Simulation axial fan - error
Old   July 24, 2015, 16:22
Arrow Simulation axial fan - error
Clement Mtrl
Clmkite is on a distinguished road
Hi Everyone,
I' new to openFoam but already work on StarCCM+. My company want to develop CFD but with opensource but I'm kind of alon for this point and I find it hard to find great tutorials about the method with Linux/OpenFoam (not about CFD). It was kind of long to install everything first and run one tutorial.
I used ANSYS to create my mesh: wich I'll probably refine when I will succeed my first simulation.
You can find it here : http://we.tl/iMd0hE2YDj
So I copied the folder tutorials/incopressible/SRFSimpleFoam/mixer in my running folder.
Copy my mesh in it and run: fluent3DMeshToFoam fans.msh
Then I changes boundary so cyclic_half0 (&1) are like in the tutorials, nu = 33.10-6 (Hydrogene at 0.3MPa)
I also change the velocity inlet to 17m.s-1
For the first try, I didn't change anything else.
So I tried to launch SFRSimpleFoam but I have tho following message which I don't know what to do with :
| \\ / O peration | Version: 2.1.1 |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : SRFSimpleFoam
Date : Jul 24 2015
Time : 15:53:39
Host : "clement-VirtualBox"
PID : 3810
Case : /home/clement/OpenFOAM/clement-2.1.1/run/fans
nProcs : 1
Create time
Create mesh for time = 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:olyPatch::faceCellCentres() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::cyclicPolyPatch::calcGeometry(Foam::PstreamB uffers&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam:olyBoundaryMesh::calcGeometry() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam:olyMesh:olyMesh(Foam::IOobject const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/SRFSimpleFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Segmentation fault (core dumped)
I don't really know what to do.
So if somebody can help me on tell me where I sould go find informations to resolve this case.
Thanks a lot
Clement
Clmkite is offline   Reply With Quote
Old   July 25, 2015, 02:57
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Well firstly your "innerwall" and "outerwall" BC had to be "innerWall" and "outerWall"
Then your cyclics dont match perfectly which is why the cyclic BC is completely useless unless using fully structured mesh. So the cyclics need to be of type cyclicAMI.
And also cyclicAMI in all the 0 files.
cyclic_half0
        type 		cyclicAMI;
        inGroups        1(cyclicAMI);
        nFaces          13819;
        startFace       2617836;
	matchTolerance  0.0001;
        neighbourPatch  cyclic_half1;
        transform 	rotational;
        rotationAxis 	(0 0 1);
        rotationCentre 	(0 0 0);
    cyclic_half1
        type 		cyclicAMI;
        nFaces          13819;
        startFace       2631655;
        neighbourPatch  cyclic_half0;
I have tweaked the fvSolution and fvSchemes a couple of places to better match unstructured meshes.
But you have a much bigger problem
The mesh is not sutiable for solving
chechMesh gives this
   Mesh non-orthogonality Max: 84.2138 average: 15.006
   *Number of severely non-orthogonal (> 70 degrees) faces: 199.
    Non-orthogonality check OK.
  <<Writing 199 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
 ***Max skewness = 14.4396, 146 highly skew faces detected which may impair the quality of the results
  <<Writing 146 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
Your skewness should be below 3 and non-ortho below 75.
Link to Case
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   July 25, 2015, 09:19
Clement Mtrl
Hi Linnemann.
Thanks a lot for your time.
First, where could if find the information for cyclic boundary like cyclicAMI ?
I thought my face matched because I used match control in Ansys...
Furthermore, I thought I could try a first run (no or bad convergence) with this mesh and later work on it. OpenFOAM don't start run if it considered the mesh too bad ?
I will work on my mesh and take in consideration your comments and let you know
Old   July 25, 2015, 09:22
linnemann's Avatar
Niels Nielsen
Google cyclicAMI
I tried running it and it starts to diverge immediately.
Checked in Paraview and the bad cells are causing velocities in the 5e6.
So no the current mesh is no good.
Linnemann
Old   July 27, 2015, 10:58
Clement Mtrl
Hi Linnemann,
I watched your folder on Drive and I have some questions.
(for the moment, and I'm not oworking on the mesh but more about understanding and using great controls in OpenFoam).
I see that you havec a blockmeshdict in your system folder. I don't understant because we used an external mesh...
Also, you change many points in fvSchemes and I'd like to know where I can find documentation to explain each keywords you use because in the user guide, I didn't see a list of keywords we can use.
