January 5, 2009, 13:18 |
\attach
Hi All..
I want to
Vishal Nandigana
Rep Power: 18 |
\attach
Hi All.. I want to incorporate the following geometry using blockMesh.. Kindly help me out how exactly I have to go about implementing this... I am relatively new to Open foam.. Regards Vishal |
January 5, 2009, 13:21 |
http://www.cfd-online.com/Ope
Vishal Nandigana
Rep Power: 18 |
January 6, 2009, 06:20 |
Hi Vishal,
You will have thre
Sachin Kanetkar
Hi Vishal,
You will have three blocks - 2vertical and 1 horizontal. give all co-ordinates and create it. The best way to understand is to check tutorials/icoFoam/cavity/constant/polyMesh/blockMeshdict and tutorials/icoFoam/cavityclipped/constant/polyMesh/blockMeshdict - see how the cavity is created and also how clipped geometry is created. All geometries in openfoam will be 3 dimensional although third dimension could be made of 1 grid. help for cavity geometry is available in userguide. Please go thru that best luck ... Sachin |
January 6, 2009, 21:34 |
Thanks a lot Sachin for the va
Vishal Nandigana
Rep Power: 18 |
Thanks a lot Sachin for the valuable comments. I did create simple geometries as given in ICOFOAM cavity problem...but here the vertical and horizontal blocks are connected right and it is not closed.. hence wanted to know how do we connect the two sections...
Thanks Vishal |
January 7, 2009, 10:04 |
Sachin is right. you will have
Wolfgang Heydlauff
Rep Power: 21 |
Sachin is right. you will have to creat 3 blocks. give the coordinateds and create the blocks.
is this a solid problem or should this become a fluid problem? be sure the nodes of all blocks are the same number and have the same coordinates at the connecting face. if this is a fluid problem you will have to define the patches. just define each patch as e.g. wall, an inlet, an outlet and don't define the connecting patches. they'll automatically merge together (no need to add something under "mergePatchPairs"). hope that helps, write if it does. |
January 7, 2009, 14:21 |
Hi Wolfgang,
Thanks for the
Vishal Nandigana
Rep Power: 18 |
Hi Wolfgang,
Thanks for the reply. Yes this is a fluid problem.. I will try to incorporate your suggestions and would send my code once I am done.. Thanks for the help.. Vishal |
January 9, 2009, 12:45 |
As I had posted before,
Vishal Nandigana
Rep Power: 18 |
As I had posted before, I finished coding it, I would like to know how to define the patches for proper boundary conditions... My boundary conditions are I have inlet at the left vertical block and outlet at the right vertical block and at wall at the rest as I had given in my geometry file in the forum... Kindly let me know whether my code is correct.... Here is my blockMesh Dict file. I have 2 vertical blocks of geometry 1 * 1 and a horizontal block in the middle of geometry 5 (length) * 0.03 (height) Vertical Block1 - Numbered as (0 1...7) Vertical Block2 - Numbered as (16 17...23) Horrizontal block - Numbered as (8 9..15) /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (1 0 0) (1 1 0) (0 1 0) (0 0 0.1) (1 0 0.1) (1 1 0.1) (0 1 0.1) (1 0.485 0) (6 0.485 0) (6 0.515 0) (1 0.515 0) (1 0.485 0.1) (6 0.485 0.1) (6 0.515 0.1) (1 0.515 0.1) (6 0 0) (7 0 0) (7 1 0) (6 1 0) (6 0 0.1) (7 0 0.1) (7 1 0.1) (6 1 0.1) ); blocks ( hex (0 1 2 3 4 5 6 7) (100 10 1) simpleGrading (2 1 1) hex (8 9 10 11 12 13 14 15) (100 10 1) simpleGrading (2 2 1) hex (16 17 18 19 20 21 22 23) (100 10 1) simpleGrading (2 1 1) ); edges ( ); patches ( patch inlet ( (0 3 7 4) ) patch outlet ( (17 18 22 21) ) patch upperwall ( (2 3 7 6) (18 19 23 22) ) patch lowerwall ( (4 5 1 0) (20 21 17 16) ) patch connectingupperwall ( (14 10 11 15) (11 2 6 15) (10 19 23 14) ) patch connectinglowerwall ( (12 13 9 8) (1 8 12 5) (16 9 13 20) ) empty frontAndBack ( (0 1 2 3) (4 5 6 7) (8 9 10 11) (12 13 14 15) (16 17 18 19) (20 21 22 23) ) ); mergePatchPairs ( ); // ************************************************** *********************** // When I run the mesh I get the following error.. Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty face 1 in patch 4 does not have neighbour cell face: 4(11 2 6 15)#0 Foam::error::printStack(Foam:stream&) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam:stream& Foam::operator<<>(Foam:stream&, Foam::errorManip<foam::error>) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #3 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face> > const&, int) const in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #6 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #7 main in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #9 __gxx_personality_v0 in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 125. FOAM aborting Aborted Kindly do the needful Thanks -- Regards Vishal |
