March 29, 2017, 03:52 |
keyword Phi is undefined in dictionary
Chrismar Punzal
Rep Power: 9 |
Hi.
I am running a pipe flow simulation in Simflow and this is my first time. and since it uses Openfoam, I thought that someone who is using OpenFoam can help me with my problem. When I start running my simulation, it ends unsuccessful. The problem has to do with this "keyword Phi is undefined in dictionary fvsolver". I checked the file fvsolver, changed some values there but to no avail. How do I proceed? How do I solve this problem? Thank you. |
March 29, 2017, 03:57 |
Agustín Villa
Rep Power: 15 |
could you post your fvSolution file? The problem is inside of it, but more information is needed to help you |
March 29, 2017, 04:02 |
Chrismar Punzal
Rep Power: 9 |
Thanks Agustinvo for the reply.
Here it is. FoamFile { version 2.0; class dictionary; format ascii; location "system"; object fvSolution; } solvers { p { smoother GaussSeidel; relTol 0.1; cacheAgglomeration true; maxIter 100; nPreSweeps 0; nPostSweeps 1; nFinalSweeps 0; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; tolerance 1.0E-6; mergeLevels 1; solver GAMG; } U { relTol 0.1; preconditioner DILU; tolerance 1.0E-6; maxIter 100; solver PBiCG; } } SIMPLE { nNonOrthogonalCorrectors 1; pRefPoint (0.0 0.0 0.0); pRefValue 10.0; residualControl { p 1.0E-4; U 1.0E-4; } } relaxationFactors { p 0.3; U 0.7; } potentialFlow { nNonOrthogonalCorrectors 10; pRefPoint (0.0 0.0 0.0); pRefValue 10.0; } |
March 29, 2017, 04:33 |
Chrismar Punzal
Rep Power: 9 |
By the way Agustin, I am using the simplefoam for my simulation. I am simulating a flow through a pipe that is connected to a tank. The flow of water out of the tank is also through a pipe that is connected to it.
March 31, 2017, 02:38 |
Chrismar Punzal
Rep Power: 9 |
Thanks Sana for the reply. I changed the file, however the problem persists. It is interesting to note that after I change the file and run the Simflow, the fvsolution reverts back to its previous contents, ie, without the
phi { $p; }. Did I do it correctly when I added the text you mentioned inside solvers? |
March 31, 2017, 02:41 |
Sana Ullah
Rep Power: 11 |
In that case....please confirm that file is not replaced during the run....Looks like when you run your simulation...it copies fvsolution file from some other location and replaces the existing file...
Sent from my LG-F600L using CFD Online Forum mobile app
Mehar, Phd Scholar KAIST, Korea |
March 31, 2017, 02:55 |
Chrismar Punzal
Rep Power: 9 |
Thanks Sana.
I think the file is replaced (the File's time modified changes and coincides with the time of the simulation, not the time of editing) since the changes are not there anymore after I run the simulation. |
March 31, 2017, 03:04 |
#10 |
Chrismar Punzal
Rep Power: 9 |
What do I need to check for in my run script so that the file is not replaced?
March 31, 2017, 03:13 |
#12 |
Chrismar Punzal
Rep Power: 9 |
Thanks Sana for the help. I am running it through Simflow, by the way.
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows port by SIMFLOW Technologies *\ \*---------------------------------------------------------------------------*/ Build : 3.0+-949e02381429 Exec : C:/Program Files/simFlow/engine-3.0+/bin/potentialFoam -noFunctionObjects -writep Date : Mar 31 2017 Time : 15:03:18 Host : "DESKTOP-165GQND" PID : 5792 Case : C:/Users/TRANS-ASIA/Desktop/4/4 nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 potentialFlow: Operating solver in PISO mode Reading velocity field U Constructing pressure field p Constructing velocity potential field Phi Creating MRF zone list from MRFProperties Calculating potential flow --> FOAM FATAL IO ERROR: keyword Phi is undefined in dictionary "C:/Users/TRANS-ASIA/Desktop/4/4/system/fvSolution.solvers" file: C:/Users/TRANS-ASIA/Desktop/4/4/system/fvSolution.solvers from line 13 to line 55. From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const in file db/dictionary/dictionary.C at line 640. FOAM exiting |
March 31, 2017, 03:33 |
#13 |
Sana Ullah
Rep Power: 11 |
I never used OpenFoam with simFlow...what I can guess is that while preparing your case using simFlow...there will be some option to define Phi...
March 15, 2018, 17:49 |
#14 | |
Metikurke
Rep Power: 9 |
For the future readers this following code works, but you should use Phi instead of phi, and add these in the solvers area of fvSolutions. And thank you Chrismar and Sana for this thread.
Metikurke |
openfoam |
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 00:58 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
