Coupling patches in chtMultiRegionSimpleFoam
Like Tree13Likes
  • 2 Post By Nkl
  • 1 Post By flanel1988
  • 1 Post By Antimony
  • 9 Post By Bloerb
Old   May 27, 2016, 13:23
Default Coupling patches in chtMultiRegionSimpleFoam
Nkl
Nikola
Nkl is on a distinguished road
Hello to everyone!
I am running a case with chtMultiRegionSimpleFoam in which i have 4 different regions: 3 are solid and 1 is fluid.
I've created a mesh for each region separately - each region has its own polyMesh - and generated the meshes by means of blockMesh -region.
I've assigned a compressible::turbulentHeatFluxTemperature boundary condition on the external wall of a solid region - which is a boundary patch - and now i am wandering what should i assign to the internal wall of the same region and to the corresponding patch of the fluid region (the 2 patches that sould be coupled).
I see that i cannot use compressible::turbulentTemperatureCoupledBaffleMix ed since it requires mapping - i went through the planeWall2D tutorial, but as i said i generated 4 different meshes instead of mapping one.
What should i assign to the fluid/solid patches in the 0/T file?
Thanks in advance!
sadjad.s and shohifafitriana like this.
Nkl is offline   Reply With Quote
Old   May 31, 2016, 05:59
Nkl
Nikola
No one can help?
Old   May 31, 2016, 09:06
flanel
flanel1988 is on a distinguished road
Hey! First of all: What OF-Version do you use? I had similar problems in the past, but then I detected gmsh and I created one big mesh with all regions. I assigned all relevant patches to physical surfaces; except for the boundary patches. If you assign physical volumes, in OF with
splitMeshRegions -cellZones -overwrite
the program detects the boundaries by itself and adds patches like solid1_to_solid2 or something like that.
Vishsel likes this.
flanel1988 is offline   Reply With Quote
Old   May 31, 2016, 09:11
Nkl
Nikola
Hi! I use the 3.0.1 version.
I know there is that possibility, but since i already modelled the different regions i wanted to figure out if there is a possibility of coupling the patches in another way.
Old   May 31, 2016, 10:43
flanel
But i do not understand, why you cannot use
Old   May 31, 2016, 10:48
Nkl
Nikola
I've tried to apply that patch to both the solid and fluid region as in the planeWall2D case, but i receive the following error:
--> FOAM FATAL ERROR:
    patch type 'wall' not type 'mappedPatchBase'
Old   May 31, 2016, 11:09
Antimony is on a distinguished road
This error means that in the boundary file under constant/polyMesh, the highlighted patch has been specified as 'wall', while the compressible::turbulentTemperatureBaffleMixed is only available (again from the error message) if the type is 'mappedPatchBase'.
So change the type to 'mappedPatchBase' in the boundary file and at the very least, this error message will be removed.
Hope this helps.
Cheers,
Antimony
granzer likes this.
Antimony is offline   Reply With Quote
Old   May 31, 2016, 11:25
Nkl
Nikola
Hello and thanks for the suggestion. Unfortunately it is the first thing i did but then i receive the following error:
    patch type 'genericPatch' not type 'mappedPatchBase'
    for patch walls of field T in file "/home/nikola/OpenFOAM/nikola-3.0.1/PhD/receiverMultiRegion4/0/moltenSalt/T"
I supposed that i cannot use compressible::turbulentTemperatureCoupledBaffleMix ed when different regions have a separate mesh. Any suggestions about this error?
Old   June 1, 2016, 03:30
flanel
Do you have different Meshes in your constant/ folder? So chance the "mapped" in the constant/meshXX/boundary to "mappedWall". This has to be done for all meshes involved!
Old   June 8, 2016, 06:48
Nkl
Nikola
Sorry for the late answer.
I tried to change to mappedWall in the various constant/regionX/polyMesh/boundary files, but now I receive the following error:
--> FOAM FATAL IO ERROR:
keyword sampleMode is undefined in dictionary ".walls"
file: .walls from line 34 to line 37.
Should I map the fields using the mapFields utility?
