How to open a old file for APPEND
Like Tree3Likes
Old   March 27, 2006, 18:08
Default I need to restart the solver a
liu
Xiaofeng Liu
liu is on a distinguished road
I need to restart the solver at some point. Also I write out some log information for postprocessing.
My question is how can I open the old log file to APPEND new lines?
Now I am using:
//outlet concentration log file
if(!dir(runTime.path()/"outletAlpha")) //if the directory doesn't exist
mkDir(runTime.path()/"outletAlpha");
OFstream outlet1AlphaFile(runTime.path()/"outletAlpha"/"outlet1AlphaLog.dat");
outlet1AlphaFile << bla bla bla
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   March 28, 2006, 08:33
Default Have a look at stream handling
Hrvoje Jasak
hjasak will become famous soon enough
Have a look at stream handling in C++ - there's a flag you can set wehn opening a stream for append.
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   March 28, 2006, 12:00
Default Google "ifstream C++" //o
Eugene de Villiers
eugene is on a distinguished road
//open file for append
ifstream someStreamName(filename, ios_base::app);
eugene is offline   Reply With Quote
Old   June 20, 2006, 08:51
Default Hello I used OFstrean myFil
Aurelia Cure
aurelia is on a distinguished road
Hello
I used
OFstrean myFile(file,ios_base::app)
but get the error "
error: no matching function for call to 'Foam:: OFstream:: OFstream(Foam::fileName&, const std::_Ios_Openmode&)'
/home/aurelia/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/OFstream.H:107: note: candidates are: Foam:: OFstream:: OFstream(const Foam::fileName&, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType)
/home/aurelia/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/OFstream.H:86: note: Foam:: OFstream:: OFstream(const Foam:: OFstream&)
Should I add something in lnInclude/OFstream.H ?
Thanks
Aurelia
aurelia is offline   Reply With Quote
Old   June 20, 2006, 11:47
Default Problem is that the Foam strea
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Problem is that the Foam streams (OFstream,IFStream) look a lot like the standard C++ file-streams (ifstream, ofstream) but are not capable of all the things the std-streams are: for instance appending. When you look at the Doxygen info for OFstream you will find that it doesn't take the ios_base-Parameters.
I guess that is because the Foam-streams are capable of orderly output during parallel computations. The std-streams aren't. So if you need appending use the std::ofstream, it should work as well as long as you don't plan to run your program in parallel.
Note: if I am wrong could someone who has actually looked at the IO-code correct me?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   June 20, 2006, 17:45
Default There's still absolutely nothi
Hrvoje Jasak
There's still absolutely nothing stopping you from making a plain old ofstream and working with that. In fact, the streams will swallow the on-the-fly stream modifiers, but the constructor for append is not there. If you'd really like one, I will add it for you.
The additional stuff will sit in /db/IOstreams/Fstreams/OFstream.H and .C and it's pretty straightforward. Not sure what happens with the ogzstreams (compressed data), but there must be a way out...
Hrv
Hrvoje Jasak
Old   June 21, 2006, 02:20
Default Bernhard and Hrvoje, thanks fo
Aurelia Cure
Bernhard and Hrvoje, thanks for your reply
Hrvoje, if you have time to do it, I will appreciate if you could add this constructor for appending because for me, it is far to be straightforward!
Aurelia
Old   June 21, 2006, 05:55
Default I needed the same option. What
Maka Mohu
maka is on a distinguished road
I needed the same option. What I do is a simple solution. I log the new run in log.2 file and then append it from linux when I finish the simulation (or before) by log.2 >> log.1 linux command.
regards,
Maka.
maka is offline   Reply With Quote
Old   June 21, 2006, 18:57
Default OK, it looks like this, using
Hrvoje Jasak
OK, it looks like this, using the stream modifier on construction - the one below opens the file for append:
OFstream of("hello", ios_base::app);
of << 0 << nl << 1 << nl << 2 << endl;
I changed 3 files, all in the main library:
OFstream.H
OFstream.C
regIOobjectWrite.C
You will, of course, need to rebuild the whole thing. The files are attached below hrvsStreams.tgz
Enjoy,
Hrv
Hrvoje Jasak
Old   June 22, 2006, 04:40
Default Hrv, Thank you for the files!
Aurelia Cure
Hrv,
Thank you for the files! It really helps me.
Aurelia
Old   November 23, 2007, 10:43
Default Dear forum, I would like al
  #11
Cedric DUPRAT
cedric_duprat is on a distinguished road
Dear forum,
I would like also to play with OFstream. cause I would like to print every timestep in one file a value of one home-made parameter.
Is there any thing to modified in Hrvoje.tgz for 1.4.1 version of Foam ?
I ask this because I had some error message when compiling ...
It's just to know if I made a mistake some where or, if I have to change something.
I copy the OFstream .C and .H at the right place, samething for regIOobjectWrite.C but, when compiling, I got some error.
Thank you,
Cedric
cedric_duprat is offline   Reply With Quote
Old   November 23, 2007, 11:42
Default Hi again, it's ok now, I for
  #12
Cedric DUPRAT
Hi again,
it's ok now, I forgot to add the files in lnInclude :o)
sorry for the disturbance
Cedric
Old   November 23, 2007, 11:53
Default Well, this is precisely the re
  #13
Hrvoje Jasak
Well, this is precisely the reason why we support an open SVN development line: every time you get stuck, you can just go there and see what I've dome to keep the code working between versions.
