Looking for recommendions for two evolving cases
Old   July 23, 2008, 14:11
Default First of all, I am relatively
Dennis Kingsley
dkingsley is on a distinguished road
First of all, I am relatively new to OpenFOAM, but have a 15 year history with other commercial and/or university codes including the code Eric Patterson authored CFDSHIP-Iowa.
Over the last few weeks I have been able to take grids I created in Gridgen and transfer them to OpenFOAM and got resonable incompressible unsteady results.
The first model is a ships rudder on a ground board like you would have in a water tunnel. I have been manually moving the inlet/outlet patches to change the AoA. I would like some pointers on how to set this up with a movable mesh so I can prescribe a set of rudder angles to develop lift/drag curves as a function of rudder angle. Eventually, I will be including this in the flow field of the actual ships hull.
The second case I have is a ships topside again modeled on a ground board. I have used turbFoam to get an unsteady solution of the wake around the superstructure. Here I am looking for input on how to model the exhaust gases that are ejected from the stacks for a various stack gas velocites and temperatures. I need to track the stack gas plume, and if it impinges on the ships superstructure I need to determine the temperature of the plume at that point. I should add that all of this needs to be done in the context of various wind over deck speeds and directions.
thanks
dennis
dkingsley is offline   Reply With Quote
Old   July 23, 2008, 15:30
Default Hi Dennis, Send me an email
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Hi Dennis,
Send me an email or give me a call. I can help you with both cases.
Eric
egp is offline   Reply With Quote
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
More Cases or Examples jon OpenFOAM Running, Solving & CFD 5 October 2, 2008 08:11
Where to get validation cases? me Main CFD Forum 2 June 21, 2007 05:30
XY Plots for different cases Ness FLUENT 4 May 29, 2007 14:50
How to run example cases PattiMichelle Phoenics 2 February 6, 2002 12:00
