Time step continuity
Like Tree23Likes
Old   October 29, 2007, 12:29
Default Hi Holger .. I am a new use
  #21
Nishant
nishant_hull is on a distinguished road
Hi Holger ..
I am a new user to Openfoam. i am also working on a cylindrical pipe flow geometry with water as fluid in icoFoam and simplefoam module. The problem consist of a circular face as a inlet and another face as a outlet. (see p and U file at the end)
My pre-compiled OpenFoam was working fine for the tutorial problems but now with my current cylinderical pipe problem, this is give some error:
error is:
#0 Foam::error::printStack(Foam: :-Ostream&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/343880/OpenFOAM/OpenFOAM- 1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0x110420]
#3 void Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::Field<foam::vector<double> >&, Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#5 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::tmp<foam::geometricfield<foam::vector<doub le>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#6 Foam::fv::gaussDivScheme<foam::tensor<double> >::fvcDiv(Foam::GeometricField<foam::tensor<double >, Foam::fvPatchField, Foam::volMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#7 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so"
#8 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so"
#9 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::tmp<foam::geometricfield<foam::tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so"
#10 Foam::turbulenceModels::kEpsilon::divR(Foam::Geome tricField<foam::vector<double> , Foam::fvPatchField, Foam::volMesh>&) const in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so"
#11 main in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam"
#12 __libc_start_main in "/lib/libc.so.6"
#13 Foam::regIOobject::readIfModified() in "/home/343880/OpenFOAM/OpenFOAM- 1.4.1/applications/bin/linuxGccDPOpt/simpleFoam"
Floating point exception
The files, i am using are listed below:
1. transportproperties:
transportModel Newtonian;
nu nu [0 2 -1 0 0 0 0] 0.89;
CrossPowerLawCoeffs
nu0 nu0 [0 2 -1 0 0 0 0] 0.89;
nuInf nuInf [0 2 -1 0 0 0 0] 0.89;
m m [0 0 1 0 0 0 0] 1;
n n [0 0 0 0 0 0 0] 1;
BirdCarreauCoeffs
k k [0 0 1 0 0 0 0] 0;
2. blockMeshDict
arguments "/home/343880/OpenFOAM/343880-1.4.1/run/tutorials/icoFoam/pipeflow" off;
convertToMeters 0.01;
vertices
(0.3 0 0)
(0 0.3 0)
(-0.3 0 0)
(0 -0.3 0)
(1 0 0)
(0 1 0)
(-1 0 0)
(0 -1 0)
(0.3 0 10)
(0 0.3 10)
(-0.3 0 10)
(0 -0.3 10)
(1 0 10)
(0 1 10)
(-1 0 10)
(0 -1 10)
blocks
hex (0 1 2 3 8 9 10 11) (10 10 20) simpleGrading (1 1 1)
hex (0 1 5 4 8 9 13 12) (10 10 20) simpleGrading (1 1 1)
hex (1 2 6 5 9 10 14 13) (10 10 20) simpleGrading (1 1 1)
hex (2 3 7 6 10 11 15 14) (10 10 20) simpleGrading (1 1 1)
hex (3 0 4 7 11 8 12 15) (10 10 20) simpleGrading (1 1 1)
edges
arc 4 5 (0.866 0.5 0)
arc 5 6 (-0.866 0.5 0)
arc 6 7 (-0.866 -0.5 0)
arc 7 4 (0.866 -0.5 0)
arc 12 13 (0.866 0.5 40)
arc 13 14 (-0.866 0.5 40)
arc 14 15 (-0.866 -0.5 40)
arc 15 12 (0.866 -0.5 40)
patches
wall fixedWalls
(4 5 13 12)
(5 6 14 13)
(6 7 15 14)
(7 4 12 15)
patch inlet
(0 3 2 1)
(0 4 7 3)
(0 1 5 4)
(1 2 6 5)
(2 3 7 6)
patch outlet
(8 9 10 11)
(8 11 15 12)
(9 8 12 13)
(10 9 13 14)
(10 14 15 11)
mergePatchPairs
3. p file
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
fixedWalls
type zeroGradient;
4. U file
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 0 10.005);
outlet
type zeroGradient;
fixedWalls
type fixedValue;
value uniform (0 0 0);
I saw your blogs on discussion group and i was glad to know that you could be able to run the same problem succesfully. I hope you could be able to guide me in this regard.
I look forward to hearing from you soon.
Nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   October 31, 2007, 11:23
Default My problem is now fixed..!! ht
  #22
Nishant
My problem is now fixed..!! []
Thanks and regards,
Nishant
Old   February 7, 2008, 20:35
Default Dear Foamers, when I use my g
  #23
Danielle PRL
danielle is on a distinguished road
Dear Foamers,
when I use my geometry in Fluent 6.3 with one or two phases I have a realistic result. In O.Foam 1.4.1 neither with turbFoam nor with twoPhaseEulerFoam gives a good (realsitic) result. when I check my mesh, I get the following message:
Time = constant
Mesh stats
edges: 1088715
faces: 1277556
internal faces: 1211202
cells: 492171
boundary patches: 13
point zones: 0
face zones: 0
cell zones: 2
Number of cells of each type:
hexahedra: 257595
prisms: 0
wedges: 0
pyramids: 4884
tet wedges: 0
tetrahedra: 229692
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Topological cell zip-up check OK.
