October 31, 2015, 12:45 |
ERROR:Cannot find patchField entry for
Filippo
Rep Power: 10 |
I have to simulate an energy transmition from CO2 to air in a tube....
I took the multiRegionHeaterRadiation tutorial and edited it, importing a mesh from gambit with "fluent3DMeshToFoam -scale 0.001 scambiatore.msh"... I have set every initial conditions and split the dominions.... when I try to run it, it gives me this: "--> FOAM FATAL IO ERROR: Cannot find patchField entry for outlet_aria file: /home/cfdbuntu/OpenFOAM/cfdbuntu-2.3.1/run/multiRegionHeaterRadiation/0/aria/k.boundaryField from line 26 to line 41. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209. FOAM exiting" the problem is that outlet_aria is both in the boundary file (polymesh/boundary), both in the "0/aria/k" file......and is written exactly in the same way..... I can't understand why is this happening.... |
Cannot find patchField entry for InletWall | range_rover | OpenFOAM Running, Solving & CFD | 5 | November 18, 2020 21:21 |
The patchField type for wedge | Jerry L.D. Cheng | OpenFOAM | 4 | October 3, 2016 04:12 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
