How to apply a function as boundary condition |
January 13, 2009, 03:48 |
Dear Foamers,
I'm a newbie
Chuang Gao
Rep Power: 17 |
Dear Foamers,
I'm a newbie here. For my question, I want to add a function with time and circumferential position as the variables for the inlet boundary condition. The study object is a circular ring and the inlet radius is R2 while the outlet one is R3. The inlet condition should be V2=V_mean+sin(Omega*t+phi), in which the Omega is the angular velocity and a constant in this expression. V_mean and phi (initial position) are also constants, t is the time for unsteady calculation. Can such kind of boundary condition be given? For fluent, this is very easy through using the UDF. Thanks all. |
January 15, 2009, 03:49 |
i need to run a combustion pro
VIJAYAKUMAR R
Rep Power: 17 |
i need to run a combustion problem.... i used XI-foam as solver, while running some errors are coming... i need to know which solver is good for combustion problem.. and few guidelines for solving combustion problem.
January 15, 2009, 05:07 |
OK. Let's see: http://openfoam
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
OK. Let's see: http://openfoamwiki.net/index.php/Ho..._Message_Board
You hit the points 1,2,3,5 and 7. Not a bad score. But it means it is very unlikely that you'll get an answer. No offense.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
January 15, 2009, 05:53 |
Ok, I'd like to use the DNS so
Chuang Gao
Rep Power: 17 |
Ok, I'd like to use the DNS solver in OpenFoam 1.5.
Is this information clear? |
January 15, 2009, 06:14 |
Hi Chuang
I am certain that
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Chuang
I am certain that Bernhard's comment was not minded on you, but on the person who hijacked the thread. As a answer to your question, I cannot see any spatial variation in your boundary condition, thus you might be able to achieve what you are after by applying "timeVarying<something>". I am not at a OF-machine at the present, but you should be able to find it using the search function. Best regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
January 15, 2009, 14:47 |
Hi Chunag!
Niels is right.
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Chunag!
Niels is right. I meant the other poster. Sorry if I upset you Bernhard
January 15, 2009, 21:26 |
Hi, Niels and Bernhard,
If
Chuang Gao
Rep Power: 17 |
If you plot the function I posted, it has nonuniform distribution along the circumferential direction. for a function, such as sin(n*theta) is a kind of flower function. theta is the circumferential coordinate. I've noticed a poster which talked about parabolic inlet boundary condition. But there do existed some differences. Can anybody give me a hint? |
January 18, 2009, 15:03 |
Hi Chuang
There is not prob
Rep Power: 37 |
Hi Chuang
There is not problem in specifying boundary conditions, which are varying both in space and time. I you want to give a Dirichlet condition, then I would recommend you to find parabolicInlet-BC, which you will be able to find on this forum. This you should be able to modify to the purpose you are considering. When you have implemented your own conditions just compile the BC using the wmake-procedure, link the BC to the solver of your choice, and you should be well off. Good luck, Niels
January 19, 2009, 18:45 |
Hi Niels,
Thx for your kin
#9 |
Chuang Gao
Rep Power: 17 |
Hi Niels,
Thx for your kind help! I'll try it and post my results here. Best Regards, Chuang Gao |
February 12, 2009, 10:22 |
Hi everybody,
I'm dealing wit
#10 |
Andrea Petronio
Rep Power: 17 |
Hi everybody,
I'm dealing with boundary condition as function of a calculated scalar fields. I think to derive it from a fixedValue bc. Someone have already done something similar? |
How to apply a function as boundary condition | coompressor | OpenFOAM Running, Solving & CFD | 0 | January 13, 2009 03:50 |
How can apply mass flow rate boundary condition? | Sima | Phoenics | 1 | December 1, 2007 18:55 |
Apply boundary condition functions | billy | OpenFOAM Pre-Processing | 7 | December 18, 2005 21:22 |
How to set a boundary condition as a function respect to time | chnrdu | OpenFOAM Running, Solving & CFD | 2 | June 17, 2005 04:18 |
Random function UDF for boundary condition | Chris | FLUENT | 4 | March 28, 2003 15:38 |
