November 17, 2012, 12:47 |
PotentialFOam
EMAVI V SURYA SAMPATH
Rep Power: 14 |
Im continuously getting this error when Im running potentialFOam
continuity error = 9.077995892e-08 Interpolated U error = 1.798108527e-05 --> FOAM FATAL ERROR: No valid model for viscous stress calculation. From function forces::devRhoReff() in file forces/forces.C at line 113. FOAM exiting its running, but in the last Im getting this . What does this mean? and wil this affect simpleFOAM? |
June 20, 2016, 16:04 |
Rep Power: 10 |
Hi
I have this error too,can anybody help me? It's about adding forces code in controldict. "--> FOAM FATAL ERROR: No valid model for viscous stress calculation." thanks masoud |
June 21, 2016, 04:30 |
Alex
Rep Power: 12 |
That is actually not a problem. It is because potentialFoam cannot calculate the forces calculated in the controlDict functions. You can either ignore the message or simply run potentialFoam the following way.
potentialFoam -noFunctionObjects Alex |
June 21, 2016, 07:16 |
Rep Power: 10 |
Hello Alex
thanks by your answer. I use "-noFunctionObjects" but this command overrides the function added in controldict,and I don't want to do that. I want to calculate forces and forces coefficeint SO I added some commands in controldict. Can you help me? Best Regards Masoud |
June 21, 2016, 08:41 |
Matthew Shorter
Rep Power: 10 |
Hello. PotentialFoam solves the inviscid incompressible equations and gives you what is effectively the analytical solution. According to the D'Alembert paradox, the drag on any object in the potential flow field will be 0. The lift may be non zero, but I don't think controlDict is the way to find that- look into using paraView or something other postprocessing tool for that.
June 21, 2016, 10:32 |
Rep Power: 10 |
Hello Matthew
thanks for your reply I use twophaseEulerfoam and I have this error too. "--> FOAM FATAL ERROR: No valid model for viscous stress calculation." |
potentialfoam |
How to run potentialFoam and simpleFoam together . | vmsandip2011 | OpenFOAM Running, Solving & CFD | 11 | April 2, 2021 10:56 |
Initialization with potentialFoam | Sune | OpenFOAM Running, Solving & CFD | 6 | March 2, 2016 12:18 |
Using potentialFoam with simpleBuoyantFoam | lasb | OpenFOAM Running, Solving & CFD | 5 | August 28, 2015 12:32 |
simple geometry and potentialFoam? | Tobi | OpenFOAM | 0 | June 21, 2012 16:39 |
potentialFoam error | djstoneage | OpenFOAM | 2 | November 9, 2011 18:40 |
