Combined compressible flow and moving mesh with layers
Old   September 1, 2008, 23:05
Default Hi, I am trying to run a m
Andrew King
andersking is on a distinguished road
I am trying to run a moving mesh simulation with compressible flow. The solver is based on sonicTurbDyMEngineFoam, but without the crank angle parts. Also I am trying to use a layered mesh for the moving mesh component.
Unfortunately my solution blows up after a new layer is added, as in the following images.
before added layer.
after added layer
Somehow the pressure is not getting updated correctly. I'm not sure if this is due to the new cells not receiving their correct value, or the fact that the added layer is too small (I have tried different layer thicknesses however.), also the large negative (absolute) pressures suggest that the pressure/temp values for the new cells are the problem. I have run this solver under 1.4-dev previously with no problems. Any help is appreciated.
Cheers,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   September 1, 2008, 23:08
Default PS. sorry for the large images
Andrew King
PS. sorry for the large images. I meant to resize these first.
Dr Andrew King
Curtin University
Old   September 2, 2008, 21:29
Default Have you looked at the actual
Sandeep Menon
deepsterblue will become famous soon enough
Have you looked at the actual cell pressure for the new cells? It would be more useful if you provide cell data and not point-interpolated pressure. Looks like this is a mapping issue, but I can't be sure. Also, since you mention that it worked with 1.4-dev, I'm assuming that you're using 1.5 now?
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   December 1, 2010, 05:29
Default howto sonicTurbDymEngineFoam
abminternet is on a distinguished road
Hi Andrew,
I'm also trying to set up a case with sonicTurbDyMEngineFoam, but as I'm an OpenFOAM newbie, and as I can't find any tutorial or info on the net, I haven't got very far. Would you mind to share a bit of your knowledge? what do the entries on the dictionaries mean, or what dictionaries do I need? or any idea as where to find some info? Thanks a lot.
abminternet is offline   Reply With Quote
Old   March 1, 2011, 09:40
Hi Andrew and Sandeep,
did you happen to find out the problem with pressure? I am also using sonicTurbDyMEngineFoam, and I notice the same effect, pressure doesn't seem to be changing. When both valves are closed, pressure remains constant inside the cylinder, as soon as one of the valves opens, pressure in all of the cylinder changes to adopt the pressure in the port whose valve just opened. Any ideas?? I would greatly appreciate it.
Turbulent compressible solver rhoTurbFoam with dynamic moving mesh eno OpenFOAM Running, Solving & CFD 4 December 12, 2011 03:38
icem 3d mesh for compressible flow with combustion James FLUENT 0 September 3, 2007 11:46
How 2 generate combined mesh? bogesz CFX 0 April 7, 2004 12:42
Moving grids & compressible flow Cristian Orozco Main CFD Forum 1 May 10, 2001 13:43
Number of layers for moving piston Hassaneen Siemens 1 August 17, 2000 04:43
