interFoam - stratified flow - problem with shear stress at interface
Old   December 2, 2009, 07:23
Unhappy interFoam - stratified flow - problem with shear stress at interface
Anja Miehe
AnjaMiehe is on a distinguished road
Dear Foamers,
I have a problem when simulating stratified flow of transformer oil and water with interFoam.
I simulate in a 2D channel of width 0.1 m and 6 m length. The interface shall be at 0.05 m, so at 50 %. Water is the denser fluid, so at the bottom of the channel, and the transformer oil the lighter fluid. I start the simulation with a wall of zero thickness (splitMesh) at the interface to ensure the Poiseuille profile (see Folder 01_Poiseuille in tar). The analytic solution is matched perfectly (see Poiseuille_TransformerOil_Water.pdf).
Then I take the last step as the starting point for the simulation without a wall. The resulting profile is in general not bad, but it does not match. Without any change in the profile I tried the following: run a longer simulation time (*1.5); enlarge the length of the channel (+ 2 m); enlarge number of cells in length (*1.5); enlarge number of cells in cross section (*1.5); schemes of 2nd order; surface correction factor from 1 to 0 (see TowPhaseFlow.pdf).
The problem seems to be the shear stress compatibility condition at the interface (continuity of shear stress at the interface) (see ShearStress.pdf).
I am waiting and hoping for your advice.
Anja
AnjaMiehe is offline   Reply With Quote
Old   December 9, 2009, 03:27
Default Another Try for stratified flow
Anja Miehe
Hello everybody,
I tried the two phase stratified, laminar flow for water treated as two different phases, a water-similar oil (HT350) and water and for water and air. Using water for both phases works perfectly, HT350 and water too, as their properties are very similar. Air and water is even worse than the transformer oil from above.
I am not sure if that is a problem with the simulation or with the coding of the interface treatment. If anybody has an idea, it is very welcome.
Thanks, Anja
TwoPhase_Water.pdf
TwoPhase_OilHT350.pdf
TwoPhase_Air.pdf
Old   June 10, 2010, 09:39
Emanuele
nuovodna is on a distinguished road
Hi, i m trying to simulate a two-phases Poiseuille flow like you but i have some problems. The water-air interface is not stable: the flow is not stratified. I setted up a case with: inlet / outlet boundary with a pressure drop and top / bottom wall (there's no gravity). How can i solve this problem and simulate a stratified flow?
Thanks in advance
Emanuele
EDIT: i have seen your attached file right now. Thanks
RE-EDIT : i dont understand this part of how to
- change /constant/polyMesh/boundary
between faceSet command and splitMesh. I n what way i have to modify the boundary file??
RE-RE-EDIT: solved reading this post http://www.cfd-online.com/Forums/ope...thickness.html
nuovodna is offline   Reply With Quote
Old   June 10, 2010, 11:46
Emanuele
How can you obtained a no-zero value of U along the interface?? I setted U at fixedValue (0 0 0) and obviously at the interface U values are 0.
Old   June 10, 2010, 12:38
Emanuele
I made a new mesh but i have a problem with splitMesh: it returns this error
--> FOAM FATAL ERROR:
Face 1024 in faceSet interface is not an internal face.
I attach my case
Old   June 11, 2010, 02:29
Anja Miehe
Hey Emanuele,
thanks for your interest in my work. I would like to ask you to do some steps the next time you post your case. Every command you enter in OpenFOAM will lead to a message on the terminal, if you do the commands as, for example,
  • faceset |tee log.faceset
you can see the message on the terminal and have a log file where you can read it and post it here, too. It is far easier to find the fault this way.
In general, I did two different simulations. First, I simulate the velocity profile with a baffle (wall of zero thickness in OpenFOAM) seperating the two fluids. I obtained the two Poiseuille-Profiles. I did this to avoid the development of a wavy interface. With these results I deleted the interface (that is the entry for the two faces in the file of the time step to continue with) and continued to obtain the multiphase flow velocity profile.
Additionally, I did not start with air right away because of some problems in setting up the case.. Therefore I started with water-water, water-waterLikeOil, water-HeavyOil and at last water-air as the difference in properties increases this way. I also did not use gravity, but surface tension.
Please find attached my water-air case. In the post, probably in the afternoon, I will also write the commands and files together for the mesh with internal face walls (baffles).
Due to a securty error, I cannot upload the tar.gz of my case. Please write me a mail to get the files.