Face vertices OK.
Number of identical duplicate faces (baffle faces): 11380
Face-face connectivity OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface
wall_cylin_int_Pied 22752 10349 multiply connected surface (shared edge)
wall_cylin_ext_G 8448 8624 ok (not multiply connected)
wall_capt_inlet_G 960 980 ok (not multiply connected)
inlet3 142 76 ok (not multiply connected)
inlet2 140 75 ok (not multiply connected)
outlet 25 33 ok (not multiply connected)
Wall_top 2653 2755 ok (not multiply connected)
inlet1 78 43 ok (not multiply connected)
wall_buttom 2669 1406 ok (not multiply connected)
wal_capt_inlet_F 873 685 ok (not multiply connected)
wall_cylin_inter 809 420 multiply connected surface (shared edge)
wall_cylin_ext_F 24925 19277 ok (not multiply connected)
wall_disc_inlet 1880 949 ok (not multiply connected)
<<Writing 10349 conflicting points to set nonManifoldPoints
Checking geometry...
Domain bounding box: (-0.139998 -0.139998 -8.61533e-16) (0.139998 0.139997 0.99)
Boundary openness (-1.08376e-17 2.8904e-17 -1.39722e-16) OK.
Max cell openness = 1.66038e-15 OK.
Max aspect ratio = 21.4331 OK.
Minumum face area = 1.22452e-07. Maximum face area = 8.99153e-05. Face area magnitudes OK.
Min volume = 2.74672e-11. Max volume = 2.55601e-07. Total volume = 0.0347228. Cell volumes OK.
Mesh non-orthogonality Max: 84.9996 average: 12.6589
*Number of severely non-orthogonal faces: 49.
Non-orthogonality check OK.
<<Writing 49 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 1.33507 OK.
Min/max edge length = 0.000218421 0.0171268 OK.
All angles in faces OK.
Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 0.995346
All face flatness OK.
Mesh OK.
End
1. which value should I give to nNonOrthogonalCorrectors in fvSolution ?
2. Is my mesh the problem ?(when I use 1.4 version alot of error appear in checkMesh).
thank you for help
danielle is offline   Reply With Quote
Old   July 23, 2008, 07:22
Default hi to all group, i have one
  #24
Edwin Gonzalez
edwin_gonzalez is on a distinguished road
hi to all group,
i have one question:
what so important are the time step continuity errors in a steady state simulation?
what happen if they are big?
edwin
edwin_gonzalez is offline   Reply With Quote
Old   November 25, 2008, 02:48
Default I have the same problem with a
  #25
emilianyassenov
I have the same problem with anja I have done the steps above and I have following error
Time = 0.0001
Courant Number mean: 0 max: 9.2665e-08
DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 4.2086e-16, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
Unknown symmetric matrix solver AMG
Valid symmetric matrix solvers are :
4
ICCG
smoothSolver
PCG
GAMG
file: /home/rkahraman/OpenFOAM/rkahraman-1.5/run/tutorials/project/shape/system/fvSolu tion::p at line 20.
From function lduMatrix::solver::New
in file matrices/lduMatrix/lduMatrix/lduMatrixSolver.C at line 78.
FOAM exiting
someone can help me?
Emo
Old   November 25, 2008, 03:48
Default hi I am using last version
  #26
emilianyassenov
hi
I am using last version of OpenFOAM and also IcoFoam but that instructions above not working in my case I have a problem with AMG solver...
Emo
Old   November 25, 2008, 03:51
Default The AMG solver does not exist,
  #27
ep4
Pattyn Eric
ep4 is on a distinguished road
The AMG solver does not exist, the error message says that you can to use the GAMG solver to solve symmetric matrix.
Just add the G befor AMG in the system/fvSolution file.
ep4 is offline   Reply With Quote
Old   November 25, 2008, 04:04
Default hi I did add G but it is no
  #28
emilianyassenov
hi
I did add G but it is not working as well
then I had that
keyword agglomerator is undefined in dictionary "/home/rkahraman/OpenFOAM/rkahraman-1.5/run/tutorials/project/shape/system/fvSol ution::p"
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 213.
Emo
Old   November 25, 2008, 04:05
Default where I must add "agglomerator
  #29
emilianyassenov
where I must add "agglomerator"
any suggestion
thanks Emo
Old   April 10, 2017, 02:18
Viraj Belekar
viraj20feb is on a distinguished road
Originally Posted by hjasak View Post
Yup. Put zero gradient on the pressure and the continuity error will go away. The fixed gradient b.c. gives you additional flux which is not accounted for in the continuity equation.