Enjoy,
Hrv
Hrvoje Jasak
Old   November 23, 2007, 11:57
Default well, that's right, I get it f
  #14
Cedric DUPRAT
well, that's right, I get it for future problems
Thanks,
Cedric
Old   November 12, 2008, 12:52
Default Hi, I tried this with openf
  #15
John Deas
johndeas is on a distinguished road
I tried this with openfoam 1.5 :
std::ofstream wallStress
runTime.path()/"wallStress",
ios_base::app
but got this error message:
channelStress.C:75: error: no matching function for call to 'std::basic_ofstream<char,> >::basic_ofstream(Foam::fileName, const std::_Ios_Openmode&)'
/home/flurec/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../lib/gcc/i686-p c-linux-gnu/4.3.1/../../../../include/c++/4.3.1/fstream:572: note: candidates are: std::basic_ofstream<_chart,>::basic_ofstream(const char*, std::_Ios_Openmode) [with _CharT = char, _Traits = std::char_traits<char>]
/home/flurec/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../lib/gcc/i686-p c-linux-gnu/4.3.1/../../../../include/c++/4.3.1/fstream:556: note: std::basic_ofstream<_chart,>::basic_ofstream() [with _CharT = char, _Traits = std::char_traits<char>]
/home/flurec/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../lib/gcc/i686-p c-linux-gnu/4.3.1/../../../../include/c++/4.3.1/iosfwd:89: note: std::basic_ofstream<char,> >::basic_ofstream(const std::basic_ofstream<char,> >&)
make: *** [Make/linuxGccDPOpt/channelStress.o] Error 1
Anybody know how to fix this ? I wouldn't want to modify the OFstream source files as proposed in this thread.
johndeas is offline   Reply With Quote
Old   April 19, 2009, 16:09
Mark Couwenberg
markc is on a distinguished road
Hello John,
I had the same struggle. It's because ofstream needs the filename either directly entered or as a pointer variable of type const char*. Well, that's nice to know but I also do not know how to work around it. Maybe someone else?
Brgds,
Mark
markc is offline   Reply With Quote
Old   July 2, 2009, 14:34
Cem Albukrek
albcem is on a distinguished road
Hello Mark,
It seems our paths cross quite often when it comes to problems. In case you do not yet have an answer to your problem, here is a dirty work around I have discovered:
The problem with using ofstream is, as you said, the requirement to pass a "char*" type as file name. But how do you extract "char*" from "word" which we predominantly use in OpenFOAM?
word MyWord = "testing"
stringstream MyStrStream;
char* MyChar;
MyStrStream << MyWord;
MyChar = MyStrStream.str().c_str();
I hope this helps.
Best,
Cem
albcem is offline   Reply With Quote
Old   September 28, 2009, 09:42
John Deas
Maybe I haven't understood basic things about pointers, but when you create:
char* MyChar;
and then assign it
aren't you writing in memory chunks you do not control (since no specific amount of memory is allowed to the char*) ?
I also tried this way:
std::stringstream MyStrStream;
MyStrStream << runTime.path()/"wallStress";
    MyStrStream.str().c_str(),
    ios_base::app
and get that as a result:
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/LListIO.C: In function ‘Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::LList<LListBase, T>&) [with LListBase = Foam::SLListBase, T = Foam::SymmTensor<double>]’:
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/LListIO.C:51: internal compiler error: Segmentation fault
I also got a segmentation fault with:
string MyStrStream(runTime.path()/"wallStress");
    MyStrStream.c_str(),
    ios_base::app
So, at that point any help would be appreciated ! Thanks !
Old   June 14, 2010, 03:48
Default Cannot download the files...
  #19
Jens Johansson
jensjo is on a distinguished road
HI
I am really interested in the files posted here. But when I am not able to download them... I get a *.unk file instead. Any help?
Kind regards
Jens Johansson
OFstream.H
OFstream.C
regIOobjectWrite.C
Enjoy,
Hrv
jensjo is offline   Reply With Quote
Old   June 14, 2010, 08:21
Victor Fleischer
Victor is on a distinguished road
I tried it with different versions, but finally it works with
#include <iostream>
using namespace std;
fileName myDir = runTime.path();
word tracingFileName="TestName"
fileName myFile = myDir/tracingFileName;
std:: ofstream myStream(myFile.c_str(),ios_base::app);
I know, there would be an shorter version, but i just copied these lines out of my solver.
I do not know if you really have to include <iostream>, i did not test it!
Victor
ayhan515 and waiter120 like this.
Victor is offline   Reply With Quote
how to open a cas file in gambit Michal K FLUENT 5 March 14, 2009 16:37
FORTRAN(OPEN->APPEND) kris Siemens 1 November 30, 2004 07:57
where to open the file jx FLUENT 0 February 19, 2004 12:19
Scheme: append to existend file Ingolf FLUENT 0 November 10, 2003 05:27
append data to a file Wen Long Main CFD Forum 1 April 11, 2002 20:45
