OpenFOAM-2.1.0 Writes Data in Old Format and Reads in New Format
Like Tree2Likes
  • 2 Post By JLight
Old   October 4, 2012, 00:38
Default OpenFOAM-2.1.0 Writes Data in Old Format and Reads in New Format
Nishit Joseph
JLight is on a distinguished road
Hi OF Users!
I am having a seprate difficulity regarding OF-2.1 with the 'parallel' patches influencing the the solution here. In trying to diagnose that issue I have hit a seprate one.
Here is what I am trying to do. Run the solver as a single process for a few time steps. Use the intermediat solution to deocmpose the case. Then run the case from the last computed time step.
I can
  • View the solution in ParaView without any issues.
  • Decompose the case without any issues.
I cannot
  • Contine the solution in parallel
  • Continue the solution as a single processor
Here is my output when I try to run the solver again as a single processor
$ rhoCentralFoam
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-bd7367f93311
Exec   : rhoCentralFoam
Date   : Oct 04 2012
Time   : 14:26:10
Host   : "jlightDell"
PID    : 10761
Case   : /home/jlight/CFD/DSTO/MainWork/Wire_OF_New
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 1.000000e-08
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
--> FOAM Warning :
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/jlight/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C at line 262
    Reading "/home/jlight/CFD/DSTO/MainWork/Wire_OF_New/1.000000e-08/U::boundaryField::wire" from line 166680 to line 167095
    expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
--> FOAM FATAL IO ERROR:
Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 166686 the label 200
file: /home/jlight/CFD/DSTO/MainWork/Wire_OF_New/1.000000e-08/U::boundaryField::wire::refValue at line 166686.
    From function Istream::readBegin(const char*)
    in file db/IOstreams/IOstreams/Istream.C at line 94.
FOAM exiting
Any suggestion on how I am solve this?
JLight
JLight is offline   Reply With Quote
Old   October 4, 2012, 07:12
Default Missing Keyword
Nishit Joseph
Just an update on this.
I was looking at the U files and found that the keyword 'nonuniform' was missing for the refValues and valueFraction.
However I am not sure which file controls the output for boundary fields like this one (being the maxwellSlipU from rhoCentralFoam's BC). I will like to edit the source and fix this issue.
JLight
Old   October 4, 2012, 08:59
Default The Fix
Nishit Joseph
The fix is simple and I have reported a bug to OpenFOAM.
Just edit the file $FOAM_APP/solvers/compressible/rhoCentralFoam/BCs/U/maxwellSlipUFvPatchVectorField.C.
--- ../../../rhoCentralFoam/BCs/U/maxwellSlipUFvPatchVectorField.C	2011-11-25 03:59:50.000000000 +1100
+++ maxwellSlipUFvPatchVectorField.C	2012-10-04 22:30:46.318141418 +1000
@@ -194,11 +194,9 @@
     os.writeKeyword("thermalCreep")
         << thermalCreep_ << token::END_STATEMENT << nl;
     os.writeKeyword("curvature") << curvature_ << token::END_STATEMENT << nl;
-    os.writeKeyword("refValue")
-        << refValue() << token::END_STATEMENT << nl;
-    os.writeKeyword("valueFraction")
-        << valueFraction() << token::END_STATEMENT << nl;
+    refValue().writeEntry("refValue", os);
+    valueFraction().writeEntry("valueFraction", os);
     writeEntry("value", os);
Hope this helps.
JLight
wyldckat and caduqued like this.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