Hrv
I am getting a similar error. I am trying to simulate a steady state laminar flow in 5mm diameter cylindrical pipe. I have attached my log file, p, U, fvSchemes and fvSolution files. Please help.
Regards
Viraj
viraj20feb is offline   Reply With Quote
Old   February 24, 2018, 01:22
Default timestep calculation
  #31
gouravjee is on a distinguished road
can anyone tell me hot to access current and old timesteps ?
gouravjee is offline   Reply With Quote
Old   February 24, 2018, 01:23
Default timestep
  #32
Regards
Viraj
Old   February 26, 2018, 10:41
Viraj Belekar
OpenFOAM creates folders to write data for current and previous timesteps. You can access your data in the particular folder. Also you can use the following command to make a log file for your simulations:
command | tee log
Old   March 5, 2019, 06:06
Default how did you solve your problem
  #34
SHUBHAM ONAVE
oshubham is on a distinguished road
Hi Nishant can you tell me how did you tackle your time step continuity error.
Thanks in advance.
oshubham is offline   Reply With Quote
Old   May 1, 2019, 21:56
Unhappy Same problem with SIMPLE
  #35
sam zou
zzou1@uci.edu is on a distinguished road
Dear all,
I am new to openfoam and I am trying to solve an asymmetric jet flow in free stream and my results are not satisfying.
smoothSolver: Solving for Ux, Initial residual = 0.000508293, Final residual = 3.21941e-06, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.000940431, Final residual = 4.81773e-06, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.0107984, Final residual = 7.2382e-05, No Iterations 3
GAMG: Solving for p, Initial residual = 0.00121237, Final residual = 7.15837e-05, No Iterations 2
time step continuity errors : sum local = 5.58531e-05, global = 1.58563e-05, cumulative = 0.0521039
smoothSolver: Solving for epsilon, Initial residual = 0.000275732, Final residual = 1.74389e-06, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.000345624, Final residual = 2.17518e-06, No Iterations 4
The following is my fvscheme and fvsolution
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind limited;
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,R) bounded Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) bounded Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited 1;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
solvers
p
solver GAMG;
tolerance 1e-07;
relTol 0.1;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
"(U|k|epsilon|R|nuTilda)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-07;
relTol 0.01;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-4;
Ux 1e-4;
Uy 1e-4;
//U
"(k|epsilon)" 1e-4;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
Please help! Thank you!!!
zzou1@uci.edu is offline   Reply With Quote
Old   August 22, 2019, 17:56
Default Very large continuity error
  #36
Chris Harding
HappyS5 is on a distinguished road
How big are they? They are related to the pressure solver tolerance and you should be able to squeeze them by converging the pressure more tightly. If this doesn't work, you've probably messed up the boundary conditions.
Hrv
I have checked my boundary conditions.
Velocity: inlet: fixedValue, uniorm (0 0 25); outlet: zeroGradient; all walls: fixedValue uniform (0 0 0);
Pressure: inlet: zeroGradient; outlet: uniform 0; all walls: zeroGradient;
My continuity errors: were x.xe+35 or more.
I tightened the relTol of pressure to 1e-06 in hopes that the errors would get under control.
The flow is very turbulent.
Any suggestions on how to get continuity errors under control?
HappyS5 is offline   Reply With Quote
Old   August 22, 2019, 19:18
Default Is time step a valid way to drop continuity errors
  #37
Chris Harding
I have read that reducing the time step will reduce continuity errors. Is the latter physically accurate or is it a false fix that just makes the simulation run "look" good.
Please forgive me for the ignorant question. I am new, don't know the code, and I am trying to learn about how to increase accuracy. I changed the timeStep and my continuity dropped to the range of x.xe-07 and -x.xe-07. I also changed my fvSchemes though.
Still, the continuity errors dropped, during the previous run, when I changed the timeStep in the controlDict.
Old   June 22, 2020, 11:16
Default Continuity Error
  #38
Himanshu
Himanshu_Shrivastava is on a distinguished road
Hello ,
Can anyone explain what is the difference between sum local ,global and cumulative in continuity error.
Eg.: "time step continuity errors : sum local = 0.043, global = 1.13e-007, cumulative = 1.33e-007"
and Which one we have to check for deciding convergence?
P.S.: I am coming from Fluent background where we only see one value of continuity residue.
Thanks
Himanshu_Shrivastava is offline   Reply With Quote
SimpleFoam and Time Step continuity errors philippose OpenFOAM Running, Solving & CFD 64 September 13, 2023 10:26
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
SELECTING TIME STEP SIZE, NUMBER OF TIME STEP NITUL KALITA FLUENT 2 November 22, 2012 08:28
Long time CHT transient simulation time step.... JP CFX 0 May 9, 2008 03:36
Relation of computational time step with real time Salman Main CFD Forum 2 August 3, 2005 14:13
