finding the wetted surface of a floating body
Old   January 21, 2016, 22:03
Default finding the wetted surface of a floating body
ashkan is on a distinguished road
Hi All,
I have a floating body in waves modelled in sixDoFRigidBodyMotion solver. I would like to calculate the excursion of the body with respect to free-surface at each time-step. This is different than the heave (vertical) displacement of the body.
I was wondering how this can be done in OpenFoam? Do I need to calculate it from the volume fraction value and how to do this at each time-step in sixDoFRigidBodyMotion solver.
I really appreciate any advice and help.
Regards
Ashkan
ashkan is offline   Reply With Quote
Old   January 22, 2016, 02:15
akidess's Avatar
Anton Kidess
I'm guessing the surface of the body is in a separate patch. Then patchIntegrate of the volume fraction (alpha) should do the trick?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   January 23, 2016, 21:25
Hi Anton,
Many thanks for your comment and suggestion. I looked into patchIntegrate solver in OpenFoam. It seems that I need to pass the mesh, alpha1 and my patch and it calculate the surface integral over that patch. Can you please explain a bit more on how this can be done in sixDoFRigidBodyMotionSolver?
If I understood this should return the submerged surface area and not the volume? How to calculate the submerged volume then?
Many thanks again
Ashkan
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
pressure sensor on a floating body ashkan OpenFOAM Running, Solving & CFD 2 March 9, 2015 04:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Algorithm for finding surface normals Deevyendu Main CFD Forum 1 July 2, 2010 20:34
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
