid-body rotation + local flow velocity, giving you a choice of formulation.
Enjoy,
Hrv
Hrvoje Jasak
Old   June 30, 2008, 12:32
Default Hi Hrv! thanks!,but my equest
wayne.zhang
Hi Hrv!
thanks!,but my equestion is when in the rotation region,what velocity is used to calculate the "k","epsilon" and "omega" for KEpsilon or KOmega turbulence model.although the equation of k","epsilon" and "omega"have the same form in the both rotation and fixed frame,they have convection term and production term which is related to the velocity,for this velocity,i think there will be different from the rotation frame to the fixed one.or i think in the rotation frame the turbulence kinetic--k is convected with the "relative velociy" and produced by the gradient of "relative velociy" ,but for the station part that is "abosulte velocity". is that right?how about the MRFsimpleFoam? could you please tell me more
thanks
wayne
Old   May 7, 2015, 04:43
M. Montero
be_inspired is on a distinguished road
Same doubt here.
I am using OF2.3.x and very strange results are obtained at first cell around blade. I am simulating a wind turbine.
Even if the first cell height has been calculated for a y+=100 taken into account that the blade is rotating.
pressure distribution is non-real and so epsilon field at that location. The simulation crashes quickly
be_inspired is offline   Reply With Quote
CellZons and MRFSimpleFoam vinz OpenFOAM Running, Solving & CFD 19 December 1, 2016 15:18
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
MRFSimpleFoam ERROR waynezw0618 OpenFOAM Running, Solving & CFD 5 July 28, 2011 10:34
MRFSimpleFoam command to run shyam OpenFOAM Running, Solving & CFD 2 February 5, 2009 05:38
MRFSimpleFoam xdanielx OpenFOAM Running, Solving & CFD 0 December 17, 2008 01:28