Thanks a lot for your help
PS: When I try to lauch you case, I also have this error :
clement@clement-VirtualBox:~/OpenFOAM/clement-2.4.0/run/fan$ SRFSimpleFoam
| \\ / O peration | Version: 2.4.0 |
Build : 2.4.0-f0842aea0e77
Date : Jul 27 2015
Time : 13:17:35
PID : 12725
Case : /home/clement/OpenFOAM/clement-2.4.0/run/fan
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Reading field p
AMI: Creating addressing and weights between 13819 source faces and 13819 target faces
AMI: Patch source sum(weights) min/max/average = 1, 1, 1
AMI: Patch target sum(weights) min/max/average = 1, 1, 1
Reading field Urel
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Creating SRF model
Selecting SRFModel rpm
No finite volume options present
SIMPLE: no convergence criteria found. Calculations will run for 1000 steps.
Starting time loop
Time = 1
--> FOAM FATAL IO ERROR:
keyword div((nuEff*dev(T(grad(Urel))))) is undefined in dictionary "/home/clement/OpenFOAM/clement-2.4.0/run/fan/system/fvSchemes.divSchemes"
file: /home/clement/OpenFOAM/clement-2.4.0/run/fan/system/fvSchemes.divSchemes from line 32 to line 39.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 442.
FOAM exiting
Old   July 28, 2015, 13:05
linnemann's Avatar
Niels Nielsen
The blockmesh dict is not needed, just something that followed when copying from another case.
The error is because you need to add div((nuEff*dev(T(grad(Urel))))) under the divSchemes section. Why my case does not complain I do not know.
divSchemes
    default         none;
    div(phi,Urel)   bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(phi,omega)  bounded Gauss upwind;
    div(phi,R)      bounded Gauss upwind;
    div(R)          Gauss linear;
    div(phi,nuTilda) bounded Gauss upwind;
    div((nuEff*dev2(T(grad(Urel))))) Gauss linear;
    div((nuEff*dev(T(grad(Urel))))) Gauss linear;
as for the other options in fvSchems.
1. Search the forum
2. Search Google
3. Search the OpenFOAM git page
3. Read Hrvoje Jasak's PhD thesis section 3 and 4
4. Read "Computational Methods for Fluid Dynamics by Joel H. Ferziger and Milovan Peric"
5. Read the Fluent Manual
for example searching the OpenFOAM github for cellMDLimited gives me this in the header file.
Description
    cellMDLimitedGrad gradient scheme applied to a runTime selected base
    gradient scheme.
    The scalar limiter based on limiting the extrapolated face values
    between the maximum and minimum cell and cell neighbour values and is
    applied to the gradient in each face direction separately.
If you want to know which solvers and schemes are avaliable just write a garbage name and run the case the OpenFOAM will spit out the available options for you.
gradSchemes
    default         Gauss linear;
    grad(Urel)      WHAY Gauss linear 1;
    grad(U)         cellMDLimited Gauss linear 1;
Unknown grad scheme WHAY
Valid grad schemes are :
9
Gauss
cellLimited
cellMDLimited
edgeCellsLeastSquares
faceLimited
faceMDLimited
fourth
leastSquares
pointCellsLeastSquares
Unfortunately there are no "all about openfoam" written anywhere. There are bits and pieces everywhere. The good thing is that all the source code is available so if you can read C++ you can deduce whats going on.
The settings I use is what I have found is ok settings for an unstructured mesh.
Linnemann
Old   July 28, 2015, 14:10
Clement Mtrl
Hi Linnemann,
I finally understood why I didn't work and I learn everyday
I change my mesh (skewness and ortho is ok) and try this case :
Link to drive
The case / The mesh / First results 50 and 100
In fact, for the moment I was using virtualbox but now for computing it slows so much that I'm going to install Linux on dualboot.
I tried to search but I'm not sure about the information I've found so maybe you can help me:
Where can I change between first order and second order of discretization ?
How can I really control how may wall function works ?
Why do we initialize omege and epsilon if we chosse the k-omega model ?
I understood your point of writing and see the help but after I need to see which every schemes means (I don't know all in your example). But for sure I start looking this way too.
Otherwise, if you have any comments on my case you are welcome. In fact, even if I hace a good knowledge in fluid mechanics and quite good in CFD, I'm still junior
Once again, thanks for your help.
Clement
ansys, foam, frame, rotating, srfsimplefoam
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
