Adding a solver without admin rights
Old   August 29, 2017, 05:25
Default Adding a solver without admin rights
Gearb0x is on a distinguished road
I need to modify the interFoam solver to make it take into account molecular diffusion in the phase continuity equation.
However, I work on a station where I don't have the admin rights. So apparently, following this tutorial does not work because it requires to have access to the OpenFoam installation folder to put some files there (which I can't)
Could someone point me towards a "procedure" to create a new OpenFoam solver without the admin rights ? If it is even possible...
Thanks for the support.
Gearb0x is offline   Reply With Quote
Old   August 29, 2017, 05:56
akidess's Avatar
Anton Kidess
OpenFOAM does not care where you build your solvers. In fact, $WM_PROJECT_USER_DIR should be set to a subdirectory of your home directory, so you should be able to follow the tutorial you linked.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   August 29, 2017, 06:56
Hello and thanks for your time,
Actually, I have been an idiot. of course the $(FOAM_USER_APPBIN) was not a valid alias. That was the issue.
Can an admin delete this post ? I don't think it is very useful but I couldn't find a way to delete it myself ?
adding a solver from OF 16.x to OF 4.x marauder OpenFOAM Running, Solving & CFD 2 May 26, 2017 13:11
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 11:05
problem in adding instructions to the solver Gary51075607 OpenFOAM Programming & Development 2 January 13, 2015 22:26
Adding additional complex source term to BuoyantBoussinesqPisoFoam solver pajofego OpenFOAM Programming & Development 2 April 9, 2013 17:00
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
