Porblem getting resonable results using KomegaSST for an airfoil case |
May 21, 2015, 13:40 |
CFD
Hello All,
I have been using OpenFoam for about four months so far. I’ve learned the basics through some tutorials and I’ve been recently trying to obtain some good results for a 2D airfoil case. I’m using simpleFoam with both Spalart-Almaras and kOmegaSST turbulence models to simulate the flow around a NACA 0015 airfoil (Reynolds number approximately 2.575*10^6 and 0 degrees angle of attack). After finishing the grid convergence study, which gave a value of Cd = 0.016 at zero mesh spacing, I have obtained values of Cl and Cd 1.042858e-03 and 1.675878e-02 respectively. The experimental result, especially for Cd shows a value of 1.4e-02. However, after finishing the validation using Spalart-Almaras, I am unable to get reasonable results when I switch to KomegaSST turbulence model. I’m really asking for some help. MESH: Using Gmsh This is how the mesh looks like in Paraview: Mesh.jpg Zoom.jpg BOUNDARY CONDITIONS: I’m using freestream BC for U both at inlet and outlet, and obviously zero velocity condition on airfoil patch. For p, freestreampressure at inlet/outlet and zerogradient on airfoil. For k, freestream BC at inlet/outlet and fixedValue on airfoil. For omega, freestream BC at inlet/outlet and fixedValue on airfoil. For nut, calculated BC at inlet/outlet and fixedValue on airfoil. Down here you’ll find the complete case directory with all the files http://www.mediafire.com/download/zk...-Komega.tar.gz |
May 22, 2015, 06:16 |
Hasan K.J.
Hello there,
What is your Y+ value and did you try your cases with and without wallfunctions ?, In my experience this factor is one of the most important for validation Please have a look here http://www.cfd-online.com/Forums/ope...provement.html What is the final validation you are trying to acheive ? just Cl/Cd or Cp and boundary layer growth aswell ? If you want Cp and boundary data aswell did you consider them during mesh independency study Regards, Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius |
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
Unphysical Results of Low-Re Airfoil Simulations | ericthefatguy | SU2 | 2 | February 2, 2015 05:07 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
oscillating airfoil test case | Akbar | Main CFD Forum | 1 | July 22, 2005 11:49 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