Hope it does help. Best wishes Anja
Old   June 11, 2010, 08:55
Default How I did my mesh
Anja Miehe
My constant/polyMesh/blockMeshDict is:
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1.0;
vertices
    (0 0 0)
    (6 0 0)
    (6 0.001 0)
    (0 0.001 0)
    (0 0 0.05)
    (6 0 0.05)
    (6 0.001 0.05)
    (0 0.001 0.05)
    (0 0 0.1)
    (6 0 0.1)
    (6 0.001 0.1)
    (0 0.001 0.1)
blocks
    hex (0 1 2 3 4 5 6 7) (600 1 50) simpleGrading (1 1 1)
    hex (4 5 6 7 8 9 10 11) (600 1 50) simpleGrading (1 1 1)
edges
patches
    wall top
        (8 9 10 11)
    wall bottom
        (0 3 2 1)
    patch inletWater
    (0 4 7 3)
    patch inletAir
    (4 8 11 7)
    patch outletWater
    (2 6 5 1)
    patch outletAir
    (5 6 10 9)
    empty frontAndBack
    (6 7 11 10)
        (7 6 2 3)
    (4 5 9 8)
    (0 1 5 4)
mergePatchPairs
The command I use is: blockMesh |tee log.blockMesh
The log.blockMesh file does look like:
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 1.6-f802ff2d6c5a
Exec   : blockMesh
Date   : Jun 11 2010
Time   : 14:15:10
Host   : hugo163
PID    : 21816
Case   : /home/anja/01_Einlauf
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Creating block mesh from
    "/home/anja/01_Einlauf/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
Check block mesh topology
        Basic statistics
                Number of internal faces : 1
                Number of boundary faces : 10
                Number of defined boundary faces : 10
                Number of undefined boundary faces : 0
        Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating points with scale 1
Creating cells
Creating patches
Creating mesh from block mesh
Writing polyMesh
End
Create a system/faceSetDict like:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
// Name of set to operate on
name interface;
// One of clear/new/invert/add/delete|subset/list
action new;
// Actions to apply to pointSet. These are all the topoSetSource's ending
// in ..ToFace (see the meshTools library).
topoSetSources
    // Faces with face centre within box
    boxToFace
        box  (0 0 0.0499) (6.0 0.001 0.0501);
The command I use is: faceSet |tee log.faceSet
The log.faceSet file does look like:
Exec   : faceSet
Date   : Jun 11 2010
Time   : 14:17:14
Host   : hugo163
PID    : 22251
nProcs : 1
Create time
Create polyMesh for time = 0
Reading faceSetDict
Backing up interface into interface_old
Set:interface  Size:0  Action:new
    Adding faces with centre within box (0 0 0.0499) (6 0.001 0.0501)
Writing interface (size 600) to "constant/polyMesh/sets/interface"
End
The size must be exactly the number of cells in x direction for the case at hand. Goto file constant/polyMesh/faces:
FoamFile
    version     2.0;
    format      ascii;
    class       faceList;
    location    "constant/polyMesh";
    object      faces;
240700
4(1 602 1804 1203)
4(1202 1203 1804 1803)
4(2 603 1805 1204)
4(1203 1204 1805 1804)
4(3 604 1806 1205)
4(1204 1205 1806 1805)
4(4 605 1807 1206)
4(1205 1206 1807 1806)
4(5 606 1808 1207)
and get the number 240700. Edit the file constant/polyMesh/boundary to make it look like that (9 instead of 7 because every interface consists of to "surfaces")
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    object      boundary;
9 //!!!!! beause of the two new faces
    top
        type            wall;
        nFaces          600;
        startFace       119300;
    bottom
        type            wall;
        nFaces          600;
        startFace       119900;
    inletWater
        type            patch;
        nFaces          50;
        startFace       120500;
    inletAir
        type            patch;
        nFaces          50;
        startFace       120550;
    outletWater
        type            patch;
        nFaces          50;
        startFace       120600;
    outletAir
        type            patch;
        nFaces          50;
        startFace       120650;
    frontAndBack
        type            empty;
        nFaces          120000;
        startFace       120700;
    }                 // !! here the new faces
    interface_up
        type            patch;
        nFaces          0;
        startFace       240700; // number from /constant/polyMesh/faces
    interface_down
        type            patch;
        nFaces          0;
        startFace       240700;
The splitMesh command is in general: splitMesh faceSet newface1 newface2
The newface1/2 are form the boundary file and will be the new boundaries. The command here is therefore: splitMesh interface interface_up interface_down |tee log.splitMesh
and the log.splitMesh file does look like:
Exec   : splitMesh interface interface_up interface_down
Date   : Jun 11 2010
Time   : 14:27:58
Host   : hugo163
PID    : 24566
nProcs : 1
Create time
Read 600 faces to split
Adding point and face zones
Constructed topologyModifier:
Splitter
    type attachDetach;
    faceZoneName membraneFaces;
    masterPatchName interface_up;
    slavePatchName interface_down;
    triggerTimes 1(0);
    manualTrigger false;
    active true;
Writing mesh to 0.001
end
Now you have to add the new faces interface_up and interface_down to all the boundary files in the folder 0 with the properties you want to have, for example a wall in my case
last: do a checkMesh |tee log.checkMesh
to be sure that everything went well
Old   June 14, 2010, 06:44
Emanuele
The wrong part in my case is the faceSet command: i obtain a size (122) not equal to x size (16). At this resolution checkMesh fail but if i increase (eg 600) it gives a good output but faceSet still says a wrong size. Perhaps there is something wrong on my blockMesh file. I changed it according to your own and now it works.
Thanks
PS It's important to delete *Zones files in constant/polyMesh before splitMesh command
Old   June 14, 2010, 06:49
Anja Miehe
I am happy that your mesh works now. Hope, that the simulation will too.
compatibility condition, interface, interfoam, shear stress, velocity profile
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Flow not moving - Supersonic/Initial Pressure problem? shankara.2 FLUENT 0 June 9, 2009 20:49
Stratified Two Phase Flow ravi1650 FLUENT 1 May 29, 2009 05:13
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 16:52
