R used in thermodynamicproperties
Old   June 13, 2008, 10:33
Default Hi I find that R is set to
srinath
srinath is on a distinguished road
Hi
I find that R is set to .714286J/(KgK), in most of the examples.
This does not correspond to specific gas constant of air. So is foam assuming some strange gas for the examples or am i missing something?
Univeral gas constant = 8.314J/(mol K)
Mol wt of air =29gm/mol
Therefore specific gas constant = 8.314/.029 = 287 J/(Kg K)--Also confirmed by wikipedia
Am i missing something trivial here?
Could someone please clear this, as i am trying to benchmark the solvers?
Regards
Srinath
srinath is offline   Reply With Quote
Old   June 13, 2008, 11:26
Default Can you please list out the tu
ash
Arun Shourie
ash is on a distinguished road
Can you please list out the tutorials.
But in sonicFoam tutorial its given correctly only
ash is offline   Reply With Quote
Old   June 13, 2008, 12:29
Default The value of R, i find in
srinath
/tutorial/sonicFoam/forwardstep/constant/thermodynamicProperties is
as follows
R [0 2 -2 -1 0 0 0] 0.714286;
But i do notice that it is set to 287 in the shockTube directory.--Strange
Regards
Srinath
Old   June 16, 2008, 03:47
Default Hi If you look in the Progr
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
If you look in the Programmers Guide pp 61, you will find that R is set, such that the speed of sound in air is 1 m/s.
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   June 16, 2008, 06:41
Default Thanks Niels I also find in
srinath
Thanks Niels
I also find in the Programmers guide a reference to thermal conductivity kappa.
But nowhere in the code for sonicFoam is kappa even used. It is also not mentioned in thermodynamicProperties in ver-1.4.1
Is this a minor oversight, which can be fixed trivially, by changing mu in the energy equation to kappa?
Regards
Srinath