January 9, 2009, 14:30 |
Vishal Nandigana
Rep Power: 18 |
January 9, 2009, 14:31 |
Vishal Nandigana
Rep Power: 18 |
As I had posted before, I finished coding it, I would like to know how to define the patches for proper boundary conditions... My boundary conditions are I have inlet at the left vertical block and outlet at the right vertical block and at wall at the rest as I had given in my geometry file in the forum... Kindly let me know whether my code is correct.... Here is my blockMesh Dict file. I have 2 vertical blocks of geometry 1 * 1 and a horizontal block in the middle of geometry 5 (length) * 0.03 (height) Vertical Block1 - Numbered as (0 1...7) Vertical Block2 - Numbered as (16 17...23) Horizontal block - Numbered as (8 9..15) /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (1 0 0) (1 1 0) (0 1 0) (0 0 0.1) (1 0 0.1) (1 1 0.1) (0 1 0.1) (1 0.485 0) (6 0.485 0) (6 0.515 0) (1 0.515 0) (1 0.485 0.1) (6 0.485 0.1) (6 0.515 0.1) (1 0.515 0.1) (6 0 0) (7 0 0) (7 1 0) (6 1 0) (6 0 0.1) (7 0 0.1) (7 1 0.1) (6 1 0.1) ); blocks ( hex (0 1 2 3 4 5 6 7) (100 10 1) simpleGrading (2 1 1) hex (8 9 10 11 12 13 14 15) (100 10 1) simpleGrading (2 2 1) hex (16 17 18 19 20 21 22 23) (100 10 1) simpleGrading (2 1 1) ); edges ( ); patches ( patch inlet ( (0 3 7 4) ) patch outlet ( (17 18 22 21) ) patch upperwall ( (2 3 7 6) (18 19 23 22) ) patch lowerwall ( (4 5 1 0) (20 21 17 16) ) patch connectingupperwall ( (14 10 11 15) (11 2 6 15) (10 19 23 14) ) patch connectinglowerwall ( (12 13 9 8) (1 8 12 5) (16 9 13 20) ) empty frontAndBack ( (0 1 2 3) (4 5 6 7) (8 9 10 11) (12 13 14 15) (16 17 18 19) (20 21 22 23) ) ); mergePatchPairs ( ); // ************************************************** *********************** // When I run the mesh I get the following error.. Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty face 1 in patch 4 does not have neighbour cell face: 4(11 2 6 15)#0 Foam::error::printStack(Foam:stream&) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam:stream& Foam::operator<<>(Foam:stream&, Foam::errorManip<foam::error>) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #3 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face> > const&, int) const in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #6 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #7 main in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" #8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #9 __gxx_personality_v0 in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh" From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 125. FOAM aborting Aborted Kindly do the needful Thanks -- Regards Vishal |
January 13, 2009, 04:05 |
in my opinion you can n
Wolfgang Heydlauff
Rep Power: 21 |
in my opinion you can not only use 3 blocks for this problem. you might not use a block and attach another block to it without any further connection rules. in your solution you have the faces with double boundary conditions. use at least 7 blocks. for this you have to insert more vertices. maybe you can work with one symmetryPlane horizontally through the middle. so you only had to change the coordinates and use 5 blocks. another solution could be, you crearte 6 blocks. so they are also devided in the middle. and your connectionblock in the middle consists of 2 horizontal devided blocks. i yould prefer the symmetryPlane solution. good luck. |
January 13, 2009, 09:09 |
Yes, my mistake should have be
#11 |
Sachin Kanetkar
Yes, my mistake should have been atleast 5, 3 was wrong ans
January 13, 2009, 14:20 |
Hi Wolfgang and Sachin
Than
#12 |
Vishal Nandigana
Rep Power: 18 |
Thanks for the information, I finished creating the geometry with 7 blocks and implemented it in the code, it is working fine at the moment. I would get back to you guys if I encounter any problem. Thanks Regards Vishal |
create turbine geometry with gambit | badlaine | ANSYS Meshing & Geometry | 2 | March 26, 2012 23:54 |
[Technical] What is the best option for create a mesh not using blockmesh | titio | OpenFOAM Meshing & Mesh Conversion | 4 | January 17, 2008 02:37 |
[blockMesh] Does blockMesh create mesh vertices in any particular order | brooksmoses | OpenFOAM Meshing & Mesh Conversion | 3 | December 12, 2005 20:26 |
how to create structured geometry | Rashmi | FLUENT | 10 | December 2, 2005 07:48 |
Create 2d geometry file with pro*am? | raymond | Siemens | 1 | December 13, 2001 10:31 |
