Pressure BCs for rasInterFoam tank fillingdraining problem
Old   August 29, 2008, 09:40
Default I am relatively new to OF and
Kent Wardle
kwardle is on a distinguished road
I am relatively new to OF and have been working for some time on a tank filling/draining problem using rasInterFoam. The basic geometry is a symmetrical rectangular tank with a side inlet and a bottom drain and the top surface is open to atmosphere to allow the liquid level to equilibrate based on the inlet flow conditions.
I am not sure which boundary conditions are appropriate particularly for pressure. Starting from a 2d case, I was able to determine that the only BCs for pd that would allow the liquid level to drop when the inlet flow was zero (tank draining only) is gammaFixedPressure on the top surface and the bottom outlet. However, when I went to 3D, the simulation crashes after just a few iterations with velocity spikes (and/or unbounded epsilon) at the liquid interface. The initial gamma field was a half full [or half empty ;-)] tank. By accident, I found that if I start the simulation with the gravity vector off-normal relative to the liquid interface (and all upwind) and gradually shift it back to normal the solution proceeds but ONLY when there is inflow. It dies when there is no liquid inflow. Even the simulation that seems to go ends up with very strange behavior on the upper surface (where there could be flow of air inward or outward). Here the pd file at a time after startup shows very strange things for the "p" profile (discontinuous pressures of 1e-315) but the "value" profile is reasonable and smooth.
My questions:
(1) What boundary conditions should I be using for this problem? Specifically, is gammaFixedPressure appropriate? If so, what do I need to specify? For example for the top surface for pd:
top
type gammaFixedPressure;
U U;
phi phi;
rho none;
psi none;
gamma 1;
p uniform 0;
value uniform 0;
Is this correct for the upper surface (open to atmosphere)? What do the lines for U, phi, rho, psi, and gamma mean? There was no explanation of this BC type anywhere so I copied the input format from totalPressure examples.
(2) Why does the simulation have trouble starting with a stationary interface that is normal gravity? Why the differt solution behavior between 2D and 3D?
(3) Why in the pd files for later time steps are there boundary values for both "p" and "value" on the top surface, what exactly are these describing? Incidentally, the outlet remains as "uniform 0" for both "p" and "value". I assume this is because there is no backflow.
I apologize for the lengthy post, but I have been beating my head against this problem for some time and could really use some help. If I am missing something basic that is explained somewhere else PLEASE let me know--I have read many many other threads and tried to find answers.
PLEASE HELP!
-Kent
kwardle is offline   Reply With Quote
Old   August 29, 2008, 10:15
Default like this? http://jp.youtub
Giro
girogirozakk is on a distinguished road
like this?
http://jp.youtube.com/watch?v=RjA4sAUXiBc
girogirozakk is offline   Reply With Quote
Old   August 29, 2008, 10:43
Default Giro, Yes. That is essentiall
Kent Wardle
Giro,
Yes. That is essentially the problem although I also would have inlet flow at the same time. I would appreciate any help you could offer. What boundary conditions did you use for the top and the outlet? Would you be willing to send me the files for this problem?
Thanks,
Kent
Old   August 30, 2008, 05:55
Default Kent, I used "total pressure"
Giro
Kent,
I used "total pressure" BC , for the inlet and outlet (both surface).
I seted outlet's total pressure equal to the outlet-flow's kinetic energy.
Because , I want to set the outlet-flow's velocity to constant value.
Please wait a few days (or 1week) to send you sample-files(if you want).
Because , now I check my result to some experiment data.
Sorry , I'm Japanease , and my sentence is not so good ... .
Bye,
Giro
Old   September 2, 2008, 10:14
Default Giro, thanks for the response.
Kent Wardle
Giro, thanks for the response. It looks like you are specifying a fixed outlet velocity and a fixed negative pressure at the outlet boundary. This is not what I want--I would like the outlet velocity and pressure to be calculated and the flow to be induced by gravity. Can anyone tell me how I need to set up the boundary condition on the outlet to do this?
Old   September 2, 2008, 17:05
Default Hi Giro could You send them t
jfb
Josef F. Buergler
jfb is on a distinguished road
Hi Giro
could You send them to me too? Thanks a lot,
Josef
jfb is offline   Reply With Quote
Old   September 3, 2008, 06:07
Default Kent,This is ..... not good ?
Giro
http://jp.youtube.com/watch?v=U0G6kn03CTU
Old   September 3, 2008, 10:12
Default Giro, sure, that is the idea.
Kent Wardle
Giro, sure, that is the idea. However, I would like to set the outlet boundary as the tank outlet. I have found some conditions that work for my case (totalPressure for the top, fixedValue for the outlet, inletOutlet for all others on the outlet), but these only work at the beginning with all divSchemes to upwind. Even then it can crash at some later point.
After looking at this more, it really seems to be an issue of interfacial instabilities rather than BCs. When the simulation crashes, it is always after large spikes in velocity (and/or epsilon) at some point on the liquid/air interface. It seems like others have observed this same problem (http://www.cfd-online.com/cgi-bin/Op...=2531#POST2531). Is this an issue with the interface compression scheme? When I change cGamma to 1, things seem to go much smoother. Doesn't this scheme add an 'artificial' velocity in the interfacial region in order to induce interfacial compression? Can anyone clarify this or point me towards some detailed description of the scheme?
Has anyone implemented a reliable piecewise interface reconstruction (PLIC) algorithm for VOF in OpenFOAM? How would I go about doing that? I am curious to see how this compares.
Old   September 17, 2008, 14:37
Default All, I was able to solve the
Kent Wardle
All,
I was able to solve the convergence problem by setting cgamma equal to 1. I am not sure why it is set to 2 for the tutorials (e.g. damBreak). This gives a solution for the draining problem. But for the actual problem of interest, where there is constant inflow and draining at the same time in a manometer type geometry--that is, the flow from the drain is opposite gravity--I would like to be able to specify the *static pressure* on the outlet. How do I specify a constant value for the static pressure? For the standard interFoam setup, the boundary value for 'pd' is defined where (unless I am mistaken) pd is the dynamic pressure:
p = (0.5*rho*U^2) + (rho*g*h) = pd + ps
I understand there is a post-processing utilty interFoamPressure for calculating the static pressure. Has anyone used this to construct a staticPressure boundary? Is there some better way such as to to use p rather pd for the boundary field? How does one do this?
Thanks,
Kent
Pressure tank simulation Dalibor Vlcek FLUENT 2 January 10, 2019 04:36
Full pressure for rasInterFoam paka OpenFOAM Post-Processing 12 February 17, 2009 11:31
Static Pressure BC in rasInterFoam kwardle OpenFOAM Running, Solving & CFD 0 September 19, 2008 16:15
Bounding problem in running rasinterfoam qtian OpenFOAM Running, Solving & CFD 4 June 30, 2008 22:54
static pressure in a tank beginner FLUENT 1 July 11, 2007 16:57
