Help to create geometry using blockMesh
Old   January 5, 2009, 13:18
Default \attach Hi All.. I want to
Vishal Nandigana
nandiganavishal is on a distinguished road
\attach
Hi All..
I want to incorporate the following geometry using blockMesh.. Kindly help me out how exactly I have to go about implementing this... I am relatively new to Open foam..
Regards
Vishal
nandiganavishal is offline   Reply With Quote
Old   January 5, 2009, 13:21
Default http://www.cfd-online.com/Ope
Vishal Nandigana
geometry.pdf.tar.gz
Old   January 6, 2009, 06:20
Default Hi Vishal, You will have thre
Sachin Kanetkar
sachin is on a distinguished road
Hi Vishal,
You will have three blocks - 2vertical and 1 horizontal.
give all co-ordinates and create it. The best way to understand is to check tutorials/icoFoam/cavity/constant/polyMesh/blockMeshdict and tutorials/icoFoam/cavityclipped/constant/polyMesh/blockMeshdict - see how the cavity is created and also how clipped geometry is created.
All geometries in openfoam will be 3 dimensional although third dimension could be made of 1 grid. help for cavity geometry is available in userguide. Please go thru that
best luck ...
Sachin
sachin is offline   Reply With Quote
Old   January 6, 2009, 21:34
Default Thanks a lot Sachin for the va
Vishal Nandigana
Thanks a lot Sachin for the valuable comments. I did create simple geometries as given in ICOFOAM cavity problem...but here the vertical and horizontal blocks are connected right and it is not closed.. hence wanted to know how do we connect the two sections...
Thanks
Vishal
Old   January 7, 2009, 10:04
Default Sachin is right. you will have
Wolfgang Heydlauff
wolle1982 will become famous soon enough
Sachin is right. you will have to creat 3 blocks. give the coordinateds and create the blocks.
is this a solid problem or should this become a fluid problem?
be sure the nodes of all blocks are the same number and have the same coordinates at the connecting face.
if this is a fluid problem you will have to define the patches. just define each patch as e.g. wall, an inlet, an outlet and don't define the connecting patches. they'll automatically merge together (no need to add something under "mergePatchPairs").
hope that helps, write if it does.
wolle1982 is offline   Reply With Quote
Old   January 7, 2009, 14:21
Default Hi Wolfgang, Thanks for the
Vishal Nandigana
Hi Wolfgang,
Thanks for the reply. Yes this is a fluid problem.. I will try to incorporate your suggestions and would send my code once I am done..
Thanks for the help..
Vishal
Old   January 9, 2009, 12:45
Default Hi, As I had posted before,
Vishal Nandigana
As I had posted before, I finished coding
it, I would like to know how to define the patches for proper boundary
conditions... My boundary conditions are I have inlet at the left
vertical block and outlet at the right vertical block and at wall at
the rest as I had given in my geometry file in the forum... Kindly let
me know whether my code is correct.... Here is my blockMesh Dict file.
I have 2 vertical blocks of geometry 1 * 1 and a horizontal block in
the middle of geometry 5 (length) * 0.03 (height)
Vertical Block1 - Numbered as (0 1...7)
Vertical Block2 - Numbered as (16 17...23)
Horrizontal block - Numbered as (8 9..15)
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0.1)
(1 0 0.1)
(1 1 0.1)
(0 1 0.1)
(1 0.485 0)
(6 0.485 0)
(6 0.515 0)
(1 0.515 0)
(1 0.485 0.1)
(6 0.485 0.1)
(6 0.515 0.1)
(1 0.515 0.1)
(6 0 0)
(7 0 0)
(7 1 0)
(6 1 0)
(6 0 0.1)
(7 0 0.1)
(7 1 0.1)
(6 1 0.1)
blocks
hex (0 1 2 3 4 5 6 7) (100 10 1) simpleGrading (2 1 1)
hex (8 9 10 11 12 13 14 15) (100 10 1) simpleGrading (2 2 1)
hex (16 17 18 19 20 21 22 23) (100 10 1) simpleGrading (2 1 1)
edges
patches
patch inlet
(0 3 7 4)
patch outlet
(17 18 22 21)
patch upperwall
(2 3 7 6)
(18 19 23 22)
patch lowerwall
(4 5 1 0)
(20 21 17 16)
patch connectingupperwall
(14 10 11 15)
(11 2 6 15)
(10 19 23 14)
patch connectinglowerwall
(12 13 9 8)
(1 8 12 5)
(16 9 13 20)
empty frontAndBack
(0 1 2 3)
(4 5 6 7)
(8 9 10 11)
(12 13 14 15)
(16 17 18 19)
(20 21 22 23)
mergePatchPairs
When I run the mesh I get the following error..