Old   June 21, 2016, 11:42
Nkl
Nikola
Some one can help please?
Old   July 12, 2016, 03:50
Default Same issue
  #12
Sing
Struggle_Achieve is on a distinguished road
Hello Nikola,
I also created a very complex geometry of a ladle which is used in Steel operations.
I already made different regions using blockMesh. Then I saw the plane2D wall case example for chtMultiRegionSimpleFoam. Then I tried to modify my mesh files so the format matches with the example. But when I run this case I too get the same error:
in the T file for the mappedWall zone1_to_zone2. I used
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
kappa fluidThermo;
kappaName none;
value uniform 1873;
for the same.
I am clueless. One possible solution I can think is to recreate the whole geometry using snappyhex and let splitMeshRegions -cellZones -owerwrite define all the boundaries between the different regions. ie (zone0_to_zone1, etc)
Any help would be greatly appreciated!
Thanks and regards,
Singh.
Struggle_Achieve is offline   Reply With Quote
Old   July 15, 2016, 14:47
Bloerb will become famous soon enough
The answer has already been given. Change your patch type in all constant/meshXX/boundary files from wall to mappedWall.
As for Nkl issue. Here is an example from the tutorials:
bottomAir_to_leftSolid
    type            mappedWall;
    nFaces          130;
    startFace       4680;
    sampleMode      nearestPatchFace;
    sampleRegion    leftSolid;
    samplePatch     leftSolid_to_bottomAir;
You have to set this accordingly. The sample region is the neighbour region and the samplePatch the neighboring patch to this one. You need to add these lines since you meshed with different meshes instead of splitting one mesh into different domains. The splitmeshregions command automatically adds these lines. For many industrial applications meshing your domains separately is of course more convenient.
Bloerb is offline   Reply With Quote
Old   July 19, 2016, 02:24
Default Problem still persists
  #14
Sing
    type            mappedWall;
    nFaces          130;
    startFace       4680;
Hello Bloerb,
First of all my gratitude for your answer.
Yes I have already modified the wall type to mappedWall; I have tried a number of things here but still same error appears.
I have used a format like this for all the boundaries:
domain1_to_domain0
        type            mappedwall;
        inGroups        1(wall);
        nFaces          4000;
        startFace       236000;
        sampleRegion    domain0;
        samplePatch     domain0_to_domain1;
I am certainly new to openFOAM and I guess I must be wrong somewhere.
I would be very grateful if you may please point that out.
I have also posted the whole problem, it might be useful to understand the whole case.
Please take a look:
http://www.cfd-online.com/Forums/ope...blockmesh.html
My deepest thanks and regards,
Prateek Singh.
Old   November 9, 2020, 05:37
Bineet Mehra
bineet_aero is on a distinguished road
    type            mappedWall;
    nFaces          130;
    startFace       4680;
Thanks a lot. Will it be possible to use the Y+utility to find yplus values for solid walls in contact with fluid in conjugate heat transfer problems (for the mappedWalls) ?for example chtMultiRegionSimpleFoam cases etc ?
thanks
bineet_aero is offline   Reply With Quote
Old   November 9, 2020, 06:14
Bineet Mehra
Originally Posted by Nkl View Post
Hello to everyone!
Thanks in advance!
Hii thanks a lot. How did you create mesh for each region separately ? blockMesh region solid1 something like this ?
thanks
Old   November 2, 2021, 08:43
Lorenzo
JesusJoker is on a distinguished road
mappedWall;
JesusJoker is offline   Reply With Quote
Old   May 19, 2023, 09:23
Adrian
Henrinavier is on a distinguished road
First of all: Super helpful thread and thanks to those responding! However, I have a follow-up question:
Is it possible to map patch a from region A to multiple patches 1, 2, 3 in region B or do I have to always create perfectly matching patches in both regions?
Best, Henrinavier
Henrinavier is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
[blockMesh] Merging edge patches Yosmcer OpenFOAM Meshing & Mesh Conversion 11 November 16, 2014 14:51
[swak4Foam] groovyBC for coupling of patches deniggo OpenFOAM Community Contributions 20 October 2, 2014 18:04
