rhoSimplecFoam: error in Forces output (correct pressure field) |
December 7, 2015, 11:23 |
Rep Power: 10 |
Hi to everybody.
I'm running some simulation on an airplane using both Fluent and OpenFoam 2.3.0 in order to do a comparison. I'm using the compressible solver rhoSimplecFoam and I have found a resolution strategy for OF in order to obtain a convergence: - 100 iterations with energy equation deactivated (through fvOptions) - first order schema until the residual are 1e-4 - second-like order schema This strategy grants me a good accordance in the global pressure and velocity fields. The pressure field on the airplane surfaces also seems to be correct. However the force coefficients, the drag and lift forces are very different in OpenFoam and I don't understand the reason. I attached an image of the force report for Fluent and OpenFoam analysis(I converted the OF results in fluent format using foamMeshToFluent and foamDataToFluent commands). I report the setting used in controlDict, fvSolution and fvSchemes. The boundary I'm using are: p - inlet: totalPressure - outlet: fixedValue U - inlet_ pressureInletVelocity - outlet: pressureInletOutletVelocity T - inlet: totalTemperature - outlet: inletOutletTotalTemperature Turbulence model - the k-omega SST. Has someone some advice in order to fit the forces output? Thanks in advance, [WhiteW ControlDict Code:
application rhoSimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 6000; deltaT 1; writeControl timeStep; writeInterval 200; purgeWrite 0; writeFormat ascii; writePrecision 9; writeCompression off; timeFormat general; timePrecision 9; graphFormat raw; runTimeModifiable true; libs ( "libforces.so" ); functions { forces { type forces; functionObjectLibs ( "libforces.so" ); outputControl timeStep; outputInterval 1; patches ( wall_fuselage wall_nose wall_sponson wall_junction wall_tail wall_wing_nacelle wall_nacelle wall_pianetto_orizzontale1 wall_raccordo_pianetti wall_pianetto_verticale ); pName p; UName U; rhoName rhoInf; log true; rhoInf 1.16; CofR (0.98460 0 0.35195); pitchAxis (0 -1 0); } } Code:
source1 { type temperatureLimitsConstraint; selectionMode all; active true; temperatureLimitsConstraintCoeffs { Tmin 294.18; Tmax 294.19; } } Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(U) Gauss linear; grad(p) Gauss linear; } divSchemes { default bounded Gauss upwind; div(phi,U) bounded Gauss upwind; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } fvSchemes 1st-2nd order Code:
ddtSchemes { default steadyState; } gradSchemes { default cellLimited Gauss linear 1; grad(U) cellMDLimited Gauss linear 1; } divSchemes { default bounded Gauss linearUpwind cellLimited Gauss linear 1; div(phi,U) bounded Gauss linearUpwindV cellMDLimited Gauss linear 1; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } Code:
solvers { p { solver GAMG; tolerance 1e-09; relTol 0.1; smoother GaussSeidel; cacheAgglomeration off; nCellsInCoarsestLevel 800; agglomerator faceAreaPair; mergeLevels 1; maxIter 40; } rho { solver GAMG; tolerance 1e-09; relTol 0.1; smoother GaussSeidel; cacheAgglomeration false; nCellsInCoarsestLevel 800; agglomerator faceAreaPair; mergeLevels 1; maxIter 20; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-09; relTol 0.1; maxIter 40; } h { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0.1; maxIter 20; } k { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-09; relTol 0.1; maxIter 20; } omega { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-09; relTol 0.1; maxIter 20; } e { solver GAMG; tolerance 1e-08; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 800; agglomerator faceAreaPair; mergeLevels 1; } } SIMPLE { nNonOrthogonalCorrectors 4; pMin pMin [1 -1 -2 0 0 0 0] 90000; pMax pMax [1 -1 -2 0 0 0 0] 105000; rhoMin rhoMin [1 -3 0 0 0 0 0] 1.12; //then changed to 1.08 rhoMax rhoMax [1 -3 0 0 0 0 0] 1.20; //then changed to 1.24 residualControl //tutorial { p 1e-4; U 1e-4; e 1e-4; "(k|epsilon|omega)" 1e-3; } } relaxationFactors { p 0.3; rho 0.1; e 0.7; U 0.7; h 0.7; k 0.7; omega 0.7; } |
December 8, 2015, 13:02 |
Rep Power: 10 |
I noticed the output values of forces strongly depends from the initialization of turbulence parameters.
I used k=0 and omega=2, for the internalField. Now, using different values (k=0.027 and omega=2.05) the force output in the first iterations differ of about an order of magnitude(but then the simulation diverges). I also run a checkMesh and this is the log: Code:
* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 4949919 faces: 36290908 internal faces: 35830274 cells: 16487628 faces per cell: 4.37426063 boundary patches: 20 point zones: 0 face zones: 1 cell zones: 3 Overall number of cells of each type: hexahedra: 0 prisms: 6170670 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 10316958 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology wall_fuselage 18346 9448 ok (non-closed singly connected) wall_pilone_lato_aereo2626 1390 ok (non-closed singly connected) wall_nose 21680 11037 ok (non-closed singly connected) wall_sponson 21869 11040 ok (non-closed singly connected) wall_junction 29688 15182 ok (non-closed singly connected) wall_tail 34684 17834 ok (non-closed singly connected) wall_wing_nacelle 82898 41788 ok (non-closed singly connected) wall_nacelle 43241 21880 ok (non-closed singly connected) wall_pianetto_orizzontale140740 20449 ok (non-closed singly connected) wall_raccordo_pianetti7184 3805 ok (non-closed singly connected) wall_pianetto_verticale33317 17231 ok (non-closed singly connected) wall_pil_fisso 6542 3432 ok (non-closed singly connected) inflow 146 90 ok (non-closed singly connected) outflow 148 91 ok (non-closed singly connected) symm_parete 1571 851 ok (non-closed singly connected) symm_floor 615 364 ok (non-closed singly connected) symm_ceiling_interno1550 1155 ok (non-closed singly connected) symm_ceiling_esterno2254 1224 ok (non-closed singly connected) symm_esterno 7978 4224 ok (non-closed singly connected) symm_interno 103557 77227 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-6.95 -3.5 -2.273955) (14.65 3.33069446e-06 2.726045) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-2.05138739e-18 -7.24646001e-16 1.31380308e-16) OK. ***High aspect ratio cells found, Max aspect ratio: 4925.81694, number of cells 1586 <<Writing 1586 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 4.70543557e-10. Maximum face area = 0.32125922. Face area magnitudes OK. Min volume = 8.94286652e-14. Max volume = 0.0550260094. Total volume = 345.427077. Cell volumes OK. Mesh non-orthogonality Max: 78.9019986 average: 12.3286271 *Number of severely non-orthogonal (> 70 degrees) faces: 69. Non-orthogonality check OK. <<Writing 69 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 14.8103056, 4889 highly skew faces detected which may impair the quality of the results <<Writing 4889 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 2 mesh checks. End Thanks, WhiteW |
How to get the velocity field from the pressure field | Hermano | Main CFD Forum | 2 | November 29, 2011 08:32 |
Calculate forces without hydrostatic pressure | geir_oye | FLUENT | 4 | November 12, 2009 09:12 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
