Adding centrifugal force
Old   May 19, 2010, 07:24
Default Adding centrifugal force
Gearb0x is on a distinguished road
Dear Foamers,
I'm running a simulation of a duct using simpleFoam.
I would like to add centrifugal force acting on the duct due to its rotation in the model.
Is there an easy way to do this in openfoam with my solver? Where could I find information? (checked on the forum but didn't find anything)
Thanks for your help
Gearb0x is offline   Reply With Quote
Old   May 20, 2010, 13:06
Ok after some research, it seems there are two ways :
-MRFSimpleFoam
-SimpleSRFFoam
SimpleSRFFoam could be suitable but apparently you cannot set the coordinate of the rotation axis ...
Does anyone suceeded in makin these solvers working with something else than a propeller, compressor, ... ?
In fact I just want my whole geometry to rotate with a certain angular speed...
Old   May 20, 2010, 16:32
Here we go for a detailed explanation of my case, what I have, what I want
:::::: Geometry : (2D for now but final will be 3D) ::::::
http://yfrog.com/09geometryp
Very Simple : inlet, outlet, fixedWalls (2D)
I've defined my 6 faces as "rotor" since I want all my geometry to rotate
:::::: Solver, boundary conditions, ... ::::::::
solver : MRFSimpleFoam
turbulence model : LaunderSharmaKE
RANS
Boundary conditions :
k
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.2646;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.2646;
    outlet
        type            zeroGradient;
    fixedWalls
        type            fixedValue;
	value		uniform 1e-06;
    frontAndBackPlanes
        type            empty;
epsilon
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 4.26;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 4.26;
    outlet
        type            zeroGradient;
    fixedWalls
        type            fixedValue;
    frontAndBackPlanes
        type            empty;
nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    fixedWalls
        type            nutWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    frontAndBackPlanes
        type            empty;
p
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    fixedWalls
        type            zeroGradient;
    inlet
	type		zeroGradient;
    outlet
        type           fixedValue;
	value          uniform 0;
    frontAndBackPlanes
        type            empty;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    fixedWalls
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            zeroGradient;
    inlet
        type            fixedValue;
	value		nonuniform List<vector>
50
         (0  0.2906        0)
         (0  0.9366        0)
         (0   1.7184        0)
         (0   2.5785        0)
         (0   3.3476        0)
         (0   3.9615        0)
         (0   4.4557        0)
         (0   4.8674        0)
         (0   5.2249        0)
         (0   5.5473        0)
         (0   5.8476        0)
         (0   6.1343        0)
         (0   6.4138        0)
         (0   6.6906        0)
         (0   6.9686        0)
         (0   7.2508        0)
         (0   7.5400        0)
         (0   7.8379        0)
         (0   8.1440        0)
         (0   8.4518        0)
         (0   8.7389        0)
         (0   8.9583        0)
         (0   9.0807        0)
         (0   9.1344        0)
         (0   9.1541        0)
         (0   9.1541        0)
         (0   9.1344        0)
         (0   9.0807        0)
         (0   8.9583        0)
         (0   8.7389        0)
         (0   8.4518        0)
         (0   8.1440        0)
         (0   7.8379        0)
         (0   7.5400        0)
         (0   7.2508        0)
         (0   6.9686        0)
         (0   6.6906        0)
         (0   6.4138        0)
         (0   6.1343        0)
         (0   5.8476        0)
         (0   5.5473        0)
         (0   5.2249        0)
         (0   4.8674        0)
         (0   4.4557        0)
         (0   3.9615        0)
         (0   3.3476        0)
         (0   2.5785        0)
         (0   1.7184        0)
         (0  0.9366        0)
         (0  0.2906        0)
    frontAndBackPlanes
        type            empty;
As you can see, I start with a profile. In fact these BC are in the same as in my stationnary case since I want everything to be the same EXCEPT that it's rotating with a specified velocity.
Now about MRF settings :
MRFZones
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      MRFZones;
1
    rotor
        // Fixed patches (by default they 'move' with the MRF zone)
        nonRotatingPatches ();
        origin    origin [0 1 0 0 0 0 0]  (0 -0.3 0.0375);
        axis      axis   [0 0 0 0 0 0 0]  (0 0 1);
        omega     omega  [0 0 -1 0 0 0 0] 10;
origin is like this because : I want axis of rotation to @center on Z and X and below my duct (y position)
Axis of rotation is Z
I set low speed to be "easy" on beginning.
I've done nothing else. Mesh was generated with gambit with, like I said, fluid zone set as "rotor" and exported via fluentMeshToFoam -writeSets -writeZones.
Now when I make MRFSimpleFoam, it's working but solutions are very weird. See velocity field and pressure field :
pressure : http://yfrog.com/14pfieldp
velocity : http://yfrog.com/6luyfieldp
vector field : http://yfrog.com/j1vectorrp
What do you think? To me solution is weird ... but vector field seems to take rotation into account... But inlet BC seems not since vecor field near the inlet is shifted to the left since the beginning of the duct...
Could you please help me? Where am I wrong?
Thank you for the help
Convergence for Ux,Uy,p is OK (10^-6) but k and epsilon say @10^-3
Centrifugal force/ Rotating Wall david FLUENT 4 January 2, 2014 06:30
Centrifugal force !!?? imbesh ANSYS 2 April 1, 2010 18:32
Adding Van der Waals force by coding UDF Long Sang FLUENT 1 June 23, 2008 07:44
cyclone separator- centrifugal force kumar FLUENT 2 May 29, 2008 03:33
MRFZonesC questions what is the mesh_V and why only Coriolis force no centrifugal force waynezw0618 OpenFOAM Running, Solving & CFD 49 April 8, 2008 04:23
