chtMultiRegionSimpleFoam vs. chtMultiRegionFoam |
September 14, 2016, 06:34 |
Rep Power: 11 |
Can anybody advise mi with the following problem connected to the chtMultiRegionSimpleFoam?
I run chtMultiRegionSimpleFoam with turbulence model but the simulation fails after 3 iterations even when I set the inlet temperature to zero and there is no temperature gradient (all temperature BC have the same temperature). When the model is laminar the convergence is without any problem. When I run the same model with chtMultiRegionFoam the convergence is also without any problem. Has anybody some experiences with this problem? The mesh quality is I think OK Mesh stats points: 1324068 faces: 3857346 internal faces: 3742722 cells: 1266678 faces per cell: 6 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 2 Overall number of cells of each type: hexahedra: 1266678 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology outlet 132 165 ok (non-closed singly connected) inlet 270 327 ok (non-closed singly connected) wall 30426 30864 ok (non-closed singly connected) lava 7284 7638 ok (non-closed singly connected) solid_side1 30312 30750 ok (non-closed singly connected) solid_side2 46200 46644 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.155 -0.155 -7.06635e-010) (0.155 0.155 0.15) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (2.39061e-016 4.07968e-016 -3.65159e-015) OK. Max cell openness = 3.82736e-016 OK. Max aspect ratio = 6.07907 OK. Minimum face area = 2.41553e-007. Maximum face area = 1.58724e-005. Face area magnitudes OK. Min volume = 1.91764e-010. Max volume = 2.56454e-008. Total volume = 0.00975473. Cell volumes OK. Mesh non-orthogonality Max: 54.607 average: 5.3253 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.29129 OK. Coupled point location match (average 0) OK. Mesh OK. End |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 06:34 |
Error in chtMultiRegionFoam | kirankarki | OpenFOAM | 6 | August 21, 2018 08:00 |
Simulation of a sample in a furnace w/ chtMultiRegionFoam | sergimart7 | OpenFOAM Running, Solving & CFD | 7 | August 12, 2015 06:48 |
What does this error when use solver chtMultiRegionFoam mean | sajad6 | OpenFOAM Running, Solving & CFD | 7 | October 6, 2014 07:38 |
FOAM FATAL IO ERROR for chtMultiRegionFoam | xiaoyoyo | OpenFOAM Running, Solving & CFD | 0 | May 8, 2012 16:49 |
