How does one convert a scalarField into a volScalarField |
June 3, 2008, 05:59 |
Hi Su,
well i have cyclic con
#21 |
davey david
Rep Power: 17 |
Hi Su,
well i have cyclic conditions for the inlet/outlet,symmetry plane bottom and three electrode patches with psi = 1/-1,alternating and fixed walls having a zero gradient. how do i get to compile the code to suit my case?do i simply omit the temporal terms? thanks in advance davey |
June 3, 2008, 20:44 |
Hi davey
you got a uniform
#22 |
Hi davey
you got a uniform field with laplaceFoam solver? Su Junwei |
June 5, 2008, 05:26 |
Hi Su,
yes,i do have a unifor
#23 |
davey david
Rep Power: 17 |
Hi Su,
yes,i do have a uniform field but i used the icofoam solver and commented out all the pressure and velocity terms ,whiles adding my laplace equation to it.seems to be working fine.will keep you posted on any mishaps which might crop up. thanks davey |
August 4, 2016, 09:43 |
#24 | |
elham usefi
Rep Power: 10 |
Hi su_junwei I have a question! what does exactly the last zero in dimensionedScalar("zero", dimensionSet(0,0,0,0,0,0,0), 0.0), refers to? |
How to sum up scalarField | wese | OpenFOAM Running, Solving & CFD | 2 | August 19, 2019 17:30 |
How to set up an AUTO_WRITE scalarField | xiao | OpenFOAM Running, Solving & CFD | 9 | July 22, 2010 03:23 |
max for scalarField | maka | OpenFOAM Bugs | 9 | February 19, 2009 09:43 |
ScalarField division | maka | OpenFOAM Pre-Processing | 2 | August 27, 2007 05:10 |
[CGNS] Computing a cellcentered scalarField from a vertexcentered scalarField | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 10 | February 22, 2007 07:43 |