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
face 1 in patch 4 does not have neighbour cell face: 4(11 2 6 15)#0
Foam::error::printStack(Foam:stream&) in
"/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in
#2 Foam:stream& Foam::operator<<>(Foam:stream&,
Foam::errorManip<foam::error>) in
"/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh"
#3 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&,
Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face>
> const&, int) const in
#4 Foam::polyMesh::polyMesh(Foam::IOobject const&,
Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape>
const&, Foam::List<foam::list<foam::face> > const&,
Foam::List<foam::word> const&, Foam::List<foam::word> const&,
Foam::word const&, Foam::word const&, Foam::List<foam::word> const&,
bool) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam::blockMesh::createTopology(Foam::IOdictionary &) in
#6 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in
#7 main in "/home/vishal/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/blockMesh"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#9 __gxx_personality_v0 in
From function polyMesh::facePatchFaceCells(const faceList&
patchFaces,const labelListList& pointCells,const faceListList&
cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 125.
FOAM aborting
Aborted
Kindly do the needful
Thanks
Regards
Vishal
Old   January 9, 2009, 14:30
Vishal Nandigana
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0.1)
(1 0 0.1)
(1 1 0.1)
(0 1 0.1)
(1 0.485 0)
(6 0.485 0)
(6 0.515 0)
(1 0.515 0)
(1 0.485 0.1)
(6 0.485 0.1)
(6 0.515 0.1)
(1 0.515 0.1)
(6 0 0)
(7 0 0)
(7 1 0)
(6 1 0)
(6 0 0.1)
(7 0 0.1)
(7 1 0.1)
(6 1 0.1)
blocks
edges
patches
patch inlet
(0 3 7 4)
patch outlet
(17 18 22 21)
patch upperwall
(2 3 7 6)
(18 19 23 22)
patch lowerwall
(4 5 1 0)
(20 21 17 16)
(14 10 11 15)
(11 2 6 15)
(10 19 23 14)
(12 13 9 8)
(1 8 12 5)
(16 9 13 20)
empty frontAndBack
(0 1 2 3)
(4 5 6 7)
(8 9 10 11)
(12 13 14 15)
(16 17 18 19)
(20 21 22 23)
mergePatchPairs
Creating block mesh
Creating blocks
Creating patches
FOAM aborting
Aborted
Thanks
Regards
Vishal
Old   January 9, 2009, 14:31
Vishal Nandigana
Horizontal block - Numbered as (8 9..15)
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0.1)
(1 0 0.1)
(1 1 0.1)
(0 1 0.1)
(1 0.485 0)
(6 0.485 0)
(6 0.515 0)
(1 0.515 0)
(1 0.485 0.1)
(6 0.485 0.1)
(6 0.515 0.1)
(1 0.515 0.1)
(6 0 0)
(7 0 0)
(7 1 0)
(6 1 0)
(6 0 0.1)
(7 0 0.1)
(7 1 0.1)
(6 1 0.1)
blocks
edges
patches
patch inlet
(0 3 7 4)
patch outlet
(17 18 22 21)
patch upperwall
(2 3 7 6)
(18 19 23 22)
patch lowerwall
(4 5 1 0)
(20 21 17 16)
(14 10 11 15)
(11 2 6 15)
(10 19 23 14)
(12 13 9 8)
(1 8 12 5)
(16 9 13 20)
empty frontAndBack
(0 1 2 3)
(4 5 6 7)
(8 9 10 11)
(12 13 14 15)
(16 17 18 19)
(20 21 22 23)
mergePatchPairs
Creating block mesh
Creating blocks
Creating patches
FOAM aborting
Aborted
Thanks
Regards
Vishal
Old   January 13, 2009, 04:05
Default Hi, in my opinion you can n
Wolfgang Heydlauff
in my opinion you can not only use 3 blocks for this problem. you might not use a block and attach another block to it without any further connection rules. in your solution you have the faces with double boundary conditions.
use at least 7 blocks. for this you have to insert more vertices. maybe you can work with one symmetryPlane horizontally through the middle. so you only had to change the coordinates and use 5 blocks.
another solution could be, you crearte 6 blocks. so they are also devided in the middle. and your connectionblock in the middle consists of 2 horizontal devided blocks.
i yould prefer the symmetryPlane solution.
good luck.
Old   January 13, 2009, 09:09
Default Yes, my mistake should have be
  #11
Sachin Kanetkar
Yes, my mistake should have been atleast 5, 3 was wrong ans
Old   January 13, 2009, 14:20
Default Hi Wolfgang and Sachin Than
  #12
Vishal Nandigana
Thanks for the information, I finished creating the geometry with 7 blocks and implemented it in the code, it is working fine at the moment. I would get back to you guys if I encounter any problem.
Thanks
Regards
Vishal
create turbine geometry with gambit badlaine ANSYS Meshing & Geometry 2 March 26, 2012 23:54
[Technical] What is the best option for create a mesh not using blockmesh titio OpenFOAM Meshing & Mesh Conversion 4 January 17, 2008 02:37
[blockMesh] Does blockMesh create mesh vertices in any particular order brooksmoses OpenFOAM Meshing & Mesh Conversion 3 December 12, 2005 20:26
how to create structured geometry Rashmi FLUENT 10 December 2, 2005 07:48
Create 2d geometry file with pro*am? raymond Siemens 1 December 13, 2001 10:31
