Piston motion with time varying experimental data oscillatingFixedValue
Old   March 12, 2009, 17:33
Default I am using openfoam 1.4 in cyg
eno
Sean Bian
eno is on a distinguished road
I am using openfoam 1.4 in cygwin to solve internal compressible turbulent flow under the motion of a piston. By modifying rhoTurbFoam I can use oscillatingFixedValue in cellMotionUX to define a sinusoidal piston motion Ux = f*(a*sin(2*pi*t)+1). The mesh deforms as expected and the simulation looks reasonable.
Now I want to drive the piston with motions (time varying, no sinusoidal displacement) measured from experiment. How can I do it?
eno is offline   Reply With Quote
Old   March 13, 2009, 02:07
Default Hi, if I remember rightly,
Marco Müller
marico is on a distinguished road
if I remember rightly, this is not trivial. Maybe you can approximate the values analytically and use groovyBC. I tried just yesterday to apply the "standard piston law of motion" (way over time) and it worked perfect.
Best Regards
Marco
marico is offline   Reply With Quote
Old   March 13, 2009, 15:18
Default Can I just modify the code to
eno
Sean Bian
Can I just modify the code to read and interpolate the external velocity at where Ux = f*(a*sin(2*pi*t)+1) is executed?
Old   March 19, 2009, 10:06
eno
Sean Bian
dang... it's readily there! just modify cellMotionUx (or other initial files) like:
piston
// type oscillatingFixedValue;
// refValue uniform 1.;
// amplitude .2;
// frequency .5;
// value uniform 0;
type timeVaryingUniformFixedValue;
timeDataFileName "pistonVelocity.dat";
value uniform 0;
CFX Piston Motion (CEL) Dante CFX 4 May 28, 2012 06:08
Piston motion with time varying experimental data oscillatingFixedValue eno OpenFOAM Running, Solving & CFD 0 March 12, 2009 17:31
motion of piston wave maker chandra sekhar b Main CFD Forum 0 October 31, 2008 07:06
Piston Motion A Student Siemens 0 April 18, 2006 11:36
piston motion Arpan Siemens 1 March 9, 2006 07:52
