Changing alpha phase on inlet for interMixingFoam
Old   September 26, 2016, 09:34
Question Changing alpha phase on inlet for interMixingFoam
ilya turov
turik is on a distinguished road
Hello, I'm using interMixingFoam with 3 phases: air, water and other. I have a single inlet and I want to change a liquid passing through it mid simulation.
For example, seconds 0-3 for alpha.water it will be
type            inletOutlet;
inletValue      uniform 1;
value           uniform 1;
and for alpha.other
type            inletOutlet;
inletValue      uniform 0;
value           uniform 0;
and after 3rd second vice versa.
I've tried different approaches, but to no avail, so the question is, have I overlooked any of OpenFOAM functionality or should I start straight digging into Groovy BC?
Thanks in advance, Ilya.
turik is offline   Reply With Quote
Old   February 25, 2020, 05:32
Herman Bordal
Bordal is on a distinguished road
I am trying to do something fairly similar, did you ever figure out a way to do this?
Cheers
Bordal is offline   Reply With Quote
inhomogeneous XiFoam, problems with "ft" phase inlet roby OpenFOAM Running, Solving & CFD 6 June 9, 2023 10:39
how to set secondary phase for an inlet? alikiani Fluent Multiphase 1 January 20, 2014 01:24
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
phase changing simulation David Liu Main CFD Forum 3 October 25, 2004 01:43
Changing inlet mass fractions of CH4 and O2 Prateep Chatterjee FLUENT 4 June 13, 2002 12:06
