November 24, 2015, 12:24 |
Problem with rhoSimpleFoam
Fei
Rep Power: 10 |
Hi all, i am trying to solve a problem with rhoSimpleFoam, but it returns the following error, I try to simulate a flow inside a two layer channel, I imported the mesh from fluent.mesh files :
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } No finite volume options present Starting time loop Time = 0.0005 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0495126, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.094261, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0408954, No Iterations 2 smoothSolver: Solving for e, Initial residual = 0.999995, Final residual = 0.0329298, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0499349, No Iterations 15 time step continuity errors : sum local = 1.42277e-05, global = -1.44013e-06, cumulative = -1.44013e-06 rho max/min : 1.27951 1.25857 smoothSolver: Solving for epsilon, Initial residual = 0.22093, Final residual = 0.00844164, No Iterations 2 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.096524, No Iterations 2 ExecutionTime = 11.3 s ClockTime = 11 s Time = 0.001 smoothSolver: Solving for Ux, Initial residual = 0.200468, Final residual = 0.00571057, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.272446, Final residual = 0.00881932, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.266989, Final residual = 0.0178839, No Iterations 4 smoothSolver: Solving for e, Initial residual = 0.512064, Final residual = 0.0490672, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0572567, Final residual = 0.00273825, No Iterations 44 time step continuity errors : sum local = 0.000137462, global = -6.45329e-07, cumulative = -2.08546e-06 rho max/min : 1.29054 1.24481 smoothSolver: Solving for epsilon, Initial residual = 0.964019, Final residual = 0.0622479, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.653927, Final residual = 0.0158093, No Iterations 4 ExecutionTime = 21.13 s ClockTime = 21 s Time = 0.0015 smoothSolver: Solving for Ux, Initial residual = 0.153799, Final residual = 0.00599166, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.1602, Final residual = 0.0075074, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.115999, Final residual = 0.0073149, No Iterations 4 smoothSolver: Solving for e, Initial residual = 0.0281063, Final residual = 0.0023541, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0237124, Final residual = 0.00085322, No Iterations 12 time step continuity errors : sum local = 0.000201021, global = -1.98632e-05, cumulative = -2.19486e-05 rho max/min : 1.30101 1.2308 smoothSolver: Solving for epsilon, Initial residual = 0.923677, Final residual = 0.0609995, No Iterations 2 bounding epsilon, min: -0.65455 max: 459443 average: 1904.96 smoothSolver: Solving for k, Initial residual = 0.497815, Final residual = 0.0125684, No Iterations 4 ExecutionTime = 26.62 s ClockTime = 26 s Time = 0.002 smoothSolver: Solving for Ux, Initial residual = 0.250991, Final residual = 0.006755, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.277747, Final residual = 0.00742504, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.173037, Final residual = 0.00478922, No Iterations 4 smoothSolver: Solving for e, Initial residual = 0.133343, Final residual = 0.01046, No Iterations 1 GAMG: Solving for p, Initial residual = 0.002813, Final residual = 0.000137325, No Iterations 12 time step continuity errors : sum local = 0.000168067, global = -6.01628e-05, cumulative = -8.21114e-05 rho max/min : 1.31096 1.21821 smoothSolver: Solving for epsilon, Initial residual = 0.201193, Final residual = 0.0021078, No Iterations 2 bounding epsilon, min: -1.88318 max: 3.87696e+06 average: 18333.5 smoothSolver: Solving for k, Initial residual = 0.366344, Final residual = 0.00802616, No Iterations 4 ExecutionTime = 32.17 s ClockTime = 32 s Time = 0.0025 smoothSolver: Solving for Ux, Initial residual = 0.998187, Final residual = 0.0468286, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.999869, Final residual = 0.0458314, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.99515, Final residual = 0.0472566, No Iterations 4 smoothSolver: Solving for e, Initial residual = 1, Final residual = 0.0616162, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Floating point exception (core dumped) Could any one tell me where is the problem? Last edited by Garfield; November 24, 2015 at 12:32. Reason: code |
November 24, 2015, 12:30 |
fvSchemes
Fei
Rep Power: 10 |
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,e) bounded Gauss linearUpwind grad(e); div(phi,epsilon) bounded Gauss linearUpwind grad(epsilon); div(phi,k) bounded Gauss linearUpwind grad(k); div(phid,p) Gauss linear; div(phi,Ekp) bounded Gauss linearUpwind grad(Ekp); div((phi|interpolate(rho)),p) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; pCorr; } // ************************************************** *********************** // |
November 24, 2015, 12:39 |
Saideep
Rep Power: 12 |
hi,
are you using the standard solver as it is or have you modified your solver? The floating point exception error is related to a calculation where the compiler is trying to divide some variable with 0. But i guess it shouldn't be related to your mesh exporting. Saideep |
November 24, 2015, 12:48 |
Fei
Rep Power: 10 |
Here are the other files
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.05; smoother GaussSeidel; cacheAgglomeration on; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-06; relTol 0.1; } e { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.1; } "(k|epsilon)" { $U; tolerance 1e-07; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; rhoMin rhoMin [ 1 -3 0 0 0 ] 0.5; rhoMax rhoMax [ 1 -3 0 0 0 ] 1.5; residualControl { p 1e-2; U 1e-4; e 1e-3; // possibly check turbulence fields "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 0.3; rho 0.05; } equations { U 0.7; "(k|epsilon)" 0.7; e 0.5; p 0.6; k 0.6; epsilon 0.6; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { HEATED_WALL { type fixedValue; value uniform (0 0 0); } UNHEATED_WALL { type fixedValue; value uniform (0 0 0); } RIB { type fixedValue; value uniform (0 0 0); } INLET { //type fixedValue; //value uniform (0 0 12.65); type flowRateInletVelocity; massFlowRate constant 10; rhoInlet 1.225; // Guess for rho } OUTLET { type inletOutlet; value uniform (0 0 0); inletValue uniform (0 0 -1.21); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 110000; boundaryField { UNHEATED_WALL { type zeroGradient; } HEATED_WALL { type zeroGradient; } RIB { type zeroGradient; } OUTLET { type fixedValue; value uniform 110000; } INLET { type zeroGradient; // refValue uniform 190000; // refGradient uniform 0; // valueFraction uniform 0.3; //type mixed; //refValue uniform 110000; //refGradient uniform 0; //valueFraction uniform 1; //type transonicOutletPressure; //U U; //phi phi; //gamma 1.4; //psi psi; //pInf uniform 110000; } } // ************************************************************************* // |
November 24, 2015, 12:53 |
#5 | |
Fei
Rep Power: 10 |
Yes, I use the standard solver with the modification in the fvSchemes, I changed the original Gauss upwind to the Gauss linearUpwind grad(). Do you know usually what will cause the problem of " dividing 0 "? Thanks again |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
