November 17, 2008, 10:49 |
Imposing a heat flux on a surf
#21 |
Pattyn Eric
Rep Power: 17 |
Imposing a heat flux on a surface is equivalent to impose the normal temperature gradient. (q=dT/dn)
Example: wall{ type fixedGradient; gradient 2; } |
November 17, 2008, 15:06 |
there is a bc on the wi
#22 |
Fabian Braennstroem
Rep Power: 19 |
November 18, 2008, 03:34 |
Hello Eric,
-> FOAM Warning :
#23 |
Hello Eric,
-> FOAM Warning : From function Field<type>::Field(const word& keyword, const dictionary& dict, const label s) in file /home/rkahraman/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 252 Reading "/home/rkahraman/OpenFOAM/rkahraman-1.5/run/tutorials/my_icoFoam/tube_1/0/T::fix edWalls" from line 25 to line 26 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. keyword outlet is undefined in dictionary "/home/rkahraman/OpenFOAM/rkahraman-1.5/run/tutorials/my_icoFoam/tube_1/0/T::bou ndaryField" file: /home/rkahraman/OpenFOAM/rkahraman-1.5/run/tutorials/my_icoFoam/tube_1/0/T::boun daryField from line 25 to line 39. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 271. FOAM exiting I have put the BC like your example but it gives me that message... |
November 18, 2008, 03:47 |
hi to all
someone could hel
#24 |
hi to all
someone could help me to how to use that fixedGradient BC? Best regards Emo |
November 19, 2008, 07:08 |
Emo: Read the error message. Y
#25 |
Ville Tossavainen
Rep Power: 17 |
Emo: Read the error message. You need to add word "uniform" after "gradient" and before the uniform value.
December 5, 2008, 13:08 |
Hi All,
I am new to Openfoa
#26 |
Vishal Nandigana
Rep Power: 18 |
Hi All,
I am new to Openfoam. I have a case where I need to set B.cs given by the equation -D1*dC1/dn - K1*C1*dPhi/dn = 0 where n is the normal direction. I am solving a 2d system hence I want to set the flux in the y direction as zero. i.e -D1*dC1/dy - K1*C1*dPhi/dy = 0 where C1 and Phi are my variables. I am solving coupled equations. I hope i will get some response. Can anyone suggest how exactly I have to go about incorporating this boundary condition. Kindly do the needful. Thanks Regards Vishal |
February 25, 2010, 03:38 |
fixed wall heat flux BC
#27 |
Rep Power: 17 |
are there any news or hints how to impose a boundary condition of fixed heat flux to walls in OF 1.6? Thanks!!!!!!! |
March 5, 2010, 19:33 |
Fast and Dirty Boundary Condition
#28 |
Vitor Geraldes
Rep Power: 16 |
One simple way to implement a mixed/Robin boundary condition consists in adding a source term to the scalar transport equation that is zero everywere, except in the control volumes adjacent do the selected patch. This is not a clean approach, but it works quite well.
March 21, 2011, 02:11 |
#29 | |
NieYongguang
Rep Power: 15 |
March 21, 2011, 06:22 |
groovyBC.
#30 |
Vitor Geraldes
Rep Power: 16 |
The best way to deal with this problem is to use the boundary-condition groovyBC. I have tried it in this type of BC and it works quite well. ( please see http://openfoamwiki.net/index.php/Contrib_groovyBC)
April 12, 2013, 16:55 |
#31 | |
George Pichurov
Rep Power: 15 |
December 31, 2013, 05:35 |
#32 | |
Peter
Rep Power: 14 |
try something like this:
August 29, 2017, 18:36 |
#33 |
Annonymouse
Rep Power: 8 |
Hi, Did you ever get a response for this? I realize this is coming pretty late
December 21, 2020, 05:59 |
#34 |
Tushar Survase
Rep Power: 5 |
Use externalWallHeatFluxTemperature in file T of 0 folder.
<patchName> { type externalWallHeatFluxTemperature; mode coefficient; Ta constant 300.0; h constant 10.0; thicknessLayers (0.1 0.2 0.3 0.4); kappaLayers (1 2 3 4); kappaMethod fluidThermo; value $internalField; } This is for convective heat transfer. Conductive heat transfer example is described below wall { type externalWallHeatFluxTemperature; mode flux; q uniform 1000; kappaMethod fluidThermo; value uniform 300.0; } I am using OF-v2006 version. |
ask a question about Fixed Flux Boundary Condition | mahe | Phoenics | 1 | July 15, 2008 04:21 |
match uds boundary condition in wall & wall-shadow | pour | FLUENT | 0 | May 20, 2008 08:56 |
Wall boundary condition – UDF | Ssn | FLUENT | 0 | January 25, 2008 03:43 |
wall boundary condition | woytex | Main CFD Forum | 1 | August 19, 2004 07:11 |
Wall boundary condition | Enda Bigarelli | Main CFD Forum | 1 | March 14, 2002 23:13 |
