[swak4Foam] error: undefined symbol: _ZTIN4Foam22timelineFunctionObjectE
Old   June 1, 2016, 04:08
Default error: undefined symbol: _ZTIN4Foam22timelineFunctionObjectE
Gorg
gorg88 is on a distinguished road
Hi!
I have created an own simpleFunctionObjects library (mylibsimplefunctionObjects.so) from swak4foam file. I compiled without problems but it is appear this error when I try to use a function object into a controlDict from mylibsimplefunctionObjecs.so library.
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : /home/jgaray/OpenFOAM/jgaray-2.4.0/platforms/linux64GccDPOpt/lib/mylibsimpleFunctionObjects.so: undefined symbol: _ZTIN4Foam22timelineFunctionObjectE
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "mylibsimpleFunctionObjects.so"
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
label "Standard high-Re k-\u03B5";
fieldMaps
k kCompressible;
epsilon epsilonCompressible;
mut mut;
alphat alphatCompressible;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0.85;
alphah 1.111;
alphak 1;
alphaEps 0.76923;
sigmak 1;
sigmaEps 1.3;
Prt 1;
Calculating field g.h
Reading field p_rgh
Creating finite volume options from "system/fvOptions"
Radiation model not active: radiationProperties not found
Selecting radiationModel none
SIMPLE: convergence criteria
field U tolerance 1e-05
field k tolerance 1e-05
field epsilon tolerance 1e-05
field omega tolerance 1e-05
field nuTilda tolerance 1e-05
field T tolerance 1e-05
field p_rgh tolerance 1e-05
field p tolerance 1e-05
Starting time loop
--> FOAM FATAL ERROR:
Unknown function type patchAverage
Valid functions are :
9
initSwakFunctionObject
partialWrite
patchProbes
probes
removeRegisteredObject
sets
surfaces
writeDictionary
writeRegisteredObject
From function functionObject::New(const word& name, const Time&, const dictionary&)
in file db/functionObjects/functionObject/functionObject.C at line 92.
FOAM exiting
I attach make/options file where all the necessary libraries are included
include $(OBJECTS_DIR)/../../rules/versionOptions
ifdef FOAM_DEV
ADDITIONALFILES_INC=-I../filesThatAreOnlyInSomeDistributions
SIMPLEFUNCTIONFILES=-I../../swak4Foam/Libraries
endif
LIB=$(FOAM_USER_LIBBIN)/mylibsimpleFunctionObjects
EXE_INC = \
    $(FOAM_DEV_OPTION) \
    -I/swak4FoamParsers/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/triSurface/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/SLGThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/solidMixtureProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/liquidMixtureProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/solidProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/liquidProperties/lnInclude \
    -I$(LIB_SRC)/regionModels/regionModel/lnInclude \
    -I$(LIB_SRC)/regionModels/surfaceFilmModels/lnInclude \
    -I$(LIB_SRC)/turbulenceModels \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/lagrangian/basic/lnInclude \
    $(ADDITIONALFILES_INC)
LIB_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -lsampling \
    -ltriSurface \
    $(FLUIDTHERMO_LIB) \
    -lincompressibleTransportModels \
    -lcompressibleTurbulenceModel \
    -lincompressibleTurbulenceModel \
    -lspecie \
    -llagrangian
Thanks
gorg88 is offline   Reply With Quote
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
