How to simulate hot flue with fine dust flows with subsequent quenching?
Old   June 13, 2008, 05:02
Default Ah, ok. Right now I finally fo
  #21
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Ah, ok. Right now I finally found these books in our University Library. So I'm now going to see if they exist also in reality :-)
lord_kossity is offline   Reply With Quote
Old   June 13, 2008, 06:11
Default I have a small perl-script to
  #22
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
I have a small perl-script to help me in this that
you might want to use
http://files.nequam.se/liquidProperties.tgz
the units in the NSRDS tables are per mole and not per kg, so some coefficients needs to be recalculated.
there is an example file for water that shows you how its done.
to create the foam .C and .H files just run
./nsrds2foam.pl props.water
niklas is offline   Reply With Quote
Old   June 13, 2008, 08:06
Default Thank you very much. I'll s
  #23
Andreas Dietz
I'll soon have a look at it!
Old   June 16, 2008, 07:33
Default Hi Niklas, Another thing...
  #24
Andreas Dietz
Hi Niklas,
Another thing...
Since you are still into combustion research (as far as I know/imagine) I have another question to you; in your PhD you mention that "a practical Eulerian treatment of the spray [...] will not be realizable for some time." According to another thread (http://www.cfd-online.com/OpenFOAM_D...tml?1213613536),
I'm interested if it is now possible to simulate combustion using Euler-Euler methods?
Best regards,
Andreas
Old   June 16, 2008, 15:48
Default In openfoam - not at the momen
  #25
niklas's Avatar
Niklas Nordin
In openfoam - not at the moment afaik, but im working on it
Im currently looking into the ELSA approach.
Old   June 17, 2008, 03:01
Default Sounds quite interesting to me
  #26
Andreas Dietz
Could you share some of your literature with me?
Old   June 17, 2008, 06:01
Default Back to the original topic of
  #27
Andreas Dietz
Back to the original topic of NSRDS functions and adding liquids...
Today I managed to order the "Data compilation tables of properties of pure compounds" to our TU library
What I'm thinking about now is:
Will it be possible to add solid molecules instead of liquid ones or am I then going to run into conflicts concerning atomization an break up for example?
Old   June 23, 2008, 02:16
Default SAE 2005-01-0213 Coupling Vap
  #28
niklas's Avatar
Niklas Nordin
SAE 2005-01-0213
Coupling Vaporization Model with the Eulerian ....
Lebas, et al.
SAE 2003-01-0005
A 3D Eulerian Model to Improve the Primary Breakup of Atomizing Jet
Blokkeel, et al.
Numerically, its all about Reynolds and Weber numbers so it doesnt matter if its solid or liquid, as long as surface tension, density, viscosity exist and produce usable number.
And you can always turn off any model you dont need.
Old   June 24, 2008, 03:59
Default Thank you very much for the re
  #29
Andreas Dietz
Thank you very much for the references!
The reason for me asking if it is possible to include solid molecules is that in your example of H2O and the according "props.water" file all the coefficients for the solid properties are omitted (e.g. solid heat capacity).
How can I add these values for example if I want to create the foam .C and .H files for NaCl?
Old   June 24, 2008, 06:20
Default solid properties have been omi
  #30
niklas's Avatar
Niklas Nordin
solid properties have been omitted from the 'liquids'.
If you still would like to use it I suggest you just replace the heat capacity with the solid heat capacity. etc.
Old   July 1, 2008, 08:19
Default It doesn't seem to be that eas
  #31
Andreas Dietz
It doesn't seem to be that easy to implement solids using your pearl script...
I'm running into the error "Equation for latent heat of evaporation is not implemented yet."
Could you please help me out!?
Old   July 1, 2008, 09:24
Default which equation is it.
  #32
niklas's Avatar
Niklas Nordin
Old   July 1, 2008, 09:38
Default It's the equation for Heat of
  #33
Andreas Dietz
It's the equation for Heat of Vaporization.
For water it is "solved" using NSRDS function 106 (4 coeeficients).
For NaCl it is "solved" using NSRDS function 100 (only 1 coefficient given).
It seems like that's the problem...
Old   July 2, 2008, 05:08
Default Now that the problem is solved
  #34
Andreas Dietz
Now that the problem is solved, I add NACL to the liquids directory and run "wmake libso".
At first it looks quite promising;
'dependency list for source file NACL/NACL.C' is made and '~/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libliquids.so' is updated.
But when I try to run my case a FATAL ERROR occurs: Unknown liquid type NACL
why is that???
Old   July 2, 2008, 06:16
Default You need to add NACL/NACL.C
  #35
niklas's Avatar
Niklas Nordin
You need to add
NACL/NACL.C
to the src/liquids/Make/files file
then you can run 'wmake libso'
Old   July 2, 2008, 06:47
Default Well, I already added that "NA
  #36
Andreas Dietz
Well, I already added that "NACL/NACL.C" line in any file in the Make directory. - Without any success...
Old   July 2, 2008, 06:53
Default try recompiling the lagrangian
  #37
niklas's Avatar
Niklas Nordin
try recompiling the lagrangian stuff and the dieselFoam application.
Old   July 2, 2008, 08:01
Default anyhow, that doesn't work eith
  #38
Andreas Dietz
anyhow, that doesn't work either.
I recompiled the three directories in the lagrangian subdirectory and also the dieselFoam solver.
But NACL is still unknown.
Do you have any further hints?
Old   March 25, 2009, 04:46
Michael
farbfilm is on a distinguished road
Hi Niklas,
did you have success with the ELSA approach??
I would be very interested...
farbfilm is offline   Reply With Quote
Old   November 21, 2014, 15:09
yes
ENKIME is on a distinguished road
Thanks a lot Mr. Nordin for this post, I'm using Perry's handbook for determine the properties, did you have any other suggest?
Thanks a lot
Kind regards
ENKIME is offline   Reply With Quote
