KEpsilon error
Old   July 14, 2008, 18:37
Default Hi I ran a case with kEpsi
mohd mojab
mou_mi is on a distinguished road
Hi
I ran a case with kEpsilon model and set the wall for "k" and "epsilon" as a fixedValue for B.C. and OF gave me this error for "k" and "epsilon",
Create mesh for time = 70
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model kEpsilon
Starting time loop
Time = 70.001
Courant Number mean: 0.00103968 max: 0.0494671
DILUPBiCG: Solving for Ux, Initial residual = 5.85686e-05, Final residual = 4.6585e-10, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.000515567, Final residual = 3.09483e-09, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.00109401, Final residual = 7.4057e-09, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.942377, Final residual = 9.56964e-07, No Iterations 273
time step continuity errors : sum local = 2.11503e-12, global = 2.74312e-14, cumulative = 2.74312e-14
DICPCG: Solving for p, Initial residual = 0.000860842, Final residual = 9.75e-07, No Iterations 164
time step continuity errors : sum local = 4.12992e-12, global = -7.69118e-14, cumulative = -4.94806e-14
--> FOAM FATAL ERROR : fixedValue is the wrong epsilon patchField type for wall-functions on patch wall
should be zeroGradient
From function wall-function evaluation
in file /home/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/checkPatchFieldTypes.H at line 13.
FOAM exiting
I changed them to "zeroGradient" for wall boundary, after some calculation in the first time step it gave this error.
Reading field p
Reading field U
Starting time loop
Time = 70.001
#0 Foam::error::printStack(Foam:stream&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt in "/lib64/tls/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbule nceModels.so"
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::GeometricField<double,> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbule nceModels.so"
#6 Foam::turbulenceModels::kEpsilon::correct() in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbule nceModels.so"
#7 main in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam"
#8 __libc_start_main in "/lib64/tls/libc.so.6"
#9 Foam::regIOobject::readIfModified() in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam"
Floating exception
would you help me what happened here?
Thank you
mou
mou_mi is offline   Reply With Quote
Old   July 15, 2008, 03:18
Default Hi, Floating Point Exceptio
Andrew King
andersking is on a distinguished road
Floating Point Exception means that some of you numbers are unbounded - Inf (infinity) or NaN (not a number). Sometimes this can be overcome by executing
unset FOAM_SIGFPE
and running your simulation again (this basically stops checking for out of bounds errors).
Most of the time this won't fix the problem, however, it is more likely to be a problem with boundary conditions or the mesh.
Cheers
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   July 15, 2008, 04:00
Default Hi Mou From your error-mess
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Mou
From your error-messages, especially #3 and #6, tells me that you are dividing by 0 in your turbulence model. Do you on any of your boundaries, inlet, outlet, etc, set either k or epsilon to 0 in stead of 1e-11?
My experience is that these properties cannot be zero, as you are dividing with them. I also believe that it would be necessary to put k!=0 in the interior, but you probably already have that.
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   July 16, 2008, 18:25
Default hi Niels as you mentioned,
mohd mojab
hi Niels
as you mentioned, I set 0 for the k and it was the problem.
Thank you
mou
Understanding k from kepsilon markh83 OpenFOAM Post-Processing 3 December 5, 2008 03:42
Add new RASModel kEpsilon modification ivanwhlau OpenFOAM Running, Solving & CFD 3 August 21, 2008 04:36
About kEpsilon turbulence model osimonsimon OpenFOAM Running, Solving & CFD 10 April 24, 2008 02:52
Kepsilon BC and intialization podallaire OpenFOAM Running, Solving & CFD 0 October 17, 2007 20:29
KEpsilon and KOmega larry OpenFOAM Running, Solving & CFD 3 June 29, 2006 01:38
