July 10, 2005, 20:25 |
I'm new to OpenFoam, and my ap
Arturo O
Rep Power: 17 |
I'm new to OpenFoam, and my applications are about porous media.
I've searched the forum (not exhaustive, though) without any mention to this application. So far fluent and the like have tackled the subject by including a source term on the momentum equation and I don't expect this to be too hard to implement in openFoam. My question is of course if someone has already done that. Also if it is possible to implement it in a multiphase Eulerian N-phase model. So far I think there is only 2 phase Eulerian model, am I right? Thanks folks in advance Thanks. Arturo O. |
July 11, 2005, 07:20 |
I have done a number of
Hrvoje Jasak
Rep Power: 33 |
I have done a number of porous media flow model implementations, including scalar or tensorial resistance, using Darcy's law. They were typically a part of more complex model, like for example the biscuit baking model (mass transfer for air, liquid water and water vapour + heat transfer + stress analysis with large deformations) or similar complex heat/mass transfer models. In these cases, the flow equations lose the momentum term and you can solve them just by solving for pressure. Currently, there's no top-level example code for porous media, because it's "too simple" and interesting only with some other phenomena. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
July 11, 2005, 07:50 |
I implemented the generalised
Rep Power: 22 |
I implemented the generalised laplacian with tensorial viscosity (currently limited to an orthogonal grid in the region of the porous medium) in version 1.1 which can be used to include porous media effects into any of the basic solvers with a little bit of effort. I have used it to write a catalytic-converter simulation code and other specialised applications but it is a lot of effort to write example codes, FoamX configurations, documentation etc. so until someone is prepared to pay for this work we are unlikely to do it because our spare time is already taken up with basic maintenance and core development tasks.
July 11, 2005, 11:35 |
I have completed a multiphase
Rep Power: 22 |
I have completed a multiphase version of interFoam but haven't yet done the same for the Eulerian two-phase code although it is perfectly possible.
July 13, 2005, 00:17 |
My main interest are chemical
Arturo O
Rep Power: 17 |
My main interest are chemical reactions and other physics on porous media, the so called packed bed reactors, so many other phenomena must be accounted for such as heat transfer, chemical reaction and mass transfer, its good to know that OpenFoam can tackle those cases.
Thanks for the answer and I hope I can post my questions if stucked. Thanks to all Arturo |
July 13, 2005, 00:24 |
BTW I work also with multiphas
Arturo O
Rep Power: 17 |
BTW I work also with multiphase flows on porous media.
Thnx Arturo |
January 17, 2006, 15:39 |
Hi
@Hrvoje Jasak: How did y
Nico Petry
Rep Power: 17 |
Hi
@Hrvoje Jasak: How did you implement darcys law for tensoral resistant? For scalar resistant I simply add +fvm::SuSp(nu*G,U) to the simpleFoam solver, where U is the inverse of K and K is the specific viskosity of my porous media (unit of K :m2). But how to do this for a volTensorField? I tried +nu*(G&U), but it did not converge. bye |
January 17, 2006, 18:38 |
Several things: please note th
Hrvoje Jasak
Rep Power: 33 |
Several things: please note that this kind of thing is really consultancy, i.e. I will rarely be prepared to give away this level of explanation for free.
Firstly, when you say fvm::SuSp you mean that the term may be both positive (source) or negative. In your case, we are talking about porous drag (unless you porous medium is capable of producing energy = accelerating the fluid). This the term is always a sink - use fvm::Sp. Secondly, my Darcy's law says that the velocity field is in equilibrium with the pressure gradient. In other words, U is proportional to grad p. If you read this once again, this means that both the convection and the diffusion term in the momentum equation are negligible and should be thrown out. The last term is left is the ddt term and this is a question of taste: is the equilibrium immediate (no ddt) or is there a relaxation towards the equilibrium (ddt remains and complicates matters a little bit). With this in mind, could you please temm me why you are solving the momentum equation in the first place: U is proportional to grad p (Darcy's law) and convection and diffusion in the prorous medium should be neglected. So, now we are in business: no mementum equation and U is in equilibrium with the pressure gradient. Thus, all I need to do is to solve the pressure equation, using the porous resistance (please derive yourself!). Finally, the story above is valid both for isotropic resistance and directional resistance. When you derive it, you will find that for the latter, the pressure laplace needs a tensorial diffusivity term! There you can use: template<class> tmp<fvmatrix<type> > laplacian ( const volTensorField&, GeometricField<type,>& ); (that should now make sense!). Enjoy (courtesy of), Hrv
January 18, 2006, 03:32 |
Thank you very much.
But th
#9 |
Nico Petry
Rep Power: 17 |
But there ist still a question. In my case there is a porous region and a non porous region, and therefor I found the Navier-Stokes-Brinkman equation. I understand that the convection and the diffusion term are negligible in the porous region. But only there, so that they cannot be thrown out in my case. Am I right? I hope it is not too boring for you. I am a real beginner. Sorry Bye |
January 18, 2006, 04:52 |
That's all fine: you can knock
#10 |
Hrvoje Jasak
Rep Power: 33 |
That's all fine: you can knock out the fluxes and diffusion in the porous region and have the complete momentum elsewhere.
