[swak4Foam] Using groovyBC in OF 2.3.1
Old   February 8, 2016, 02:02
Default Using groovyBC in OF 2.3.1
Andeo
Anirudh_Deodhar is on a distinguished road
Hi
I have a domain with multiple inlets and outlets. I need to calculate the average temperature at an outlet and patch that as inlet temperature of another inlet (at every time step). I tried using groovy BC for that. but it seems groovy BC doesnt work with OF v2.3.1.
I have added following to my controlDict -
libs ("libOpenFOAM.so" "libgroovyBC.so"
"libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so"
"libswakTopoSources.so" ) ;
functions
Temp_IN
//type patchAverage;
type surfaces;
verbose false;
fields (T);
patches
OUTLET1
after 298;
And then made following change to T -
INLET1
type groovyBC;
valueExpression "InTemp";
variables "InTemp{OUTLET1}=average(T)+ 25.00000 ;";
value uniform 298;
I am getting an error like this -
--> FOAM FATAL IO ERROR:
Unknown patchField type groovyBC for patch type wall
Does groovyBC work with OF v 2.3.1? Or is there anything else that I have to use for my problem? Do I need to install any additional package to make this groovyBC work?
Thanks in advance!
Anirudh_Deodhar is offline   Reply With Quote
Old   February 8, 2016, 08:19
mnikku is on a distinguished road
Originally Posted by Anirudh_Deodhar View Post
Hi
Have you compiled just the groovyBC (I guess that is also possible) or are you using it from swak4foam? Atleast with swak4foam I have managed to use it with 2.3.1.
mnikku is offline   Reply With Quote
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
OpenFOAM Foundation releases OpenFOAMŪ 2.3.1 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 4 February 8, 2015 05:19
