June 19, 2009, 22:25 |
How to compile OF-1.5 in the debug mode?
Sandy Lee
Rep Power: 18 |
Hi OpenFOAMers,
Who know how to compile OF-1.5 in the debug mode? In OF-1.3, If I want a debug version of OpenFOAM, I just need to change the lines in $HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc from ============================= export WM_COMPILE_OPTION=Opt # export WM_COMPILE_OPTION=Debug # export WM_COMPILE_OPTION=Prof to # export WM_COMPILE_OPTION=Opt exportWM_COMPILE_OPTION=Debug # export WM_COMPILE_OPTION=Prof ========================= However, how can still make it work in OF-1.5? In addition, what is its step by step procedures to debug the original codes under the debug version of OF-1.5? Thanks Sandy sandy.lee37@gmail.com |
July 6, 2009, 11:08 |
Rep Power: 16 |
vi ~/OpenFOAM/OpenFOAM-1.5.x/etc/bashrc
# WM_COMPILE_OPTION = Opt | Debug | Prof : ${WM_COMPILE_OPTION:=Debug}; export WM_COMPILE_OPTION |
July 7, 2009, 05:22 |
#3 | |
Sandy Lee
Rep Power: 18 |
Hi sir, thank you a lot for your note. However, I remembered that I ever tried it but not work. Could you further tell me, after finish above setting, what is next step I should do step by step? Please don't mind, I just begin to study them. |
July 7, 2009, 11:51 |
Rep Power: 16 |
Sandy,
Edit the bashrc file, then log out and log back in in order to reset the $WM_COMPILE_OPTION environment variable. Then navigate to the $FOAM_INST_DIR/OpenFOAM-1.5.x/ and run ./Allwmake This will compile debug versions of the libraries and place them in the lib/linux64GccDPDebug/ directory. |
July 8, 2009, 08:43 |
Sandy Lee
Rep Power: 18 |
Thank you very much, sir . I will try it step by step.
Debug mode with UDF ?? | Thierry | FLUENT | 1 | October 9, 2018 21:57 |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
Compiling OpenFOAM 13 in Debug mode | fra76 | OpenFOAM Installation | 2 | April 14, 2006 03:09 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