However, the primary coupling in the system is p-U and not the momentum equation. Thus, as long as you keep messing about with the sink terms in the momentum equation instead of rewriting the pressure laplacian - this handles the dominant coupling - you won't get this to work (for any serious porous medium). My advice (step by step, make it work, understand it and then generalise) 1) write a simple porous medium solver, no momentum equation 2) do the same for directional resistance 3) include the ddt term only in the momentum 4) do the same, with the porous medium covering a part of the domain. Beware of continuity problems on the porous interface!!! 5) introduce tensorial resistance. Rinse. Repeat :-) Have fun, Hrv
January 18, 2006, 07:52 |
I see it's getting more compli
#11 |
Nico Petry
Rep Power: 17 |
I see it's getting more complicated than expected.
Thanks a lot. Last Question: How can I knock out the fluxes and the diffusion in the porous region and have the complete momentum elsewhere? Define a field for it? Perhaps a volScalarField with the value 0 in the porous medium and the value 1 elsewhere? So that i can use it as a switch? |
January 18, 2006, 07:56 |
P.S. What do accurately mean w
#12 |
Nico Petry
Rep Power: 17 |
P.S. What do accurately mean with pressure laplacian?
January 24, 2006, 11:14 |
Hi Hrv!
Is it right, that I
#13 |
Nico Petry
Rep Power: 17 |
Hi Hrv!
Is it right, that I have to solve the following eqaution: fvScalarmatrix pEqn ( fvm::laplacian(K/nu, p) == fcv::div(phi) ); ? In Simple Foam we solve at first the UEqn. After that we caculate phi. And then we solve the pEqn. In my case I will at first solve the presserue equation and because of that i don't know how to calculate phi. I hope you understand my problem. Thanks |
January 24, 2006, 11:26 |
Better, but there's no flux to
#14 |
Hrvoje Jasak
Rep Power: 33 |
Better, but there's no flux to start with: it's all in the pressure gradient. So, just lose the rhs. and you will get the flux when you solve for the pressure.
Keep digging :-) Hrv
January 24, 2006, 11:37 |
Sorry, but i don't know what y
#15 |
Nico Petry
Rep Power: 17 |
Sorry, but i don't know what you mean with rhs...
January 24, 2006, 11:42 |
Ok,i think with rhs you mean r
#16 |
Nico Petry
Rep Power: 17 |
Ok,i think with rhs you mean right side?!
like this: fvScalarmatrix pEqn ( fvm::laplacian(K/nu, p) ); ?? Isn't it possible that you send me one of your solver.C to understand what to do? I only need this for university. I would be a greate help. |
January 24, 2006, 11:43 |
Sorry: that would be the "righ
#17 |
Hrvoje Jasak
Rep Power: 33 |
Sorry: that would be the "right-hand-side" of the equation. In other words:
fvScalarmatrix pEqn ( fvm::laplacian(K/nu, p) ); pEqn.solve(); Hrv
January 28, 2006, 09:31 |
Hi Hrvoje Jasak,
you told m
#18 |
Nico Petry
Rep Power: 17 |
Hi Hrvoje Jasak,
you told me that my first way to solve flow in porous media was wrong. I found an article about different methods to do this. There are two macroscopic model. One is solving darcys law in the porous region and ns in the fluid region. That is what you told me. But there is another method. That is what i have done, the socalled "Reformulated problem" : Brinkman model for the porous media, Navier-Stokes for the fluid region, and continuos stress tensor interface conditions, are reformulated, so that a single system of partial differential equations is govering the flow in the pure liquid and in the porous media. This is done in the fictitious regions method manner. link: http://kluedo.ub.uni-kl.de/volltexte.../bericht51.pdf Thanks a lot for all your help and efforts. Nico |
February 26, 2009, 03:38 |
Hello, all
I'm new to OpenF
#19 |
fan
Hello, all
I'm new to OpenFoam, and also to CFD problems. I was used to discretize PDE to ODE and leave everything else to the solver (such as ode15s in matlab). Now I start to learn algorithms like PISO, and it seems really confusing for me. One question is, if I'm dealing with flows in porous media governed by simple darcy's law. Is it still necessary to use PISO loop? Because every textbook said PISO is used to solve the pressure-velocity coupling. But now the velocity can be calculated directly from pressure gradient and we don't even have a momentum balance equation. I hope this is a corret thread for this question, and thanks a lot for any hints or suggestion. Fan |
September 11, 2010, 06:26 |
#20 | |
Zinedine
Rep Power: 15 |
I have just completed a very useful and interesting Openfoam training. I was wondering if it would be possible to get some test case files like those used in "Biscuit baking model". It would be kindly appreciated. Thanks in advance. Z. |
Porous media model in OpenFOAM 14 | gac | OpenFOAM Running, Solving & CFD | 21 | August 5, 2013 17:49 |
POROUS MEDIA | Sean Cody | FLUENT | 8 | March 6, 2013 10:33 |
Free media&porous media.Big changes in properties. | Isi | Main CFD Forum | 1 | July 14, 2008 07:18 |
porous media | Kurt Malinski | FLUENT | 3 | September 13, 2004 12:31 |
Porous baffle and porous media | Jan | Siemens | 0 | June 8, 2002 09:23 |
