September 27, 2006, 03:08 |
I am a beginner of OF,and now
#61 |
I am a beginner of OF,and now try to simulate SI engine by using engineFoam.
I want to change equivalenceRatio from 1.0 to 0.8. And,I changed equivalenceRatioin in "constant/combustionProperties" file. Could I really change ratio? I need to change another property? please help me.. |
September 27, 2006, 03:31 |
Hi Noriaki,
to change the equ
#62 |
Tommaso Lucchini
Rep Power: 17 |
Hi Noriaki,
to change the equivalence ratio you don't have to change it in the constant/thermophysicalProperties, but you have to change the value of ft in the ./-180 directory. ft is the fuel mass fraction, i.e. fuel/(air+fuel), which you can easily relate with the air/fuel ratio and/or the equivalence ratio. Bye Tommaso |
September 27, 2006, 04:34 |
Thank you very much.
Noriaki.
#63 |
Noriaki. |
September 27, 2006, 04:39 |
TO Tomma
#64 |
TO Tommaso. |
September 27, 2006, 05:10 |
I want to change compression r
#65 |
I want to change compression ratio.
And I changed stroke and clearance value. But I could not change the ratio. I need to change another properties? Please help me. |
September 27, 2006, 06:40 |
Hi Noriaki,
How do you chec
#66 |
Rikard Mikalsen
Rep Power: 17 |
Hi Noriaki,
How do you check the compression ratio? engineCompRatio? Changing the stroke should be enough. Try (in the directory where your case is): engineCompRatio . case (where 'case' would be kivaTest if you run the tutorial) -- change the stroke in case/constant/engineGeometry -- run engineCompRatio again and see what happens (something should happen) You can see how the piston motion is calculated in /home/user/OpenFOAM/OpenFOAM-1.3/src/engine/engineTime/engineTime.C. Rikard |
September 28, 2006, 02:51 |
Thank you Rikard,
I will try
#67 |
Thank you Rikard,
I will try it. |
September 28, 2006, 02:54 |
Thank you Rikard,
I will try
#68 |
Thank you Rikard,
I will try it. |
September 29, 2006, 06:35 |
Hi Tonnaso,
I could not open
#69 |
Hi Tonnaso,
I could not open file in the ./-180 directory. I do not know the reason. Please tell me. |
October 1, 2006, 08:08 |
Hi Everyone.
In engineFoam,
#70 |
Hi Everyone.
In engineFoam, we can get "log_summery.-15" file after calculation. It seems that mean pressure and mean temperature is written in it, but I don't know how calculate mean value. Weighted mean value or something?? Please someone help me. Thanks. Atsushi |
October 2, 2006, 08:31 |
Hi Atsushi,
The code that w
#71 |
Rikard Mikalsen
Rep Power: 17 |
Hi Atsushi,
The code that writes to the logSummary file is found in /home/user/OpenFOAM/OpenFOAM-1.3/applications/solvers/combustion /engineFoam/logSummary.H The values written to the file are volume-weighted averages, calculated with field.weightedAverage(mesh.V()).value() or sum(field*mesh.V())/sum(mesh.V()) Rikard |
October 2, 2006, 11:15 |
Thank you for your reply, Rika
#72 |
Thank you for your reply, Rikard.
Does it mean that "add temperature of all cell" / "add volume of all cell" ?? Atsushi |
October 13, 2006, 06:07 |
I am the japanese college stud
#73 |
I am the japanese college student. Please teach me.
I run the engineFoam now. I want to put chemistryModel in engineFoam. should I change engineFoam.C or another files? please tell me how to this definitely. thanks.. |
October 13, 2006, 06:29 |
what do you want to simu
#74 |
Tommaso Lucchini
Rep Power: 17 |
what do you want to simulate with engineFoam and chemistryModel? regards tommaso |
October 13, 2006, 06:32 |
#75 |
Tommaso Lucchini
Rep Power: 17 |
October 13, 2006, 06:43 |
By running the engineFoam
#76 |
By running the engineFoam,I want to see the CO2,N2,O2 distribution such as the result of dieselFoam. |
January 30, 2007, 06:20 |
I try to model premix combusti
#77 |
I try to model premix combustion in SI engine. I use kivaTest in the tutorial.
Xi=∑/∑0? What is Xi? Help me please. |
April 4, 2007, 12:09 |
Hi in a domain of the scale fo
#78 |
O R
Rep Power: 17 |
Hi in a domain of the scale found in pitzDaily, What are the parameters to be chosen in ignites sites in order to ensure a complete combustion.
All is running stable and then an error FOAM FATAL ERROR : attempt to use janafThermo<equationofstate> out of temperature range 200 -> 6000; I saw a lot of people having this error , so far noone has a satisfactory answer the Courant number is in the range but b min(b) grows up to O(10^-5) with a combustion progress of 50 or 60 % any idea to bound b or any possible reason for such error |
May 2, 2007, 09:33 |
I am using dieselEngineFoam.
#79 |
Tomislav Sencic
Rep Power: 17 |
How can I display the rate of heat release? What are the fields: dQ phi kappa meshPhi H in the time directories? |
May 25, 2007, 07:01 |
Hello everyone,
What is the
#80 |
Hello everyone,
What is the difference between 'engineFoam' and 'coldEngineFoam'? I just want to know what kind of simulations I can do in 'coldEngineFoam'. Any help will be welcome. Thanks. Atsu |
combustion model in premixed combustion chamber | wuyu | FLUENT | 9 | February 16, 2018 10:40 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 18:40 |
Sawdust Combustion-Non-premixed Combustion Model | Jessy | FLUENT | 1 | June 19, 2007 10:59 |
combustion in internal combustion engine | George | Main CFD Forum | 0 | September 7, 2006 14:41 |
combustion | prasat | Main CFD Forum | 1 | June 16, 2003 13:17 |
