Time and Variable Dependent boundary conditions.
Like Tree1Likes
  • 1 Post By alvora
Old   July 16, 2012, 09:42
Default Time and Variable Dependent boundary conditions.
Alpesh
alvora is on a distinguished road
Hello everyones,
I want to implement new boundary conditions for electrohydrodynamics flow..
There is a conductive plate which is immersed in unipolar charge flow..
I want boundary condition as below on conductive plate surface..
d(Voltage)/dn=(chargeDensity)/epsilon,
where, voltage and charge density are variables parameter and epsilon is constant dimension scalar..
d/dn is normal gradient to surface..
for voltage and charge density, equations are separate.. But, voltage boundary condition on plate surface is depended on charge density...
Can any one tell me that How I can implement?
Thanx in advance
alpesh
alvora is offline   Reply With Quote
Old   July 16, 2012, 12:36
Assistant Moderator
Bernhard Gschaider
Originally Posted by alvora View Post
Hello everyones,
Thanx in advance
alpesh
If the chargeDensity does not change you can do it with fixedGradient. Otherwise I'd (but that is me) use groovyBC with fractionExpression "0" and a gradientExpression
Old   July 16, 2012, 17:32
Alpesh
Hello Bernhard Gschaider,
Thank you very much for reply..
In my case, chargeDensity is also changing with time... I thought to do with groovyBC.. but I dont know how to do in openfoam210.. n moreover I don't know how to implement normal gradient in groovyBC. Because, New voltage surface gradient is equal to chargeDensity/epsilon.. I dont know what to do with d/dn?
Can I consider as new voltage on boundary patch is equal to new_chargeDensity/(epsilon*patch.deltaCoeffs()) ?
Kind Regards
Alpesh
Old   July 16, 2012, 17:41
Alpesh
I also tried with this way.. but don't know that is it correct or not?
I put below code in one header file and make link with source file in time loop..
label phifreePatchID = mesh.boundaryMesh().findPatchID("phifreeplate");
//label patchId=patch().boundaryMesh().lookupPatchID(patch Name);
fvPatchScalarField& rho_CD = rhoCharge.boundaryField()[phifreePatchID];
fvPatchScalarField& platevoltage = voltage.boundaryField()[phifreePatchID];
const fvsPatchVectorField& centre = mesh.Cf().boundaryField()[phifreePatchID];
const fvsPatchVectorField& normal = mesh.Sf().boundaryField()[phifreePatchID];
//const surfaceScalarField& delta = mesh.boundaryMesh()[phifreePatchID].snGrad();
const polyPatch& cPatch = mesh.boundaryMesh()[phifreePatchID];
scalar patchArea = 0.0;
scalar r_charge =0.0;
forAll(cPatch, faceI)
patchArea += mesh.magSf().boundaryField()[phifreePatchID][faceI];
r_charge += rhoCharge.boundaryField()[phifreePatchID][faceI];
forAll (platevoltage, faceI)
platevoltage[faceI]= r_charge/(patchArea);
I wrote last equations as:
platevoltage[faceI]= r_charge/(epsilon0*patchArea*mesh.boundaryMesh()[phifreePatchID].snGrad());
and instead of snGrad, I also used .deltaCoeffs(), but I got error in both case..
Can you tell me that this type of way is correct or not? and what mistake I am doing in code?
Thank in advance
kind Regards
Alpesh
Old   July 17, 2012, 18:49
Assistant Moderator
Bernhard Gschaider
Kind Regards
Alpesh
Normal gradient in groovyBC: that's what I explained in the other posting: set fractionExpression to 0 and you have a pure fixedGradient condition (see definition of the mixed-BC).
d/dn: fixedGradient is always defined in the normal direction of the patch. So you already have that
Old   July 18, 2012, 06:26
Alpesh
Hi Bernhard Gschaider,
Thank you very much for reply,
I implemented as below:
phifreeplate
type groovyBC;
gradientExpression "(rhoCharge/epsilon)";
variables "rhoCharge@phifreeplate=sum(rhoCharge*mag(Sf() ))/sum(mag(Sf()));epsilon=8.8541e-12;";
value uniform 0;
fractionExpression "0";
Can you tell me that is this correct or not, please?
Kind Regards
Alpesh VORA
mm.abdollahzadeh likes this.
Old   July 18, 2012, 10:02
Assistant Moderator
Bernhard Gschaider
phifreeplate
type groovyBC;
value uniform 0;
Kind Regards
Alpesh VORA
You're calculating a local variable rhoCharge (BTW: you can omit the @phifreeplate) that is the weighted average of a field rhoCharge. Is that what you want?
From what I understand you might want to skip that variable altogether (variables "epsilon=8.8541e-12;" to get an inhomogenous gradient
Old   July 19, 2012, 09:15
Alpesh
Yes, I need average chargeDensity of only phifreeplates. I mean, a total charge which deposited on phifreeplate divide by total area of phifree plate..
question is: does above BC only calculating charge on phifree plate or whole domain?
Can you tell me last thing again, please? i didn't get why I should have to skip epsilon variable, please?
Kind Regards
A
Old   July 19, 2012, 20:29
Assistant Moderator
Bernhard Gschaider
Kind Regards
A
If I get your verbal explanation right, then your original formula is right. Although I'm not convinced that it makes sense physically: because I think that the d/dn on each face of the patch depends on the amount of charge on that face (and not on the others . in extreme: one face has all the charges and the others have none: then the solution would be different than from the case where you average the charge onto all the other faces: which is what you're proposing)
In short: groovyBC/swak take no responsibility that you got the physics right. That's on you
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Time dependent boundary conditions Renaud FLUENT 2 June 21, 2006 19:44
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
