Interpolation between faces and points of a polyPatch
Like Tree2Likes
  • 2 Post By hjasak
Old   May 2, 2005, 14:49
Default Hello, for the calculation
Markus Hartinger
hartinger is on a distinguished road
for the calculation of the movement of some boundary points I am doing some calulations on a polyPatch, and I would like to store that data(scalar) somewhere.
I guess, a "surfaceScalarField" would be appropriate, although I only need to store the data for that patch. A "surfaceScalarField" stores the data at the face centres, right?
From there I'd like to interplate those values to the points of the boundary and store that data as well. What is the class to use to store data in boundary points? And how do I do the interpolation, if it's already implemented?
Thank you
markus
hartinger is offline   Reply With Quote
Old   May 2, 2005, 16:36
Default If you are storing data for a
henry is on a distinguished road
If you are storing data for a single patch and are not concerned about the patch field type fvPatchField should be used for face-centre data and pointPatchField for vertex data. Both are templated on the type but there are also convenient typedefs for the common types e.g. fvPatchScalarField and pointPatchScalarField.
henry is offline   Reply With Quote
Old   May 3, 2005, 07:55
Default If I am using a fvPatchScalarF
Markus Hartinger
If I am using a fvPatchScalarField it would be constructed with a fvPatch and an internal Field. Where do I get the internal Field from and why does it need one anyways?
thanks
markus
Old   May 3, 2005, 08:00
Default A patch field needs an interna
A patch field needs an internal field from which to evaluate the boundary condition. If you do not have a corresponding internal field then you probably should be using scalarField rather than fvPatchScalarField to store your patch data.
Old   May 3, 2005, 08:37
Default Ah, I don't have an correspond
Markus Hartinger
Ah, I don't have an corresponding internal field, then I'll use a scalarField for the face centered values.
I could use another scalarField for the corresponding point values and do the interpolation myself. But I would obviously prefer an existing solution for the interpolation. Is there something?
thanks
markus
Old   May 3, 2005, 08:41
Default All done for you and ready to
Hrvoje Jasak
All done for you and ready to use - isn't FOAM wonderful! :-)
Make an object of type primitivePatchInterpolation (or templated PrimitivePatchInterpolation). The functions are in:
~/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/PrimitivePatchInterpolation.H
and you've got:
//- Interpolate from faces to points
template<class>
tmp<field<type> > faceToPointInterpolate
const Field<type>& ff
) const;
//- Interpolate from points to faces
template<class>
tmp<field<type> > pointToFaceInterpolate
const Field<type>& pf
) const;
//- Interpolate from faces to edges
template<class>
tmp<field<type> > faceToEdgeInterpolate
) const;
Enjoy (in enery sense of the word!),
Hrv
Hrvoje Jasak
Old   May 3, 2005, 09:24
Default I'll try that thank you mark
Markus Hartinger
I'll try that
thank you
markus
Old   January 27, 2015, 05:33
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
template<class>
) const;
Hello Jasak,
just one question. Is there some publication of how to interpolate from faces to points? Otherwise I will check it out in the source code but a reference would be very nice.
Kind regards
Tobi
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   January 27, 2015, 17:55
Tobi's Avatar
Tobias Holzmann
Hello all, I figured it out myself from the source code
Keep foaming,
Tobias Holzmann
Old   March 3, 2016, 16:01
Chrisi1984 is on a distinguished road
can you please explain how to do the interpolation?
Kind regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   March 3, 2016, 16:35
Tobi's Avatar
Tobias Holzmann
Yes, o can publish it in monday
Keep foaming,
Tobias Holzmann
Old   March 6, 2016, 10:24
Oh that's nice!
So my idea is to write a utility that interpolates a volScalarField to the patches (bc: zeroGradient) writing out the node values on every patch.
Kind regards
Chrisi
Old   March 7, 2016, 13:08
Tobi's Avatar
Tobias Holzmann
Hi Chris and all other,
here you find the face-to-point interpolation that is used by OpenFOAM: http://holzmann-cfd.de/index.php/en/publications
Keep foaming,
Tobias Holzmann
Field interpolation in mesh points code jzlam OpenFOAM Post-Processing 2 December 14, 2010 16:48
interpolation on faces and wall boundaries ca Main CFD Forum 0 September 2, 2008 12:42
[Technical] Mapping cell faces to other cell faces doug OpenFOAM Meshing & Mesh Conversion 5 March 30, 2007 02:43
Mesh to points cells faces and boundaries files billy OpenFOAM Pre-Processing 19 April 18, 2006 15:38
Mesh hard points on faces Ashton Peters FLUENT 4 March 15, 2005 15:43
