mpirun error when using -parallel option
Old   May 19, 2015, 09:46
Default mpirun error when using -parallel option
Taro TOKUTAKE
TToku is on a distinguished road
Dear all.
I'm beginner of OF., so please forgive me that my primary question.
I'm trying to calculate the flow in the channel, but following error occurs when execute mpirun with -parallel option.
 --> FOAM FATAL IO ERROR:
 Expected a '(' while reading Tuple2, found on line 0 the label 0
 file: IOstream at line 0.
     From function Istream::readBegin(const char*)
     in file db/IOstreams/IOstreams/Istream.C at line 94.
FOAM parallel run exiting
The error will not appear when don't use -parallel option.
Please tell me how can I solve the problem.
(solver is pisoFoam, and parallel core number is 12.)
I thank you very much in advance for your cooperation.
TToku is offline   Reply With Quote
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 03:53
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
