"wrong token type - expected Scalar, found on line - the punctuation token '('" |
September 16, 2016, 05:58 |
#1 | |
JIN WEIGUO
Rep Power: 9 |
Hi Tobi, Thanks for your reply, I saw your comment on other people's openfoam video on youtube. Could you help me check with my error as shown below? Is it naming problem in 'pressure' file? markjin@markjin-VirtualBox:~/OpenFOAM/markjin-4.0/run/Case2$ icoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0-665f1db4c1f1 Exec : icoFoam Date : Sep 16 2016 Time : 19:35:06 Host : "markjin-VirtualBox" PID : 4880 Case : /home/markjin/OpenFOAM/markjin-4.0/run/Case2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PISO: Operating solver in PISO mode Reading transportProperties Reading field p --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 19 the punctuation token '(' file: /home/markjin/OpenFOAM/markjin-4.0/run/Case2/0/p.internalField at line 19. From function Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::doubleScalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting |
September 16, 2016, 06:01 |
Tobias Holzmann
Rep Power: 51 |
I will report your last replay to be wrong in that thread. The admin will make a new thread then. Please keep clearance in that forum. The question you have is not related to the thread and therefore I will not replay in detail but the error tells you that you did something wrong in the p file. Finally, it is always necessary to ask yourself, if the question you asked has enough information. Here, it would be good to have you p file, that we can check and tell you what you did wrong. One hint more. The forum offers code tags. Please use it for formating your text.
Keep foaming, Tobias Holzmann |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Error during initialization of "rhoSimpleFoam" | kornickel | OpenFOAM Running, Solving & CFD | 8 | September 17, 2013 05:37 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
