December 24, 2015, 07:37 |
Courant number explodes
Evangelos
Hello Foamers!
i am trying to simulate the bifurcation that is depicted in the bifurcation.png file. There is one inlet in the right of the geometry and three outlets at the right. I use icoFoam to solve the flow problem. the deltaT is 1e-4. The courant number at first is very small but is increased with a small step after each iteration. After 10000 iterations the courant number is getting too big so the simulation stops. The mesh is ok after checkMesh. I calculate the Dp in order to have the desired mean velocity in the pipe before the bifurcation and then i divide with density. 0/p File object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform 0.012957446; } outlet_internal { type fixedValue; value uniform 0; } outlet_externalbig { type fixedValue; value uniform 0; } outlet_externalsmall { type fixedValue; value uniform 0; } walls { type zeroGradient; } } 0/U File object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type pressureInletVelocity; value uniform (0 0 0); } outlet_internal { type zeroGradient; } outlet_externalbig { type zeroGradient; } outlet_externalsmall { type zeroGradient; } walls { type fixedValue; value uniform (0 0 0); } } transportproperties transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 0.000002057; Can anyone help me to solve the problem ? I stuck over 15 days |
December 24, 2015, 10:49 |
Akshay Kumar
Hey
Why are you running a transient simulation for this case? |
December 24, 2015, 13:33 |
Evangelos
I know that Poiseuille flow is treated as steady state.
But i have developed a code based on transient solver and i need to evaluate the results of my case with experimental data |
December 25, 2015, 04:06 |
Akshay Kumar
Ahh okay. Did you try running adjustable time stepping? Also, try pimplefoam solver : use higher outerCorrectors and relax the solution
December 25, 2015, 22:36 |
Alberto Passalacqua
Rep Power: 36 |
If you know the desired velocity at the inlet, just impose that, rather than the pressure at the inlet (it seems you use that to find the pressure drop?).
Also, as a suggestion, I would not recommend icoFoam. You could use pimpleFoam, and have better control on the solution process (outer correctors, adaptive time-step, under-relaxation, ...).
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
Newbie Question IcoFoam - Courant Number explodes | sprobst76 | OpenFOAM Running, Solving & CFD | 12 | March 1, 2018 07:35 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
